Auto clear log (or limit) of alert sensor.
YellowSky
Domoticz version: Last
Post by YellowSky »
Hi everyone,
i use some alert sensor to inform me:
The level of water inside tank
The rain alert from viewtopic.php?f=38&t=5903
But one problem is the size of log.
I would like to know if it is possible to clear log automatically. Or limit entry number of these log.
Thank you
YellowSky
Re: Auto clear log (or limit) of alert sensor.
Post by YellowSky »
I always look after this json command.
Is there anybody to help me?
Egregius
Domoticz version: v2024.7
Post by Egregius »
Why not delete it from database directly?
YellowSky
Post by YellowSky »
Of course it is an alternative (how to do that with domoticz running?) but the most common use for me is to perform this action each dayfor selected "sensor"
Egregius
Post by Egregius »
I run this script every night:
<?php
$db = new SQLite3('/volume1/@appstore/domoticz/var/domoticz.db');
$tables = array( 'LightingLog',
                'MultiMeter',
                'MultiMeter_Calendar',
                'Meter',
                'Meter_Calendar',
                'Percentage',
                'Percentage_Calendar',
                'Rain',
                'Rain_Calendar',
                'Temperature',
                'Temperature_Calendar',
                'UV',
                'UV_Calendar',
                'Wind',
                'Wind_Calendar');
foreach($tables as $table){
    $query=$db->exec("DELETE FROM $table WHERE DeviceRowID not in (select ID from DeviceStatus where Used = 1)");
    if ($query){
        $rows = $db->changes();
        if($rows>0)
            echo $rows." rows removed from $table<br/>";
$query=$db->exec("DELETE FROM LightingLog WHERE DeviceRowID in (6,9,10)");
    if ($query){
        if($rows>0)
            echo $rows." rows removed from LightingLog<br/>";
$sql = 'VACUUM;';
if(!$result = $db->exec($sql))
    die('There was an error running the query [' . $db->error . ']');
First part: remove all data from devices that are not used. Yes, also unused devices store data in the database.
Second part: remove all data from devices with idx 6,9 or 10 as I don't care about them.
Last part: vacuum the database to free unused space.
This script runs already a year, never had a problem with it.
YellowSky
Post by YellowSky »
Wow, thank you a lot.
I guess domoticz has to be stop before to perform that?
Egregius
Post by Egregius »
I don't stop it. :twisted:
YellowSky
Post by YellowSky »
Ok, thanks.
In my case, it does not work (unable to open it) (i think because php don't have the permission to access to the domoticz.db :-( )
mayyam
Domoticz version: 4.11333
Post by mayyam »
Egregius wrote:I run this script every night:
<?php
                'MultiMeter',
                'Meter',
                'Meter_Calendar',
                'Percentage',
                'Rain',
                'Rain_Calendar',
                'Temperature',
                'UV',
                'UV_Calendar',
                'Wind',
                'Wind_Calendar');
    if ($query){
        if($rows>0)
    if ($query){
        if($rows>0)
$sql = 'VACUUM;';
I'm getting errors:
pi@domoticz:~ $ /home/pi/domoticz/scripts/php/clean_log_database.php
/home/pi/domoticz/scripts/php/clean_log_database.php: line 1: ?php: No such file or directory
/home/pi/domoticz/scripts/php/clean_log_database.php: line 2: syntax error near unexpected token `('
/home/pi/domoticz/scripts/php/clean_log_database.php: line 2: `$db = new SQLite3('/home/pi/domoticz/domoticz.db');'
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
Egregius
Post by Egregius »
Are you sure you have php and php-cli installed?
There are different ways to run a php script.
a) script starts with just <?php: host it on a webserver and use curl.
b) start the script by /usr/bin/php /path/to/script.php
c) start the script with #!/usr/bin/php before the <?php
mayyam
Post by mayyam »
Thanks for the asnwer.
Yes, i have the apache and php installed:
pi@domoticz:~ $ apachectl -V
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
Server version: Apache/2.4.10 (Raspbian)
Server built: Sep 17 2016 16:40:43
Server's Module Magic Number: 20120211:37
Server loaded: APR 1.5.1, APR-UTIL 1.5.4
Compiled using: APR 1.5.1, APR-UTIL 1.5.4
Architecture: 32-bit
Server MPM: prefork
threaded: no
forked: yes (variable process count)
Server compiled with....
-D APR_HAS_SENDFILE
-D APR_HAS_MMAP
-D APR_HAVE_IPV6 (IPv4-mapped addresses enabled)
-D APR_USE_SYSVSEM_SERIALIZE
-D APR_USE_PTHREAD_SERIALIZE
-D SINGLE_LISTEN_UNSERIALIZED_ACCEPT
-D APR_HAS_OTHER_CHILD
-D AP_HAVE_RELIABLE_PIPED_LOGS
-D DYNAMIC_MODULE_LIMIT=256
-D HTTPD_ROOT="/etc/apache2"
-D SUEXEC_BIN="/usr/lib/apache2/suexec"
-D DEFAULT_PIDLOG="/var/run/apache2.pid"
-D DEFAULT_SCOREBOARD="logs/apache_runtime_status"
-D DEFAULT_ERRORLOG="logs/error_log"
-D AP_TYPES_CONFIG_FILE="mime.types"
-D SERVER_CONFIG_FILE="apache2.conf"
pi@domoticz:~ $ php -v
PHP 5.6.29-0+deb8u1 (cli) (built: Dec 17 2016 06:04:43)
Copyright (c) 1997-2016 The PHP Group
Zend Engine v2.6.0, Copyright (c) 1998-2016 Zend Technologies
with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2016, by Zend Technologies
pi@domoticz:~/domoticz $ sudo apt-get install php5-cli
Reading package lists... Done
Building dependency tree
Reading state information... Done
php5-cli is already the newest version.
php5-cli set to manually installed.
pi@domoticz:~ $ sqlite3
SQLite version 3.8.7.1 2014-10-29 13:59:56
Enter ".help" for usage hints.
Connected to a transient in-memory database.
Use ".open FILENAME" to reopen on a persistent database.
sqlite>
Using second method:
pi@domoticz:~ $ sudo /usr/bin/php /home/pi/domoticz/scripts/php/clean_log_database.php
PHP Fatal error: Class 'SQLite3' not found in /home/pi/domoticz/scripts/php/clean_log_database.php on line 2
Using Third method (where first line= #!/usr/bin/php<?php):
sudo /home/pi/domoticz/scripts/php/clean_log_database.php
sudo: unable to execute /home/pi/domoticz/scripts/php/clean_log_database.php: No such file or directory
Using Third method (where first line= #!/usr/bin/php <?php):
pi@domoticz:~ $ sudo /home/pi/domoticz/scripts/php/clean_log_database.php
Could not open input file: <?php
First method i don't understand :( - just host on the webserwer results in blank page.
And there is the error in apche error.log:
[Thu Mar 16 12:36:05.184927 2017] [:error] [pid 745] [client 192.168.12.20:59203] PHP Fatal error: Class 'SQLite3' not found in /var/www/html/clean_log_database.php on line 2
And Domoticz directory looks like:
pi@domoticz:~/domoticz/scripts/php $ cd /home/pi/domoticz
pi@domoticz:~/domoticz $ ls
backups Config domocookie.txt domoticz domoticz.db domoticz.db-shm domoticz.db-wal domoticz.sh History.txt License.txt python-broadlink scripts server_cert.pem tmp updatebeta updaterelease www
EDIT:
The problem was:
pi@domoticz:~/domoticz $ sudo apache2ctl configtest
Syntax OK
I had to:
sudo nano /etc/apache2/apache2.conf
insert the line - ServerName myserver.mydomain.com - with my name of the server.
Then - apachectl configtest
pi@domoticz:~/domoticz $ apachectl configtest
Syntax OK
Then - sudo service apache2 restart
Then - sudo /usr/bin/php /home/pi/domoticz/scripts/php/clean_log_database.php
102 rows removed from LightingLog<br/>92 rows removed from MultiMeter_Calendar<br/>91 rows removed from Meter<br/>288 rows removed from Rain<br/>58 rows removed from Rain_Calendar<br/>92 rows removed from UV<br/>55 rows removed from UV_Calendar<br/>32552 rows removed from LightingLog<br/>pi@domoticz:~/domoticz $
Now its working :)
Bless You @Egregius
_______________
- 2x Xiaomi Gateway
Domoticz version: 2025.1
What is wrong with the log history settings? Better use these than manual srcew up your database..... ;)
https://www.domoticz.com/wiki/Applicati ... og_History
In what table are those camera log rows? If they are in Lightinglog then they will be purged after the light/switch setting days, default 30 days. So you can decrease that setting and check what changed.
Users browsing this forum: eddieb and 1 guest
