using a new bootloader... currently beta
No SD card needed anymore.....
https://www.raspberrypi.org/blog/pi-3-b ... rage-boot/
Have a look at the blog pages for other boot modes.. Part 2 Ethernet
https://www.raspberrypi.org/blog/pi-3-b ... e-awesome/
Jepp...#
Note: this is still in beta testing and uses the “next” branch of the firmware. If you’re unsure about using the new boot modes, it’s probably best to wait until it is fully released.
Mass storage boot for Raspberry Pi 3 only
- tommit01
- Domoticz version: multiple
1 x RPi3
4 x RPI
3 x RPi2
1 x RPI2 + Win 10 IoT (experimental device)
2 x RPI2 Raspbian "Jessie" + Domoticz (for tenants)
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam NOIR
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
RFXtrx 433 E FW 1020
4 x RPI
3 x RPi2
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
- gizmocuz
Re: Mass storage boot for Raspberry Pi 3 only
I use BerryBoot to boot to an iSCSI drive on my synology nas, this way, it is also backuped
http://www.berryterminal.com/doku.php/berryboot
- remb0
What about performance? I use always samsung class 10 cards and from the beginning of my domoticz adventures I never had any problems.. and this way it costs an usb port.
- tommit01
@Gizmocuz But do you still need a SD Card?
@rembo I have no performance critical things.. if you use USB you should have about 30 - 40 MB/sec
Raspberry Pi3 has 4 USB Ports isn't this enough?
Advantage: I use a Sandisk Ultra Fit 16 GB 8 Euros each.... an this can be used everywhere, no SD, micro SD format issue between Raspberry 1,2 or 3...
1 x RPi3
4 x RPI
3 x RPi2
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
4 x RPI
3 x RPi2
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
- gizmocuz
@tommit01
The raspberry has a 100mb network connection, that is fast enough to write data to the sqlite database
There is a small boot delay because of the startup menu of berryboot, but thats it
- Egregius
- Domoticz version: v2024.7
I used NFS for a while on several Pi's but returned to microSD.
Found it less stable, some services stopped from time to time. Webinterface available but ssh isn't, or reversed.
It's not that hard to move a lot to tempfs, that way you'll avoid already a lot writes.
- mobisat
- Domoticz version: 2020.1
@tommit01
Did you simply follow this tut using the Domoticz image?
https://www.raspberrypi.org/documentati ... des/msd.md
Or was there more to it? My Pi 3 should arrive tomorrow
Raspberry PI 3 model B running Domoticz. RFLink, Zigbee2MQTT,
Domoticz V2020.1, utilising 1 wire DS18B20 Digital Temperature Sensors. Running Domoticz Premium android app.
- tommit01
@mobisat At this time I used a discussion thread in a forum.
but this How To Guide is much better because it is more condensed...
BR
TommIT
BR
TommIT
1 x RPi3
4 x RPI
3 x RPi2
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
4 x RPI
3 x RPi2
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
