Battery level monitoring = default Domoticz functionality?
Awst6000
Post by Awst6000 »
Can "battery level monitoring" become default Domoticz functionality?
I mean getting an email when the battery level runs below a certain threshold.
I found some scripts that do this, but they are all for Raspberry Pi. Not for Windows.
To make this default Domoticz functionality, it helps reducing scripts.
Txs.
P.S. I hope that this thread is in the right place.
Westcott
Re: Battery level monitoring = default Domoticz functionality?
Post by Westcott »
While we are waiting, I'm developing a Lua script that uses Json to get battery levels, and display the values in dummy devices.
Egregius
Domoticz version: v2024.7
Post by Egregius »
What's wrong with current one?
The only problem I see is that some devices don't update their battery level correctly.
For example: I have 6 Fibaro Smoke detectors. They're all installed in a period of maximum 2 months. Battery levels are 3 x 100%, 70%, 10% and none.
I don't believe in those numbers anymore so I created something to notify me if some of those didn't update temperature for 4 hours.
Awst6000
Post by Awst6000 »
@Westcott: I'm curious :-)
@Egregius: I found the 'Battery low level'. (I must have overlooked it).
I just set it to 25% instead of the default of 0%
Do I get emails when batteries run low?
Txs.
Egregius
Post by Egregius »
I guess depending on your notification settings.
I don't have mail enabled but receive notification on telegram.
Awst6000
Post by Awst6000 »
I do have email notifications enabled.
I'll test with it these days.
Thanks so far.
Update:
I checked the devices that have a percentage in the device list.
Among them are Cresta TX320 temperature/humidity sensors, but they all show 100%.
Unfortunately the Kaku AMST-606 magnetic door contacts and the Marmitek MS13 don't transmit their battery status.
So no luck for me :-)
