Hi guys,
i have a question: with domoticz is it possible control every button of every remote control by learning or something? or is it only possible to on/off the lights? for example, i want to control RGBW leds, change channel of tv or change song on the radio and so on...(that have remote control!).
And, if it is possible... how can i do that?
Thank you in advance!
(Sorry for my english, i'm italian)
Domoticz and remote control Topic is solved
tinytiger3
jackslayter
- Domoticz version: stable
Re: Domoticz and remote control
yes with Chacon CH54761.
you learn each buttons in Dz and mane it 1A 2A ...1B....4C like the remote.
and you change the lua script to configure like you want.
http://www.domoticz.com/wiki/LUA_commands#General
--script_device_tel.lua
if (devicechanged['a1'] == 'On') then
commandArray['lamp']='On'
elseif (devicechanged['a1'] == 'Off') then
commandArray['lamp']='Off'
--if (devicechanged['a2'] == 'On') then
--commandArray['remote tv']='On'
--elseif (devicechanged['a2'] == 'Off') then
--commandArray['remote tv']='Off'
--end
if (devicechanged['a3'] == 'On') then
commandArray['rgb on']='On'
elseif (devicechanged['a3'] == 'Off') then
commandArray['rgb off']='On'
if (devicechanged['a4'] == 'On') then
commandArray['patt up']='On'
elseif (devicechanged['a4'] == 'Off') then
commandArray['patt down']='On'
if (devicechanged['b1'] == 'On') then
commandArray['start']='On'
elseif (devicechanged['b1'] == 'Off') then
commandArray['stop radio']='Off'
if (devicechanged['b2'] == 'On') then
commandArray['OpenURL']='www.yourdomain.com/api/movecamtopreset.cgi'
elseif (devicechanged['b2'] == 'Off') then
if (devicechanged['b3'] == 'On') then
elseif (devicechanged['b3'] == 'Off') then
if (devicechanged['b4'] == 'On') then
elseif (devicechanged['b4'] == 'Off') then
if (devicechanged['c1'] == 'On') then
elseif (devicechanged['c1'] == 'Off') then
if (devicechanged['c2'] == 'On') then
elseif (devicechanged['c2'] == 'Off') then
if (devicechanged['c3'] == 'On') then
elseif (devicechanged['c3'] == 'Off') then
if (devicechanged['c4'] == 'On') then
elseif (devicechanged['c4'] == 'Off') then
if (devicechanged['d1'] == 'On') then
elseif (devicechanged['d1'] == 'Off') then
if (devicechanged['d2'] == 'On') then
elseif (devicechanged['d2'] == 'Off') then
if (devicechanged['d3'] == 'On') then
elseif (devicechanged['d3'] == 'Off') then
if (devicechanged['d4'] == 'On') then
elseif (devicechanged['d4'] == 'Off') then
return commandArrayRPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
