Dummy Thermostat
JacquesMulders
Dummy Thermostat
Post by JacquesMulders »
Is it possible to create a dummy thermostat just like the evohome system has, with a thermostat setpoint and the actual temperature. now is it only possible to create a dumme thermostat setpoint.
i've tryed it to create a virtual thermostat using this url
/json.htm?type=createvirtualsensor&idx=894&sensorname=Testthermostaat&sensortype=70
(in the database the evohome devices has type 70)
Schermafbeelding 2016-10-27 om 14.30.00.png (78.96 KiB) Viewed 10244 times
JacquesMulders
Re: Dummy Thermostat
found out that the url was wrong... correct url is :
/json.htm?type=createevohomesensor&idx=<IDX OF DUMMY HARDWARE>&sensortype=70
maybe it can be implemented in de dummy hardware list?
Egregius
Domoticz version: v2024.7
Post by Egregius »
Where does the actual temperature comes from?
JacquesMulders
It comes from whatever you update it with, same for the set temp...
Egregius
Post by Egregius »
So you need to update the device with a temperature of another device? But to do that you need to first read the setpoint, otherwise you can't update?
Don't get the advantage over a separate setpoint and thermometer then.
JacquesMulders
i want to use for example an fibaro flood sensor as a thermostat, so use the temp of the floodsensor and switch an floorheating valve open to heat the room. i think its a nice addition to it to have it combined in to 1 device instead of 1 temp sensor and 1 thermostat.
it is possible, with the link i provided in the second post. i think it would be nice if it could be in the dropdown list of the dummy hardware.
ive tried to compile domoticz with the adaption myself, but my knowledge of c++ and the domoticz root system is not enough to get it working.
JacquesMulders
Nevermind, in the dummy hardware the device is not working properly. i will try to do it via the evohome script hardware.
bloody2k
Post by bloody2k »
Hi JacquesMulders
Have you tried creating your dummy sensor trough Setup->Hardware->Dummy->Create virtual sensor?
Creating a dummy sensor here, I can select the type Thermostat Setpoint, which I would guess could do what you want to.
Can i ask you, how you control you floor heating valves?
I'm thinking of creating my own script/system to control my waterbased floor heating, but I cant seem to figure out the best way to control the valves, since they are working on 24v I have been thinking of a Qubino Flush relay.
What hardware are you using?
JacquesMulders
bloody2k wrote:Hi JacquesMulders
i saw the thermostat setpoint but this one doesnt have a combined temperature/setpoint.. thats what i like about the evohome devices.
i've now added the evohome via script hardware and that works perfect, i've build a script to import my tado and controll it from domoticz... i'm still in the process of building the set script, the temp value update script is ready.
on my floor heating mixer i have 230vac valves, so my plan was to build a script that just turns a fibaro on. thats only for the toilet/hallway, they may only get heat from the cv when the living room is also heated, i dont wat that the toilet turns on my cv... the rest of the house i control with tado, but i wanted them all in domoticz.
mikkel75
Post by mikkel75 »
I have the same problem - currently having 2 dummy devices per room; thermostat and temp sensor, both updated by Lua script.
I would very much like a dummy device that has both values exactly like the one you suggest.
I have tried you URL to create the Evo device, which works fine, but I'm missing the possibility from Domoticz GUI to set new SetPoint, like it's possible with other thermostats - is that possible?
How do you from Lua updat both setpoint and temperature on the EvoHome device?
Thanks.
P.S. I have a Roth floor heating system (Touchline) with an Ethernet interface. I have Lua code that read/write to that system via HTTP.
PDP8
Domoticz version: V4.9700
Post by PDP8 »
Is there any progress in this Dummy Thermostat? I would also like
to have a dummy thermostat to set temperatures @ certain times.
Regards, Roland
markjgabb
Domoticz version: 3.8153
Post by markjgabb »
same here...ive only just realized this doesnt work....
ive added it from the dummy switches area but i cant find it to use it anywhere
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
Qxlkdr
Post by Qxlkdr »
mikkel75 wrote: Thursday 02 February 2017 9:22 P.S. I have a Roth floor heating system (Touchline) with an Ethernet interface. I have Lua code that read/write to that system via HTTP.
I also have a floor heating system (Roth Touchline) with an Ethernet interface.
Please explain how you read/write to the Roth system via HTTP. I would really appreciate it. Can you share the instruction and the LUA code?
Thanks in advance.
mikkel75
Post by mikkel75 »
Here is my LUA code - roth.lua (placed in scripts/lua)
local roth_ip = "192.168.1.10"
package.cpath = package.cpath..';/usr/lib/x86_64-linux-gnu/lua/5.2/socket/?.so'
package.cpath = package.cpath..';/usr/lib/x86_64-linux-gnu/lua/5.2/?.so'
-- sudo ln -s /usr/share/lua /usr/local/lib/lua
-- install lua-socket
-- The Request Bin test URL: http://requestb.in/12j0kaq1
local http = require("socket.http")
local ltn12 = require("ltn12")
roth2device = { "Soveværelse", "Værksted", "LBad", "SBad", "Albert", "Emil", "Gang" }
function sendRequest(x)
  local path = "http://"..roth_ip.."/cgi-bin/ILRReadValues.cgi"
  local data = '<body><version>1.0</version><client>App</client><file_name>Controller</file_name><item_list_size>13</item_list_size><
item_list><i><n>G'..x..'.kurzID</n></i><i><n>G'..x..'.ownerKurzID</n></i><i><n>G'..x..'.RaumTemp</n></i><i><n>G'..x..'.SollTemp</n></
i><i><n>G'..x..'.OPMode</n></i><i><n>G'..x..'.WeekProg</n></i><i><n>G'..x..'.TempSIUnit</n></i><i><n>G'..x..'.SollTempMaxVal</n></i><
i><n>G'..x..'.SollTempMinVal</n></i><i><n>G'..x..'.SollTempStepVal</n></i><i><n>G'..x..'.OPModeEna</n></i><i><n>G'..x..'.WeekProgEna<
/n></i><i><n>CD.rooms['..x..']</n></i></item_list></body>'
  local response_body = { }
  local res, code, response_headers, status = http.request
    method = "POST",
    url = path,
    source = ltn12.source.string(data),
    headers =
      ["Content-Type"] = "text/xml",
      ["User-Agent"] = "Roth-Touchline.../1.05",
          ["Content-Length"] = string.len(data)
    sink = ltn12.sink.table(response_body)
  if (code == 200) then
    return response_body[1]
   return nil
function sendSetpoint(x, val)
  local path = "http://"..roth_ip.."/cgi-bin/writeVal.cgi"
  local res, code, response_headers, status = http.request( path.."?G"..x..".SollTemp="..val )
  print( "sendSetPoint: "..res.."code: "..code)
  return code
function updateRothDev(str, i)
-- Domoticz devices to update named "Gulv_Temp_xxxxx"
-- table converts Roth index to Domoticz device names
  idx = string.find(str, "RaumTemp")
  idx2 = string.find(str, "</v>", idx)
  temp = string.sub(str, idx+15, idx2-1)
--  print( "Rum temp = " .. temp )
  table.insert (commandArray, { ['UpdateDevice'] = tostring(otherdevices_idx["Gulv_Temp_"..roth2device[i]]).."|0|"..temp/100 } )
  idx = string.find(str, "SollTemp")
--  print( "Rum set temp = " .. temp )
  table.insert (commandArray, { ['SetSetPoint:'..tostring(otherdevices_idx["Gulv_Temp_"..roth2device[i].."_set"])]=tostring(temp/100) } )
--local temp = domoticz_applyXPath(response_body[1],'//body/item_list/i[contains(@n, "G1.RaumTemp")]/@v')
--domoticz_applyXPath(s,'//weatherdata/forecast/time[contains(@from,'15:00:00')]/@from')
-- Ex. response: "<body><version>1.0</version><client>App</client><file_name>Controller</file_name><item_list_size>13</item_list_size><item_list><i><n>G1.kurzID</n><v>2</v></i><i><n>G1.ownerKurzID</n><v>68</v></i><i><n>G1.RaumTemp</n><v>2172</v></i><i><n>G1.SollTemp</n><v>2100</v></i><i><n>G1.OPMode</n><v>0</v></i><i><n>G1.WeekProg</n><v>0</v></i><i><n>G1.TempSIUnit</n><v>0</v></i><i><n>G1.SollTempMaxVal</n><v>3000</v></i><i><n>G1.SollTempMinVal</n><v>500</v></i><i><n>G1.SollTempStepVal</n><v>0</v></i><i><n>G1.OPModeEna</n><v>1</v></i><i><n>G1.WeekProgEna</n><v>1</v></i><i><n>CD.rooms[1]</n><v></v></i></item_list></body>"
Here is a timed script to update all devices every 15 minutes (script_time_Roth.lua in domoticz/lua):
local m = os.date('%M')
if (m % 15 == 0) then
   -- print('The 15 minute script interval reached')
   -- Call your function here that shall run every 15 minutes
dofile("/home/hac/domoticz/scripts/lua/roth.lua")
  table.insert (commandArray, { ['Variable:RothUpdateActive'] = '1' } )
  for i=1,#roth2device do
    str = sendRequest( i-1 )  --Roth table is 0 based
    if ( str ~= nil  ) then
      print( "Roth HTTP access failed: "..i)
  table.insert (commandArray, { ['Variable:RothUpdateActive'] = '0' } )
Remember to create dummy devices and change the scripts were needed...
Hope it helps ;)
/Mikkel
buzzzy
Post by buzzzy »
Mikkel, thanks for sharing the code. Also having a Roth device, I'd like to be able to plot the temperature data. I can pull the data using
curl -s -k -X "POST" -H "Content-Type: text/xml" -H "User-Agent: SpiderControl/1.0 (iniNet-Solutions GmbH)" --data-binary $"<body><item_list><i><n>G0.RaumTemp</n></i><i><n>G1.RaumTemp</n></i><i><n>G2.RaumTemp</n></i><i><n>G3.RaumTemp</n></i><i><n>G4.RaumTemp</n></i><i><n>G5.RaumTemp</n></i></item_list></body>" "http://192.168.2.10/cgi-bin/ILRReadValues.cgi"
Now, being new to Domoticz I cannot find any complete tutorials on how to integrate the full thing, script, hooking up with devices etc in Domoticz. Any more info you can share?
