What’s wrong with my first LUA script?
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
Blockley has its limitations. I have therefore started to work with LUA.
Domoticz generates the needed user variables (copy/paste from WIKI user variables).
Knipsel 2.PNG (71.57 KiB) Viewed 939 times
Jan Jansen
Re: What’s wrong with my first LUA script?
Stupid my topic was not ready
Next blockley is not working.
Knipsel 1.PNG (47.13 KiB) Viewed 936 times
The selector only responds if the variable season is adjusted via the web interface. (as described on the forum. LUA in combination with Blockley causes problems). Therefore, a first attempt with a LUA script.
I'm looking for help because my first LUA script does not work. Who can point me in the right direction.
Thanks in advance
jvdz
Domoticz version: 4.107
Post by jvdz »
Jan,
The Set level command is wrong and should read: 'Set Level 10'.
One other thing to remember is that each time a Variable is changed via the Web interface or JSON, this script will run and set the ventilatie to the set level.
Jos
Jan Jansen
Hello Jos,
Thanks for your quick reply.
I changed the script.
Knipsel 4.PNG (95.91 KiB) Viewed 908 times
Then I clicked on the line Season (user variables) and at last I clicked the button adjust. I expected that the selector switches from "Normaal" to "Zomer" but nothing happens, even in the log.
Using blockley the selector switches as expected.
Jan
jvdz
Post by jvdz »
Have you made the LUA script with the internal Editor or is it a File in the Lua directory?
In the latter case the name of the file is important and should be: script_variable_xxxxxx.lua.
Jos
Jan Jansen
Hello Jos,
Thanks a lot.
The name of the file was the clue. Now every thing works as desired.
Jan
