Floorplan dashboard fullscreen
d3rax
Post by d3rax »
I've got a question about the dashboard. I have my floorplan displayed on my dashboard. When I double click on the floorplan, the 'fullscreen' version gets activated by hiding the menubar.
I would like to have a url that directly shows the dashboard without the menubar, so without having to double click the floorplan (i want to use the floorplan in Imperihome). Is this possible?
Best regards!
Dnpwwo
Re: Floorplan dashboard fullscreen
Post by Dnpwwo »
Currently there isn't.
If someone updated FloorplanController.js so the init function looked like this and submitted a patch:
		function init()
			try {
				$scope.MakeGlobalConfig();
				ShowFloorplans();
				if (window.location.href.search("fullscreen")>0) {
					$('#copyright').css({display:'none'});
					$('.navbar').css({display:'none'});
					$( "#fpwrapper" ).css({position:'absolute', top:0, left:0}) .attr('fullscreen','true');
			catch(err) {
				generate_noty('error', '<b>Error Initialising Page</b><br>'+err, false);
then a URL like [url]http://<domoticz%20address>:8080/#/Floorplans?fullscreen[/url] would work.
I can't do it at present due to my main server suffering a hardware failure which has broken my setup.
d3rax
Post by d3rax »
Hopefully it will be implemented in the future....
Egregius
Domoticz version: v2024.7
Post by Egregius »
You can also create your own floorplan. Perfectly made just for you.
Have a look at https://github.com/Egregius/PHP-Custom- ... r-Domoticz to get started.
Dnpwwo
Post by Dnpwwo »
This functionality has been added and should be in the next beta :)
Let me know if there are any issues with it
DeepB
Post by DeepB »
Can you let me know in which version that was implemented? And how to use it?
thank you
Daniel
Dnpwwo
Post by Dnpwwo »
Just add '?fullscreen' to the end of the URL you were using ([url]http://<domoticz%20address>:8080/#/Floorplans?fullscreen[/url]). It would have been in the beta version since mid-may.
If a stable version has been release since then it will be in that as well.
