event disabled
pluggin
event disabled
Post by pluggin »
Hi everyone,
Time to time some of my events change his color to purple and stop working with the following message:
Error: EventSystem: Device no. '148' used in event 'Luz terraza_1' no longer exists, disabling event!
Error: EventSystem: Device no. '35' used in event 'Luz pasillo_2' no longer exists, disabling event!
Error: EventSystem: Device no. '74' used in event 'Alarma OFF_1' no longer exists, disabling event!
I made a research and the error is because the device disappeared but in this case its not what happend.
The devices are still there and if I reactive the events all works like always.
So I can´t find the problem.
Anyone have a clue?
regards
Razberry + 4 Eversrping HSM02 + 2 Aeotec Multi-Sensor + 1 Aeotec Micro Dimmer + 4 Aeotec Micro Smart Energy Switch, 2nd + 1 Remotec ZXT-120 + 1 Aeotec Smart Energy Monitor + 1 Everspring SE812 indoor Siren + 2 fibaro motion sensor + Aeotec water sensor
pluggin
Re: event disabled
Post by pluggin »
It's happened again!!!
For some reason same events disabled by it self.
Please i need some help i can't figure out why
Smartie
Re: event disabled
Post by Smartie »
Blocky has the Probmel too.
Samme Problem
fsp68
Domoticz version: V3.4834
Re: event disabled
Post by fsp68 »
Also have the same problem. I have made some dummy switches, so these can't disappear. I created a blocky, when switch-1=on or switch-2=on then set switch-3=on. Also created another blocky, switch-1=off and switch-2=off then set switch-3=off.
For some reason i get this error in the log:
Error: EventSystem: Device no. '168' used in event 'GastenAanwezig_1' no longer exists, disabling event!
Any ideas?
Raspberry Pi2, Razberry, Fibaro switches, RFXcom433, KiKa
Domosapiens
Domoticz version: V3.5981
Re: event disabled
Post by Domosapiens »
I have seen, that after creating a dummy switch, Domoticz has to be restarted, to be able to use that dummy switch.
Don't know why.
But .. I'm running currently an old version !
fsp68
Re: event disabled
Post by fsp68 »
Rebooting domoticz seems to solve the problem. Switches responding as should now. Running Domoticz version 3.4834 on a Pi2.
