zwave-temp-sensor for £10?
kman
Post by kman »
Hi, looking for a zwave temp sensor for £10.
Most zwave devices like fibaro, aeon ..etc are all in the range of £30 or higher.
Any ideas or suggestions will be much appreciated.
Many thanks,
-krish
Evelen
Domoticz version: 2.4538
Re: zwave-temp-sensor for £10?
Post by Evelen »
impossible, go for 443 MHz sensors on temperature
kman
Post by kman »
Can you please provide me with more info 443 MHz sensors. I am new to all of this. Many thanks!
mischa
Domoticz version: 3.8872
Post by mischa »
@Kman on this website you will find all the information for mysensors
http://www.mysensors.org/
Pi 2 - Pi 1 - Razzbery 2.0 - Fibaro FGD-211 - Fibaro FGD-212 - Fibaro FGRGBWM-441 (RGBW Module) - Fibaro FGBS321 (Universal Switch) - FGWPF-102 - TBK Home TZ67-G - Synology DS1515+ - Esp Easy (with wemos D1 mini)
kman
Post by kman »
Also, if am using 433 MHz sensors, how do I integrate that with Domoticz? is there another library like openzwave which could be used?
Evelen
Post by Evelen »
kman wrote:Also, if am using 433 MHz sensors, how do I integrate that with Domoticz? is there another library like openzwave which could be used?
You need one of these:
http://www.rfxcom.com/store/Transceivers/14103
All devices will come under "Devices",
Stuff that works with it:
https://www.domoticz.com/wiki/Hardware
I use this:
http://www.ebay.com/itm/261788376051
kman
Post by kman »
@Evelen - thanks for the info.
I had a few additional questions...
I am planning to use RPi with "RFXtrx433E USB 433.92MHz Transceiver"
If I already have domoticz installed on RPi then, all that is required to be done from Linux per se is to install "Mono" and use it to run RFXflash.exe program when I need to upgrade the firmware on RFXtrx433E? Do I need to upgrade the firmware on RFXtrx433E when I receive it?
Aside from that is it safe to assume that once I have RPi connected(usb) to RFXtrx433E with Domoticz running on RPi, there is no additional sw installation required on RPi?
How does one enable/disable protocols on RFXtrx433E - is that done via domoticz?
Many thanks.
manwe
Post by manwe »
If you use switches or dimmers from qubino you can connect an temperature sensor in this price range to the switch.
The big advantage is that it is powered. I hate to change (and pay) batteries ;)
kman
Cheap(£10) temp/Humidity sensor - for RFXtrx433E
Post by kman »
I found Cresta TX-320 - but it doesn't seem to be available in the UK and shipment costs from Netherlands is around euro 19.
Any suggestions on cheap Temp/Humidity sensor under £10 - compatible with RFXtrx433E/Domoticz?
