Switch On/Off - Polycontrol Danalock Circle/Square
micksel
Post by micksel »
I have connected a Polycontrol Danalock Square Lock to my Domoticz and Everything works fine exakt, i seems that the lock reports the status enverted? so unlock in domotics is locked and locked in domotics is open,
I will try to change a paremeter on the lock tonight, Invert Lock Direction but don't feel right but will get back on this.
sickboyelsass
Re: Switch On/Off - Polycontrol Danalock Circle/Square
Post by sickboyelsass »
Hello Micksel,
I'm thinking of buying a Danalock as well and integrate it in Domoticz. Did you get your problem solved ?
Is everything working as expected?
micksel
Post by micksel »
Yes got it working ok but the lock doesen't update status IF you use key
elmortero
Domoticz version: 3.9639
Post by elmortero »
Hi Micksel,
How were you able to add it?
Mine is not seen. Did you move your domoticz next to the lock (as described in the manual?
Because that seems a bit complicated in my case, especially since z-wave has a much larger range that the described 1 meter in the Danalock manual.
micksel
Post by micksel »
yes, no problems there, I just set the look in correct mode, Think It was to hold the 2 button to the second beep, then took my phone, when to domo and the z-wave meny and added a secure "Product"
smedberg
Post by smedberg »
@micksel, did you find a solution to the inverted lock status?
micksel
Post by micksel »
@Smedberg I just answered your PM, but answer is yes
