LUA, include file
gertlind1
LUA, include file
I have a bunch of functions() that i use in my LUA scripts.
Is it possible to have those in a separate file instead of copy them to all my LUA scripts?
I have recently started to use the the built in LUA editor if that matters.
Gert
Gert
jmleglise
- Domoticz version: 2022.1
Re: LUA, include file
I don't know for built in editor. But with file, you can do like this :
json = (loadfile "/home/pi/domoticz/scripts/lua/json.lua")() -- For Linux
json = (loadfile "D:\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
See example here : https://www.domoticz.com/wiki/Lua_-_json.lua
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
KMTronic USB relay
- nayr
- Domoticz version: github
I dont think the lua editor actually saves files on the filesystem, so your lua include is going to have to be maintained externally..
for me I created a folder /usr/local/share/lua/5.2 and linked a file called libs.lua into that folder.
see: https://github.com/nayrnet/domoticz-scr ... a/libs.lua
then here is an example usage in a script:
https://github.com/nayrnet/domoticz-scr ... ntdoor.lua
gertlind1
Of course I can't get it to work.
Created the /usr/local/share/lua/lua5.2/
Created a file there named libs.lua
local libs = {};
function GroupState(sArray)
-- v1.0. 2016-01-18
-- Checks the state of a group of swithces.
-- USAGE : GroupState({'Switch1','Switch2','Switch3','Switch4','Switch5',more switches})
-- RETURNS : 'On' if all switches are on.
-- : 'Off' if all switches are off.
-- : 'Mixed" if one or more, but not all switches are on.
local iState = 0
local iCount = 0
local sState = ''
for i,light in pairs(sArray) do
if (otherdevices[light] == 'On') then
iState = iState + 1
iCount = iCount + 1
if(iState == 0) then sState = "Off" end
if(iState > 0) then sState = 'Mixed' end
if(iState == iCount) then sState = 'On' end
-- print("iCount : " .. iCount)
-- print("iState : " .. iState)
-- print("sState : " .. sState)
print "LIBS LUA"
return sState
return libs
libs.lua -> /usr/local/share/lua/5.2/Code: Select all
libs = require("libs")
aLivingroom = {'Hörnbord','Soffbord','Blomma','Fönster','Bokhylla'}
sCounterName = 'Rörelse räknare'
if (devicechanged['Rörelse'] == 'On' and libs.GroupState(aLivingroom) == 'Off') then
time = os.date("*t")
if (SunSet() < 60 and time.hour <= 20) then
commandArray['Group:Alla Vardagsrum']='On'
if(time.hour >= 21) then
commandArray['Hörnbord']='On FOR 1'
difference = TimeDifference('Rörelse')
myTime = SecondsToClock(tostring(difference))
commandArray['UpdateDevice'] = '10|0|'..myTime..' sedan senaste rörelsen.'
Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_motion.lua: /home/pi/domoticz/scripts/lua/script_device_motion.lua:75: attempt to call field 'GroupState' (a nil value)---
Gert
Gert
gertlind1
Forget it.
I cannot read or my glasses are dirty.
missed this
function lGroupState(sArray)
Did not add the "libs."GroupsState(sArray)
Works fine now.
Will move all my functions to libs.lua.
Tanks for the tip and the instruction.
missed this
Works fine now.
Gert
Gert
- Dnpwwo
Scripts created through the script editor are stored in the database but the only difference is how they are loaded by Domoticz prior to being handed to the Lua engine. Functionally external file inclusion should work the same way regardless of where the script is stored.
gertlind1
Yes, works fine.Dnpwwo wrote:Scripts created through the script editor are stored in the database but the only difference is how they are loaded by Domoticz prior to being handed to the Lua engine. Functionally external file inclusion should work the same way regardless of where the script is stored.
Added a lua script in the Domoticz internal editor
if (otherdevices['Rörelse'] == 'On') then
print ('Time to Sunset : ' .. libs.SecondsToClock(tostring(libs.SunSet())))
return commandArrayCode: Select all
2016-03-12 16:09:23.602 LUA: Time to Sunset : 00:01:33That would be great.
Maybe if libs.lua is put in domoticz/scripts/lua
and the soft link that points to lib.lua is in the /usr/local/share/lua/lua5.2/
Gert
Gert
dannybloe
