Mass storage boot for Raspberry Pi 3 only
tommit01
Domoticz version: multiple
Post by tommit01 »
using a new bootloader... currently beta
No SD card needed anymore.....
https://www.raspberrypi.org/blog/pi-3-b ... rage-boot/
Have a look at the blog pages for other boot modes.. Part 2 Ethernet
https://www.raspberrypi.org/blog/pi-3-b ... e-awesome/
Jepp...#
Note: this is still in beta testing and uses the “next” branch of the firmware. If you’re unsure about using the new boot modes, it’s probably best to wait until it is fully released.
1 x RPi3
4 x RPI
3 x RPi2
1 x RPI2 + Win 10 IoT (experimental device)
2 x RPI2 Raspbian "Jessie" + Domoticz (for tenants)
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam NOIR
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
RFXtrx 433 E FW 1020
gizmocuz
Re: Mass storage boot for Raspberry Pi 3 only
Post by gizmocuz »
I use BerryBoot to boot to an iSCSI drive on my synology nas, this way, it is also backuped
http://www.berryterminal.com/doku.php/berryboot
remb0
Post by remb0 »
What about performance? I use always samsung class 10 cards and from the beginning of my domoticz adventures I never had any problems.. and this way it costs an usb port.
tommit01
Post by tommit01 »
@Gizmocuz But do you still need a SD Card?
@rembo I have no performance critical things.. if you use USB you should have about 30 - 40 MB/sec
Raspberry Pi3 has 4 USB Ports isn't this enough?
Advantage: I use a Sandisk Ultra Fit 16 GB 8 Euros each.... an this can be used everywhere, no SD, micro SD format issue between Raspberry 1,2 or 3...
1 x RPi3
4 x RPI
3 x RPi2
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
gizmocuz
Post by gizmocuz »
@tommit01
The raspberry has a 100mb network connection, that is fast enough to write data to the sqlite database ;)
There is a small boot delay because of the startup menu of berryboot, but thats it
Egregius
Domoticz version: v2024.7
Post by Egregius »
I used NFS for a while on several Pi's but returned to microSD.
Found it less stable, some services stopped from time to time. Webinterface available but ssh isn't, or reversed.
It's not that hard to move a lot to tempfs, that way you'll avoid already a lot writes.
mobisat
Domoticz version: 2020.1
Post by mobisat »
@tommit01
Did you simply follow this tut using the Domoticz image?
https://www.raspberrypi.org/documentati ... des/msd.md
Or was there more to it? My Pi 3 should arrive tomorrow
Raspberry PI 3 model B running Domoticz. RFLink, Zigbee2MQTT,
Domoticz V2020.1, utilising 1 wire DS18B20 Digital Temperature Sensors. Running Domoticz Premium android app.
tommit01
Post by tommit01 »
@mobisat At this time I used a discussion thread in a forum.
but this How To Guide is much better because it is more condensed...
BR
TommIT
1 x RPi3
4 x RPI
3 x RPi2
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
Users browsing this forum: eddieb, Google [Bot], imautohuttraeger, willemd and 1 guest
