I've added 10 zWave nodes to Domoticz, resulting in a list of 75 devices.
But there is no way to find what Device is linked to what NodeID. I have a big list of switches, and I don't know which one is what. I've ended up pressing the buttons, and check the 'last seen' to determine what node I'm actually dealing with.
This cannot be the right way!
Is there not a way show the Node ID or Node Name in the Devices list? I can't believe I'm the first one to ask this. I've searched google and this forum, no luck...
Zwave - how to link a Device with a NodeID/Name
- Lectere
Effictent and redundant two-factor authentication? http://www.smspassword.com
- Target OS: -
Re: Zwave - how to link a Device with a NodeID/Name
Do you have same product for all devices, i mean if you have one plug and one switch you can see the type in Hardware setup.
- Target OS: -
Or you should have add them one-by-one
- Egregius
- Domoticz version: v2024.7
The node id is in the devicetable in hex.
But, you should have included one by one and name them instantly.
- Lectere
Thanks for the tip on the node ID in Hex, that works partly, because some hex are appended.
I still think it would be a welcome feature to have the Node Name in device table.
Apperently there are others who have the same question; viewtopic.php?t=11509
Thanks,
Thanks,
