flat-blue - new metro look theme
SchattenMann
Post by SchattenMann »
Hey,
I've got tired of the boring "dark" UI and so I've spent some time creating a simple flat design for Domoticz.
It's not perfect and there's plenty of space for improvements but case anyone is interested: https://github.com/jonferreira/domoticz-flat-blue-theme
remb0
Re: flat-blue - new metro look theme
Post by remb0 »
Very nice.!! Thanks for sharing.
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
Thank you. I Will try it.
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
MikeF
Domoticz version: V2022.2
Post by MikeF »
This isn't working for me. I copied the folder into domoticz/www/styles, and renamed it flat-blue. In Setup>Settings, flat-blue appears as a Theme, but selecting it doesn't change the UI. I've refreshed the browser cache and restarted Domoticz, to no avail.
Any clues?
SchattenMann
sounds like cache issues to me, I always have the same problem when changing themes.
if you're using Firefox you'll need to delete the offline web content (tools - options - advanced) and clear firefox cache half a dozen times
MikeF
Post by MikeF »
Got it - looks excellent - well done!
Derik
Post by Derik »
Nice looks great..
is there perhaps a option to use all this themes like the icons...
A sideload... ?
SchattenMann
Derik wrote:Nice looks great..
A sideload... ?
not sure I understood what you mean
Derik
Post by Derik »
A sideload... ?
In Domoticz there is a option to load custom icons....
I should be nice that this option works with the different themes...
SchattenMann
you can use "custom icons" with "custom themes"...that's what I'm doing right now
Patrick
Domoticz version: 3.5877
Post by Patrick »
Very nice theme!
Just 1 issue, on my iPad the texts are placed over the icons.
On my computer everything is ok.
Could you please look into this?
SchattenMann
I've jut noticed the same thing is happening to me, guess there must be some other CSS for mobile version...I'll try to take a loom and find it ASAP
SchattenMann
Did some improvements today but still haven't figured out why that's happening in iOS Safari, seems to be ignoring padding-top for some reason
Albsucher
Post by Albsucher »
Any news up here?
I would like to use this skin for myself, too. Because it is not that dark as the others but looks more clean and fresh to me.
Unfortunately it still looks weitd on my iPad. Would be great if this could get fixed.
I am no programmer or css expert so i am sorry i cannot help here.
Thanks for all your time for this theme!
SchattenMann
I wasn't able to track down the problem or why Safari seems to be ignoring some CSS
I'll probably need help from a "proper designer" :-)
piokuc
Post by piokuc »
Very good theme :)
Very nice icon for tabs. Did you plan add this theme to official Domoticz to be in image and will be update with update Domoticz ? Maybe think about it...
SchattenMann
have no problems doing that although there's still a few known bugs to fix
piokuc
Post by piokuc »
And did you planin correct oversize slider for dimmer ?
Ok i am waiting to add this to image domoticz and will be update with update Domoticz :)
But icon for tabs should be use in official theme in Domoticz. Looks very nice and are very light.
But when you are planing correction your theme from bugs ?
SchattenMann
hmm that should be fixed on latest release, looks ok to me!
only thing pending - that I know of - is related to padding on mobile (iPad safari) view
