Domoticz and remote control Topic is solved
tinytiger3
Post by tinytiger3 »
Hi guys,
i have a question: with domoticz is it possible control every button of every remote control by learning or something? or is it only possible to on/off the lights? for example, i want to control RGBW leds, change channel of tv or change song on the radio and so on...(that have remote control!).
And, if it is possible... how can i do that?
Thank you in advance!
(Sorry for my english, i'm italian)
jackslayter
Domoticz version: stable
Re: Domoticz and remote control
Post by jackslayter »
yes with Chacon CH54761.
you learn each buttons in Dz and mane it 1A 2A ...1B....4C like the remote.
and you change the lua script to configure like you want.
--script_device_tel.lua
if (devicechanged['a1'] == 'On') then
commandArray['lamp']='On'
elseif (devicechanged['a1'] == 'Off') then
commandArray['lamp']='Off'
--if (devicechanged['a2'] == 'On') then
--commandArray['remote tv']='On'
--elseif (devicechanged['a2'] == 'Off') then
--commandArray['remote tv']='Off'
--end
if (devicechanged['a3'] == 'On') then
commandArray['rgb on']='On'
elseif (devicechanged['a3'] == 'Off') then
commandArray['rgb off']='On'
if (devicechanged['a4'] == 'On') then
commandArray['patt up']='On'
elseif (devicechanged['a4'] == 'Off') then
commandArray['patt down']='On'
if (devicechanged['b1'] == 'On') then
commandArray['start']='On'
elseif (devicechanged['b1'] == 'Off') then
commandArray['stop radio']='Off'
if (devicechanged['b2'] == 'On') then
commandArray['OpenURL']='www.yourdomain.com/api/movecamtopreset.cgi'
elseif (devicechanged['b2'] == 'Off') then
if (devicechanged['b3'] == 'On') then
elseif (devicechanged['b3'] == 'Off') then
if (devicechanged['b4'] == 'On') then
elseif (devicechanged['b4'] == 'Off') then
if (devicechanged['c1'] == 'On') then
elseif (devicechanged['c1'] == 'Off') then
if (devicechanged['c2'] == 'On') then
elseif (devicechanged['c2'] == 'Off') then
if (devicechanged['c3'] == 'On') then
elseif (devicechanged['c3'] == 'Off') then
if (devicechanged['c4'] == 'On') then
elseif (devicechanged['c4'] == 'Off') then
if (devicechanged['d1'] == 'On') then
elseif (devicechanged['d1'] == 'Off') then
if (devicechanged['d2'] == 'On') then
elseif (devicechanged['d2'] == 'Off') then
if (devicechanged['d3'] == 'On') then
elseif (devicechanged['d3'] == 'Off') then
if (devicechanged['d4'] == 'On') then
elseif (devicechanged['d4'] == 'Off') then
http://www.domoticz.com/wiki/LUA_commands#General
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
