Zwave - how to link a Device with a NodeID/Name
Lectere
Post by Lectere »
I've added 10 zWave nodes to Domoticz, resulting in a list of 75 devices.
But there is no way to find what Device is linked to what NodeID. I have a big list of switches, and I don't know which one is what. I've ended up pressing the buttons, and check the 'last seen' to determine what node I'm actually dealing with.
This cannot be the right way!
Is there not a way show the Node ID or Node Name in the Devices list? I can't believe I'm the first one to ask this. I've searched google and this forum, no luck...
Effictent and redundant two-factor authentication? http://www.smspassword.com
Flopp
Re: Zwave - how to link a Device with a NodeID/Name
Post by Flopp »
Do you have same product for all devices, i mean if you have one plug and one switch you can see the type in Hardware setup.
Flopp
Post by Flopp »
Or you should have add them one-by-one
Egregius
Domoticz version: v2024.7
Post by Egregius »
The node id is in the devicetable in hex.
But, you should have included one by one and name them instantly.
Lectere
Post by Lectere »
Thanks for the tip on the node ID in Hex, that works partly, because some hex are appended.
I still think it would be a welcome feature to have the Node Name in device table.
Apperently there are others who have the same question; viewtopic.php?t=11509
Thanks,
