Watermeter project final..
abc1000
Post by abc1000 »
First of all i'm not a guru...
But finally i'v got perfect watermeter readings with these.
LJ12A3-4-Z/BX schema and python script attached..
rename watermeter13.txt in watermeter13.py
watermeter13.txt
(1.28 KiB) Downloaded 693 times
schema watermeter3.txt
(354 Bytes) Downloaded 783 times
stlaha2007
Re: Watermeter project final..
Post by stlaha2007 »
Sound interresting... can you explain a little more, eg. post a picture, details about the particular watermeter type/make/model of the sensor?
Sent from my K00C using Tapatalk
abc1000
Post by abc1000 »
Here you are..
Derik
Post by Derik »
Great job for the first time
And now try to upload this data to Pvoutput.....
Very nice graphs..:
http://pvoutput.org/aggregate.jsp?id=15 ... 63&v=0&t=m
Monthley live days years seasons weather etc etc..
Hesmink
Post by Hesmink »
Where do you get the 8V from?
I got the same sensor, but it didn't work with 5v.
Hesmink
Post by Hesmink »
While I'm at it, I understand the resistors, but what capacitor do I need for this?
Derik
Post by Derik »
sorry..
Only perhaps a ESP2866 icl a watermeter and a temp senors and a p1 ...
Easy to built..
abc1000
Post by abc1000 »
@Hesmink
8volt is from a ac/dc chinese adapter...because 5v is too low for the sensor.
@Hesmink
a 100 nano farad capitor is ok
stlaha2007
Great job. Need to look at the script and see if i can use it with my type of watermeter.
In combination with my PI and to be P1SmartMeter Reader.
Sent from my D6603 using Tapatalk
remko2000
Post by remko2000 »
I have connected the sensor according to the diagram of abc1000. It seems to work well.
How do I use the added pythonscript? Is there somekind of manual? How do I integrate it in domoticz? Can someone put me on the right track?
