Hi, looking for a zwave temp sensor for £10.
Most zwave devices like fibaro, aeon ..etc are all in the range of £30 or higher.
Any ideas or suggestions will be much appreciated.
Many thanks,
-krish
zwave-temp-sensor for £10?
Evelen
- Domoticz version: 2.4538
Re: zwave-temp-sensor for £10?
impossible, go for 443 MHz sensors on temperature
kman
Can you please provide me with more info 443 MHz sensors. I am new to all of this. Many thanks!
mischa
- Domoticz version: 3.8872
@Kman on this website you will find all the information for mysensors
http://www.mysensors.org/
Pi 2 - Pi 1 - Razzbery 2.0 - Fibaro FGD-211 - Fibaro FGD-212 - Fibaro FGRGBWM-441 (RGBW Module) - Fibaro FGBS321 (Universal Switch) - FGWPF-102 - TBK Home TZ67-G - Synology DS1515+ - Esp Easy (with wemos D1 mini)
kman
Also, if am using 433 MHz sensors, how do I integrate that with Domoticz? is there another library like openzwave which could be used?
Evelen
You need one of these:kman wrote:Also, if am using 433 MHz sensors, how do I integrate that with Domoticz? is there another library like openzwave which could be used?
http://www.rfxcom.com/store/Transceivers/14103
All devices will come under "Devices",
Stuff that works with it:
https://www.domoticz.com/wiki/Hardware
I use this:
http://www.ebay.com/itm/261788376051
kman
@Evelen - thanks for the info.
I had a few additional questions...
I am planning to use RPi with "RFXtrx433E USB 433.92MHz Transceiver"
If I already have domoticz installed on RPi then, all that is required to be done from Linux per se is to install "Mono" and use it to run RFXflash.exe program when I need to upgrade the firmware on RFXtrx433E? Do I need to upgrade the firmware on RFXtrx433E when I receive it?
Aside from that is it safe to assume that once I have RPi connected(usb) to RFXtrx433E with Domoticz running on RPi, there is no additional sw installation required on RPi?
How does one enable/disable protocols on RFXtrx433E - is that done via domoticz?
Many thanks.
Many thanks.
manwe
If you use switches or dimmers from qubino you can connect an temperature sensor in this price range to the switch.
The big advantage is that it is powered. I hate to change (and pay) batteries
kman
Cheap(£10) temp/Humidity sensor - for RFXtrx433E
I found Cresta TX-320 - but it doesn't seem to be available in the UK and shipment costs from Netherlands is around euro 19.
Any suggestions on cheap Temp/Humidity sensor under £10 - compatible with RFXtrx433E/Domoticz?
