I have a zipato RFID Mini keypad, and it was included on my old configuration, but I reset my zwave stick and factory reset all my zwave devices, and this is the only one I can NOT reset. There is nothing in the manual except that I can exclude the node with the original host (the stick which I reseted, so that will not work) or with a zipato box, even thou the keypad it not on its zwave network (strange how you can exclude it without including it first, which I do not have, and why can I not use openzwave or a button combo for that?).
I tried http://www.benext.eu/static/manual/tagreader500.pdf factory reset but that does not work, and zipato refers me to the manual (in which states nothing about a button press to factory reset).
Can someone please tell me how to factory reset it?
Zipato RFID Mini keypad reset (how?) Topic is solved
JuanUil
- Domoticz version: 4.11083
Re: Zipato RFID Mini keypad reset (how?)
I have the same problem,
anyone any idea?
anyone any idea?
JuanUil
Nobody?
Keleos
I'm also facing this problem now.
After I accidentally hardreset my ZME-UZB I'm now not able to reset the keypad... The old configuration is still available in domoticz, but I do not know how to reset this piece of hardware
Greetings
Greetings
mkoele
I had the same problem. I pushed the wrong button and my z-wave controller was returned to factory defaults.
after a long search i found that any controller (even if the keypad is not included in the z-wave network) can send an exclude frame to all z-wave devices.
this worked for me:
- put the z-wave controller in exclude mode
- put the zipato keypad in exclude mode (hold tamper switch for 1 second)
this did not work the first time but after 5 attempts the device was back to factory default and could be included in the new z-wave network.
i hope it helps.
this worked for me:
i hope it helps.
mkoele
A small addition to my comment.
the exclude process with my second keypad took about 15 attempts. so keep trying
Keleos
Thank you very much, I'll try it as soon as possible.
Greetings
Greetings
Keleos
That helped me a lot. I was getting close to throwing the keypad away.Thank you very much
