Math Libraries for Blockly
manwe
Post by manwe »
It would be very nice to have some mathematical calculations in Blockly.
This is used in lots of other Blockly Examples but just outside of Domoticz
https://developers.google.com/blockly/
https://blockly-demo.appspot.com/static ... index.html
https://blockly-games.appspot.com/
For the beginning I wouldn't need some very complex Calculations but even easy stuff like "Increase User Variable", "Check for Temperature + x", "Multiply Numbers to convert units" would be very useful ;)
manjh
Domoticz version: 2025.2
Re: Math Libraries for Blockly
Post by manjh »
I second that. Would be great for my "intelligent dimmer", which is controlled by the value of a user variable.
Example:
0 = off
1 = 25%
2 = 50%
3 = 75%
4 = full
A motion sensor would set the variable to 4, and start a timer.
Timer runs out: decrement variable and restart timer.
Variable reaches 0: dimmer to off, and cancel timer.
Hans
gizmocuz
Post by gizmocuz »
Great idea !
Please submit a git pull request with the needed changes
Marci
Domoticz version: 3.8153
Post by Marci »
In progress - will issue pull request once finished.
velkrosmaak
Post by velkrosmaak »
Can't wait for this - going to use it to compare the current energy usage with that from 5 minutes ago, and notify me if something has stopped using energy (such as the dishwasher) 8-)
CherAlban
Post by CherAlban »
is there any news on this topic? I would also highly appreciate basic math blocks.
CherAlban
michaldobrotka
Post by michaldobrotka »
+1
Yes please math in Blockly
Domoticz on Raspi 3 and slave on ZeroW (running only with Broadlink plugin), Serial Mysensors GW on Arduino nano, Broadlink RM2, Rehau CO2 USB Stick, RF link 433 MHz, 2x Amazon Echo Dot (Controlicz), ESP2866 witk Espeasy, Sonoff
BigOpus
Domoticz version: 4.97
Post by BigOpus »
some news about this very helpful feature? I need somethig like.
e.g. if "actual temp" - 2 = "set temp" then...
tuxmartin
Post by tuxmartin »
any news about this feature?
Try it: https://developers.google.com/blockly/
Patricen
Domoticz version: Beta rel
Post by Patricen »
Up ;)
TSkar
Domoticz version: 2.13055
Post by TSkar »
Did this suggestion get dropped, or are there any kind of progress on this?
Even basic math like addition and subtraction would help a lot.
Alain
Domoticz version: 2022.1
Post by Alain »
I don't think there is much development in the Blockly side of things. Math functions would make life a little easier, for sure.
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
jvm1000
Post by jvm1000 »
+1
