I've got a question about the dashboard. I have my floorplan displayed on my dashboard. When I double click on the floorplan, the 'fullscreen' version gets activated by hiding the menubar.
I would like to have a url that directly shows the dashboard without the menubar, so without having to double click the floorplan (i want to use the floorplan in Imperihome). Is this possible?
Best regards!
Floorplan dashboard fullscreen
- Dnpwwo
Re: Floorplan dashboard fullscreen
Currently there isn't.
If someone updated FloorplanController.js so the init function looked like this and submitted a patch: then a URL like [url]http://<domoticz%20address>:8080/#/Floorplans?fullscreen[/url] would work.
I can't do it at present due to my main server suffering a hardware failure which has broken my setup.
function init()
try {
$scope.MakeGlobalConfig();
ShowFloorplans();
if (window.location.href.search("fullscreen")>0) {
$('#copyright').css({display:'none'});
$('.navbar').css({display:'none'});
$( "#fpwrapper" ).css({position:'absolute', top:0, left:0}) .attr('fullscreen','true');
catch(err) {
generate_noty('error', '<b>Error Initialising Page</b><br>'+err, false);
Hopefully it will be implemented in the future....
- Egregius
- Domoticz version: v2024.7
You can also create your own floorplan. Perfectly made just for you.
Have a look at https://github.com/Egregius/PHP-Custom- ... r-Domoticz to get started.
- Dnpwwo
This functionality has been added and should be in the next beta
Let me know if there are any issues with it
DeepB
Can you let me know in which version that was implemented? And how to use it?
thank you
Daniel
thank you
Daniel
- Dnpwwo
Just add '?fullscreen' to the end of the URL you were using ([url]http://<domoticz%20address>:8080/#/Floorplans?fullscreen[/url]). It would have been in the beta version since mid-may.
If a stable version has been release since then it will be in that as well.
