How does push work Topic is solved
Erikswed
How does push work
Post by Erikswed »
Hello everybody
Just saw this today and try to understand how does work. Using Domoticz on a raspberry pie inside an RV mobile home, how can my android phone get push notification from the the raspberry? Where is the server that the android phone connect to?
I read the forum and the wiki page but can't quite find the description for this how it works
gizmocuz
Re: How does push work
Post by gizmocuz »
http://www.notifymyandroid.com/
(There have to be internet connection on the RPi)
Erikswed
Post by Erikswed »
Thanks for the fast reply i really like this forum
Erikswed
Post by Erikswed »
Was thinking about nma vs gcm. Does this mean that i cannot use Domoticz in the RV home if i don't also use NMA? The RV has internet connection through mobile phone operator.
I still don't understand how incoming outgoing communication is able to happen since there is no way to connect to a mobile phone. The IP address for the mobile phone is not accessible. Where is the relay server?
I understand that NMA has its own server. Does the Domoticz backend also use the NMA server?
gizmocuz
Post by gizmocuz »
Yes, when we need to send a 'notification', like 'Temperature above 27.0 degrees', we deliver this message to the NMA server on the internet.
On the Android phone, you need to install NMA (i think you have to pay 1 time, 2 euro ?), the NMA server (from the internet) pushes this message to the NMA application on your phone
burton666
Post by burton666 »
Is it possible to use several api´s for notification? I want to use pushbullet and if for example some plant needs watering I want to send a notification to both me and my girlfriend? Or is there some other way to get around that? (I tried creating a new channel in pushbullet and so we both could subscribe to that channel, but then i realized that I cant send from domotics to that channel.)
Robert
Post by Robert »
?? What's wrong these days with normal English:-)
Verzonden vanaf mijn iPad met Tapatalk
Ron
Domoticz version: 2.2284
Post by Ron »
Als je zelf dit dan ook even vertaald of verwijderd:...
Verzonden vanaf mijn iPad met Tapatalk:
