Domitech ZE27EU don't report status, and set random dim-levels
Evelen
Domoticz version: 2.4538
Post by Evelen »
Hei.
yesterday i included a Domitech ZE27EU Z-wave dimable bulb, it works, kind of, but not good.
If I change the state to off with domoticz it for no reason change the dim level after i turned the device off
2016-10-26 21:20:45	Set Level: 95 %
2016-10-26 21:20:45	Off
after this the light is in fact off, but in domoticz it is on.
if i wait a little I can turn it off in domoticz again and it will be off.
2016-10-26 21:32:58	Off
then I turn it on:
2016-10-26 21:33:45	Set Level: 6 %
2016-10-26 21:33:45	On
why 6%? i did not change that.
in domoticz it is now on at 6%, but it is realy more, (100%?)
I don't have this issue with other lights, this is the only I have of this model.
Tryed to update to last update (Version: 3.5818) and restartet domoticz, no help in that.
this is my settings for Domitech Smart LED Retrofit Kit ZE27EU:
Uten navn.png (369.94 KiB) Viewed 2504 times
I use UZB1 OpenZWave,
1.4-2215-g139c076-dirty
Evelen
Re: Domitech ZE27EU don't report status, and set random dim-levels
Post by Evelen »
bump
Evelen
Post by Evelen »
bump
ceedebee
Post by ceedebee »
Did you enabled polling? That worked for mine bulbs.
Evelen
Post by Evelen »
ceedebee wrote:Did you enabled polling? That worked for mine bulbs.
did not work for me
Evelen
Post by Evelen »
I did reset the node, then it was dead in domoticz, removed it from OpenZWave control panel.
then included it again
"2016-10-31 22:20:51.500 User: flemmingss initiated a switch command (202/30 - Level/Set Level)
2016-10-31 22:20:51.500 OpenZWave: Domoticz has send a Switch command!, Level: 99, NodeID: 27 (0x1b)"
still works the same way :(
Martinq
Domoticz version: 3.8153
Post by Martinq »
Mine has the same problem. Polling helps to let Domoticz know it's switched off, but it still will take some time to update the status.
mistermister
Post by mistermister »
I have the same trouble with the Domitech ZB22UK bulb - The status does not update in Domoticz when it's turned on/off, and it randomly sets levels when turning on/off. Anyone had any luck fixing either bulb? Turning on polling does help, but obviously this has a latency that will get worse the more bulbs I add to the system. The Set % does not seem correct, either.
Does anyone know if this is a problem with the bulb itself, or if it's Domoticz/Open Z-wave? Wanting to know whether I should return the bulb and try a different brand.
anasazi
Post by anasazi »
I also bought this lamp and experience the same issues as you.
Has anyone been able to solve this?
Enable polling might be a solution I think it should work without this enabled...
odelay
Post by odelay »
Any news on this one, did anyone got it to work with Domoticz already?
This reseller tells it is compatible https://www.robbshop.nl/domitech-e27-z- ... s-led-lamp
Padster
Post by Padster »
I have the exact same problem. Any news?
RoyT
Post by RoyT »
Nope, still the same issue here.
