Problem with installation SBFspot
Henk
Post by Henk »
installed SBFspot next to mij Domoticz installation (RPI 1). All went fine following the exact instruction of https://www.domoticz.com/wiki/SMASpot_M ... n_Domoticz.
After giving the command sudo make install_sqlite a problem rizes: I got the response: make: *** No rule to make target 'install_sqlite'. Stop.
Any idea what went wrong and what I can do to complete my installation?
demandt
Domoticz version: 3.7412
Re: Problem with installation SBFspot
Post by demandt »
Old problem for you I see.
Got a solution? running into it now
Derik
Post by Derik »
When u follow the wiki..??
There is a link that is not working any more..:
https://www.codeplex.com/Download/Relea ... uild=21050
Or otherwise you have tell where you stock..
demandt
Post by demandt »
EDITED
I see what I was doing wrong. By installing SBFspot manualy I placed it directly in the SBFspot file.
SO, In my case this line:
sqlite3 SBFspot.db < /home/pi/SBFspot/SBFspot/CreateSQLiteDB.sql
Must be:
sqlite3 SBFspot.db < /home/pi/SBFspot/CreateSQLiteDB.sql
This solved my problem
Yes that's where I got stuck but I downloaded it manually and resumed with:
tar -xvf SBFspot_SRC_331_Linux_Win32.tar.gz
I replaced 312 with 331 because that is the newest release I thouhgt.
After that I resumed the Wiki with:
And now I got stuck again, see attachment.
2017-05-04 (1).png (132.26 KiB) Viewed 1233 times
