I want use the gr-105n turn valves
Here the log when the hardware was added into Z-Wave network :
2016-05-05 10:58:10.164 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-05-05 10:58:10.164 (ZWave) Light/Switch (Switch)
2016-05-05 10:58:10.743 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2016-05-05 10:58:10.743 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2016-05-05 10:58:10.743 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2016-05-05 10:59:45.897 User: Admin initiated a switch command
2016-05-05 10:59:45.897 OpenZWave: Domoticz has send a Switch command!, Level: 255, NodeID: 23 (0x17)
2016-05-05 10:59:45.897 (ZWave) Light/Switch (Switch eau)
2016-05-05 10:59:55.945 OpenZWave: Received timeout notification from HomeID: 4104505456, NodeID: 23 (0x17)I use Domoticz V3.5274 with OpenZWave USB 1.4-307-g5c6f984-dirty
Can you help me ?
Thank in advance
