I have connected a Polycontrol Danalock Square Lock to my Domoticz and Everything works fine exakt, i seems that the lock reports the status enverted? so unlock in domotics is locked and locked in domotics is open,
I will try to change a paremeter on the lock tonight, Invert Lock Direction but don't feel right but will get back on this.
Switch On/Off - Polycontrol Danalock Circle/Square
sickboyelsass
Re: Switch On/Off - Polycontrol Danalock Circle/Square
Hello Micksel,
I'm thinking of buying a Danalock as well and integrate it in Domoticz. Did you get your problem solved ?
Is everything working as expected?
micksel
Yes got it working ok but the lock doesen't update status IF you use key
elmortero
- Domoticz version: 3.9639
Hi Micksel,
How were you able to add it?
Mine is not seen. Did you move your domoticz next to the lock (as described in the manual?
Because that seems a bit complicated in my case, especially since z-wave has a much larger range that the described 1 meter in the Danalock manual.
micksel
yes, no problems there, I just set the look in correct mode, Think It was to hold the 2 button to the second beep, then took my phone, when to domo and the z-wave meny and added a secure "Product"
smedberg
@micksel, did you find a solution to the inverted lock status?
micksel
@Smedberg I just answered your PM, but answer is yes
