LUA, include file
gertlind1
LUA, include file
Post by gertlind1 »
I have a bunch of functions() that i use in my LUA scripts.
Is it possible to have those in a separate file instead of copy them to all my LUA scripts?
I have recently started to use the the built in LUA editor if that matters.
Gert
jmleglise
Domoticz version: 2022.1
Re: LUA, include file
Post by jmleglise »
I don't know for built in editor. But with file, you can do like this :
json = (loadfile "/home/pi/domoticz/scripts/lua/json.lua")() -- For Linux
json = (loadfile "D:\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
See example here : https://www.domoticz.com/wiki/Lua_-_json.lua
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
nayr
Domoticz version: github
Post by nayr »
I dont think the lua editor actually saves files on the filesystem, so your lua include is going to have to be maintained externally..
for me I created a folder /usr/local/share/lua/5.2 and linked a file called libs.lua into that folder.
see: https://github.com/nayrnet/domoticz-scr ... a/libs.lua
then here is an example usage in a script:
https://github.com/nayrnet/domoticz-scr ... ntdoor.lua
gertlind1
Post by gertlind1 »
Thanks guys.
i will play around with it,
Gert
gertlind1
Post by gertlind1 »
Of course I can't get it to work.
Created the /usr/local/share/lua/lua5.2/
Created a file there named libs.lua
local libs = {};
function GroupState(sArray)
        -- v1.0. 2016-01-18
        -- Checks the state of a group of swithces.
        -- USAGE   : GroupState({'Switch1','Switch2','Switch3','Switch4','Switch5',more switches})
        -- RETURNS : 'On'       if all switches are on.
        --         : 'Off'      if all switches are off.
        --         : 'Mixed"    if one or more, but not all switches are on.
        local iState = 0
        local iCount = 0
        local sState = ''
        for i,light in pairs(sArray) do
                if (otherdevices[light] == 'On') then
                        iState = iState + 1
        iCount = iCount + 1
        if(iState == 0) then sState = "Off" end
        if(iState > 0) then sState = 'Mixed' end
        if(iState == iCount) then sState = 'On' end
--      print("iCount   : " .. iCount)
--      print("iState   : " .. iState)
--      print("sState   : " .. sState)
        print "LIBS LUA"
        return sState
return libs
made the soft link in my /domoticz/scripts/lua/
libs.lua -> /usr/local/share/lua/5.2/
calling it from here
libs = require("libs")
aLivingroom = {'Hörnbord','Soffbord','Blomma','Fönster','Bokhylla'}
sCounterName = 'Rörelse räknare'
if (devicechanged['Rörelse'] == 'On' and libs.GroupState(aLivingroom) == 'Off') then
        time = os.date("*t")
        if (SunSet() < 60 and time.hour <= 20) then
                commandArray['Group:Alla Vardagsrum']='On'
        if(time.hour >= 21) then
            commandArray['Hörnbord']='On FOR 1'
        difference = TimeDifference('Rörelse')
        myTime = SecondsToClock(tostring(difference))
        commandArray['UpdateDevice'] = '10|0|'..myTime..' sedan senaste rörelsen.'
Getting this error:
Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_motion.lua: /home/pi/domoticz/scripts/lua/script_device_motion.lua:75: attempt to call field 'GroupState' (a nil value)
Gert
gertlind1
Post by gertlind1 »
Forget it.
I cannot read or my glasses are dirty.
missed this
function lGroupState(sArray)
Did not add the "libs."GroupsState(sArray)
Works fine now.
Will move all my functions to libs.lua.
Tanks for the tip and the instruction.
Gert
Dnpwwo
Post by Dnpwwo »
Scripts created through the script editor are stored in the database but the only difference is how they are loaded by Domoticz prior to being handed to the Lua engine. Functionally external file inclusion should work the same way regardless of where the script is stored.
gertlind1
Post by gertlind1 »
Dnpwwo wrote:Scripts created through the script editor are stored in the database but the only difference is how they are loaded by Domoticz prior to being handed to the Lua engine. Functionally external file inclusion should work the same way regardless of where the script is stored.
Yes, works fine.
Added a lua script in the Domoticz internal editor
if (otherdevices['Rörelse'] == 'On') then
    print ('Time to Sunset : ' .. libs.SecondsToClock(tostring(libs.SunSet())))
Works as a charm.
2016-03-12 16:09:23.602  LUA: Time to Sunset : 00:01:33
Would it be possible to have the "functions file" libs.lua in the internal editor also?
That would be great.
Maybe if libs.lua is put in domoticz/scripts/lua
and the soft link that points to lib.lua is in the /usr/local/share/lua/lua5.2/
Gert
dannybloe
Post by dannybloe »
<shameless-plug>
Or you use this: dzVents :mrgreen:
</shameless-plug>
