Good Chinese remote + relay
Westcott
Post by Westcott »
I've just received one of these -
http://www.ebay.co.uk/itm/231634367865? ... EBIDX%3AIT
and can confirm that it worked immediately with Rfxcom as Lighting4 PT2262
The remote created 2 devices: one for 'ON' and the other for ...... 'OFF'.
I chose the 5V version so I can run it from USB power.
deennoo
Re: Good Chinese remote + relay
Post by deennoo »
Thx !
http://domo-attitude.fr
ricorico94
Post by ricorico94 »
What is the 'receive distance" of the remote ? (ie is it still received by your Domoticz/RFXCOM far away from the remote control ?)
Also, do you know if either the relay or the remote can be de-coupled, so that they can work independetely ? (so far the remote directly triggers the relay, correct ? I'd like to have the relay and the remote communicating separately with Domoticz)
br,
Ricorico94
Westcott
Post by Westcott »
Hi RiciRico94,
Sorry, I haven't tried any range tests, but the range via the RFXcom must be greater due to its higher-gain aerial/antenna.
I believe that they are factory paired, but again have not yet tested that.
If the relay and the remote are both within range of the RFXcom, but out of range between them, then they are effectively decoupled.
