gr-105n work in OpenZWave Control Panel but not in Domoticz Topic is solved
narfight
Post by narfight »
I want use the gr-105n turn valves
Here the log when the hardware was added into Z-Wave network :
2016-05-05 10:58:10.164 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-05-05 10:58:10.164 (ZWave) Light/Switch (Switch)
2016-05-05 10:58:10.743 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2016-05-05 10:58:10.743 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2016-05-05 10:58:10.743 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
When I click on the Switch, I can see this in log :
2016-05-05 10:59:45.897 User: Admin initiated a switch command
2016-05-05 10:59:45.897 OpenZWave: Domoticz has send a Switch command!, Level: 255, NodeID: 23 (0x17)
2016-05-05 10:59:45.897 (ZWave) Light/Switch (Switch eau)
2016-05-05 10:59:55.945 OpenZWave: Received timeout notification from HomeID: 4104505456, NodeID: 23 (0x17)
If I tried in the OpenZWave Control Panel, its work but not in Domoticz.
I use Domoticz V3.5274 with OpenZWave USB 1.4-307-g5c6f984-dirty
Can you help me ?
Thank in advance
narfight
Re: gr-105n work in OpenZWave Control Panel but not in Domoticz
Post by narfight »
davidaguilar10
Post by davidaguilar10 »
hi narfight, i have the same problem, i have a dome valve is like the gr105n valve, this valve works in the panel openzwave but not in domoticz, can you help me?, do you solve the problem?
