Auto clear log (or limit) of alert sensor.
YellowSky
- Domoticz version: Last
Hi everyone,
i use some alert sensor to inform me:
The level of water inside tank
The rain alert from viewtopic.php?f=38&t=5903
But one problem is the size of log.
I would like to know if it is possible to clear log automatically. Or limit entry number of these log.
Thank you
Thank you
YellowSky
Re: Auto clear log (or limit) of alert sensor.
I always look after this json command.
Is there anybody to help me?
- Egregius
- Domoticz version: v2024.7
Why not delete it from database directly?
YellowSky
Of course it is an alternative (how to do that with domoticz running?) but the most common use for me is to perform this action each dayfor selected "sensor"
- Egregius
I run this script every night:
First part: remove all data from devices that are not used. Yes, also unused devices store data in the database.
Second part: remove all data from devices with idx 6,9 or 10 as I don't care about them.
Last part: vacuum the database to free unused space.
This script runs already a year, never had a problem with it.
<?php
$db = new SQLite3('/volume1/@appstore/domoticz/var/domoticz.db');
$tables = array( 'LightingLog',
'MultiMeter',
'MultiMeter_Calendar',
'Meter',
'Meter_Calendar',
'Percentage',
'Percentage_Calendar',
'Rain',
'Rain_Calendar',
'Temperature',
'Temperature_Calendar',
'UV',
'UV_Calendar',
'Wind',
'Wind_Calendar');
foreach($tables as $table){
$query=$db->exec("DELETE FROM $table WHERE DeviceRowID not in (select ID from DeviceStatus where Used = 1)");
if ($query){
$rows = $db->changes();
if($rows>0)
echo $rows." rows removed from $table<br/>";
$query=$db->exec("DELETE FROM LightingLog WHERE DeviceRowID in (6,9,10)");
if ($query){
if($rows>0)
echo $rows." rows removed from LightingLog<br/>";
$sql = 'VACUUM;';
if(!$result = $db->exec($sql))
die('There was an error running the query [' . $db->error . ']'); Second part: remove all data from devices with idx 6,9 or 10 as I don't care about them.
YellowSky
Wow, thank you a lot.
I guess domoticz has to be stop before to perform that?
YellowSky
Ok, thanks.
In my case, it does not work (unable to open it) (i think because php don't have the permission to access to the domoticz.db
mayyam
- Domoticz version: 4.11333
I'm getting errors:Egregius wrote:I run this script every night:First part: remove all data from devices that are not used. Yes, also unused devices store data in the database.Code: Select all
<?php $db = new SQLite3('/volume1/@appstore/domoticz/var/domoticz.db'); $tables = array( 'LightingLog', 'MultiMeter', 'MultiMeter_Calendar', 'Meter', 'Meter_Calendar', 'Percentage', 'Percentage_Calendar', 'Rain', 'Rain_Calendar', 'Temperature', 'Temperature_Calendar', 'UV', 'UV_Calendar', 'Wind', 'Wind_Calendar'); foreach($tables as $table){ $query=$db->exec("DELETE FROM $table WHERE DeviceRowID not in (select ID from DeviceStatus where Used = 1)"); if ($query){ $rows = $db->changes(); if($rows>0) echo $rows." rows removed from $table<br/>"; } } $query=$db->exec("DELETE FROM LightingLog WHERE DeviceRowID in (6,9,10)"); if ($query){ $rows = $db->changes(); if($rows>0) echo $rows." rows removed from LightingLog<br/>"; } $sql = 'VACUUM;'; if(!$result = $db->exec($sql)) die('There was an error running the query [' . $db->error . ']');
pi@domoticz:~ $ /home/pi/domoticz/scripts/php/clean_log_database.php
/home/pi/domoticz/scripts/php/clean_log_database.php: line 1: ?php: No such file or directory
/home/pi/domoticz/scripts/php/clean_log_database.php: line 2: syntax error near unexpected token `('
/home/pi/domoticz/scripts/php/clean_log_database.php: line 2: `$db = new SQLite3('/home/pi/domoticz/domoticz.db');'
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
- 2x Xiaomi Gateway
- Egregius
Are you sure you have php and php-cli installed?
There are different ways to run a php script.
a) script starts with just <?php: host it on a webserver and use curl.
b) start the script by /usr/bin/php /path/to/script.php
c) start the script with #!/usr/bin/php before the <?php
mayyam
Thanks for the asnwer.
Yes, i have the apache and php installed:
Using second method:
- just host on the webserwer results in blank page.
And there is the error in apche error.log:
EDIT:
The problem was:
sudo nano /etc/apache2/apache2.conf
insert the line - ServerName myserver.mydomain.com - with my name of the server.
Then - apachectl configtest
Then - sudo /usr/bin/php /home/pi/domoticz/scripts/php/clean_log_database.php
Bless You @Egregius
pi@domoticz:~ $ apachectl -V
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
Server version: Apache/2.4.10 (Raspbian)
Server built: Sep 17 2016 16:40:43
Server's Module Magic Number: 20120211:37
Server loaded: APR 1.5.1, APR-UTIL 1.5.4
Compiled using: APR 1.5.1, APR-UTIL 1.5.4
Architecture: 32-bit
Server MPM: prefork
threaded: no
forked: yes (variable process count)
Server compiled with....
-D APR_HAS_SENDFILE
-D APR_HAS_MMAP
-D APR_HAVE_IPV6 (IPv4-mapped addresses enabled)
-D APR_USE_SYSVSEM_SERIALIZE
-D APR_USE_PTHREAD_SERIALIZE
-D SINGLE_LISTEN_UNSERIALIZED_ACCEPT
-D APR_HAS_OTHER_CHILD
-D AP_HAVE_RELIABLE_PIPED_LOGS
-D DYNAMIC_MODULE_LIMIT=256
-D HTTPD_ROOT="/etc/apache2"
-D SUEXEC_BIN="/usr/lib/apache2/suexec"
-D DEFAULT_PIDLOG="/var/run/apache2.pid"
-D DEFAULT_SCOREBOARD="logs/apache_runtime_status"
-D DEFAULT_ERRORLOG="logs/error_log"
-D AP_TYPES_CONFIG_FILE="mime.types"
-D SERVER_CONFIG_FILE="apache2.conf"
pi@domoticz:~ $ php -v
PHP 5.6.29-0+deb8u1 (cli) (built: Dec 17 2016 06:04:43)
Copyright (c) 1997-2016 The PHP Group
Zend Engine v2.6.0, Copyright (c) 1998-2016 Zend Technologies
with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2016, by Zend Technologies
pi@domoticz:~/domoticz $ sudo apt-get install php5-cli
Reading package lists... Done
Building dependency tree
Reading state information... Done
php5-cli is already the newest version.
php5-cli set to manually installed.
pi@domoticz:~ $ sqlite3
SQLite version 3.8.7.1 2014-10-29 13:59:56
Enter ".help" for usage hints.
Connected to a transient in-memory database.
Use ".open FILENAME" to reopen on a persistent database.
sqlite>
Using Third method (where first line= #!/usr/bin/php<?php):pi@domoticz:~ $ sudo /usr/bin/php /home/pi/domoticz/scripts/php/clean_log_database.php
PHP Fatal error: Class 'SQLite3' not found in /home/pi/domoticz/scripts/php/clean_log_database.php on line 2
Using Third method (where first line= #!/usr/bin/php <?php):sudo /home/pi/domoticz/scripts/php/clean_log_database.php
sudo: unable to execute /home/pi/domoticz/scripts/php/clean_log_database.php: No such file or directory
First method i don't understandpi@domoticz:~ $ sudo /home/pi/domoticz/scripts/php/clean_log_database.php
Could not open input file: <?php
And Domoticz directory looks like:[Thu Mar 16 12:36:05.184927 2017] [:error] [pid 745] [client 192.168.12.20:59203] PHP Fatal error: Class 'SQLite3' not found in /var/www/html/clean_log_database.php on line 2
pi@domoticz:~/domoticz/scripts/php $ cd /home/pi/domoticz
pi@domoticz:~/domoticz $ ls
backups Config domocookie.txt domoticz domoticz.db domoticz.db-shm domoticz.db-wal domoticz.sh History.txt License.txt python-broadlink scripts server_cert.pem tmp updatebeta updaterelease www
EDIT:
The problem was:
I had to:pi@domoticz:~/domoticz $ sudo apache2ctl configtest
Syntax OK
Then - sudo service apache2 restartpi@domoticz:~/domoticz $ apachectl configtest
Syntax OK
Now its working102 rows removed from LightingLog<br/>92 rows removed from MultiMeter_Calendar<br/>91 rows removed from Meter<br/>288 rows removed from Rain<br/>58 rows removed from Rain_Calendar<br/>92 rows removed from UV<br/>55 rows removed from UV_Calendar<br/>32552 rows removed from LightingLog<br/>pi@domoticz:~/domoticz $
Bless You @Egregius
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
- Domoticz version: 2025.1
What is wrong with the log history settings? Better use these than manual srcew up your database.....
https://www.domoticz.com/wiki/Applicati ... og_History
In what table are those camera log rows? If they are in Lightinglog then they will be purged after the light/switch setting days, default 30 days. So you can decrease that setting and check what changed.
