SYNOLOGY Ds209+ [SOLVED]
Stevanovich
Il installed domoticz from source repo.
Z-wave device USB stick does not appear in device popup to add.
There is no z-wave device an no openzwave device available .
The last domoticz software seem to be compiled for ds209+ nas. Need last dsm 5 but mine is 4.
I tried to compile it but i meet some error.
How can i check if my USB z-wave stick is recognised ?
Why z-wave or openzwave does not appear in manual device list to add.
Thanks for help
Best regards.
Thanks for help
Best regards.
Last edited by Stevanovich on Wednesday 17 February 2016 23:05, edited 1 time in total.
Stevanovich
Re: SYNOLOGY Ds209+
I found a post about something like my trouble :
viewtopic.php?f=47&t=7087&start=20&hilit=DS209
I tried to install beta domotics from jahdal links , but are not compatible with my DS209+ , because i cannot get last DSM on it !
So , i have to try to upgrade manually DSM, or , to compile manually domoticz for my syno , very hard for me !
What is the best way?
Thanks for any reply.
- jumbotroll
Re: SYNOLOGY Ds209+
Sorry, but DS209+ arch-ppc853x with older DSM 4.2 and DSM 4.3 does not have OpenZwave support.Stevanovich wrote:I found a post about something like my trouble :
It's some problem compiling OpenZwave for older DSM.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
Stevanovich
Re: SYNOLOGY Ds209+
C'est quoi le problème ? (where is the problem ?)
So with domoticz v2.212 from synology community rep , no z-wave or openzwave device in the popup list
with domoticz V2.3823 from Jahdal , no z-wave or openzwave device in the popup list
Also tried UsbSerialDrivers_3.0.2.spk and UsbSerialDrivers_3.0.5.spk with no differences
- stop domoticz services, install driver, reboot and start domoticz
I'm sad and crying ...
Stevanovich
Re: SYNOLOGY Ds209+
Ok,jumbotroll wrote: Sorry, but DS209+ arch-ppc853x with older DSM 4.2 and DSM 4.3 does not have OpenZwave support.
if i try to install DSM 5, i will get some result ?
niki_lauda
Re: SYNOLOGY Ds209+
When you have a an "older" DS like me a DS209, you can't upgrade to dsm 5.
Synology supports the dsm 5 year after release off the diskstation.
Stevanovich
Re: SYNOLOGY Ds209+
Yes , i confirm that DS209+ does not support at all DSM5 ...
Now, I've got a syno-bricks ... at home
I tried to downgrade to DSM4 , but it is another problem.
I hope i can repear it .
Come back as soon as repair .
- jumbotroll
Re: SYNOLOGY Ds209+
I have made a test build Domoticz stable v2.3530 for DS209+ DSM 4.3 (arch=ppc853x) and OpenZvave.
Should also work on DSM 4.2.
http://www.jadahl.com/domoticz_stable/?arch=ppc853x
http://www.jadahl.com/domoticz_stable/p ... 3530-7.spk
Jumbotroll
Jumbotroll
Stevanovich
Re: SYNOLOGY Ds209+
Hello,jumbotroll wrote:I have made a test build Domoticz stable v2.3530 for DS209+ DSM 4.3 (arch=ppc853x) and OpenZvave.
Thanks for reply, i can't remember if i have tested it, not downloaded , not tested ...
i will try as soon as i repair my Syno DS209+ ...
I followed a german tutorial for upgrade it to DSM5 , i failed it and brick my syno.
At this time , i am backup all my precious files on my DS207 with an external disk , happy to have another one
I hope to have finish saturday .
Thanks for all
Stevanovich
Re: SYNOLOGY Ds209+
Unbricked my DS209+ !!!
Really thanks to this :
http://www.huubmons.nl/multimedia/nas/1 ... gy-unbrick
and this :
http://www.synology-forum.de/showthread ... erschossen
and my arduino usb ttl device !
I'm writting a french blog about it, maybe not alone in this case .
Really thanks to jadahl :
domoticz_ppc853x-4.3_2.0.3530-7.spk works for me !
Openzwave device appear in the dropdwon list now .
Can i try to install another spk (latest) and go back after ?
best regards
and this :
best regards
- jumbotroll
Re: SYNOLOGY Ds209+
No, you can not update.
domoticz_ppc853x-4.3_2.0.3530-7.spk is the only version I have manage to compile with openzwave.
You can always test another versions and uninstall if it's not working and reinstall domoticz_ppc853x-4.3_2.0.3530-7.spk
Jumbotroll
Jumbotroll
Stevanovich
Re: SYNOLOGY Ds209+
Now i meet a new problem ,
I plug AEON Stick on my Synology
Is there any easy way to know what is it's usb device mounted name (usb0 , usb1?), When i want to manage it nothing appear, what i get wrong ?
here is lsmod and dmesg |grep usb
Module Size Used by Tainted: P
ch341 10820 0
pl2303 17487 1
cp210x 14577 0
ftdi_sio 33370 0
usbserial 28790 6 ch341,pl2303,cp210x,ftdi_sio
cifs 213600 0
udf 83070 0
isofs 31447 0
loop 14892 0
usbhid 27720 0
hid 40835 1 usbhid
input_core 24002 2 usbhid,hid
usblp 13170 0
usb_storage 41243 0
ohci_hcd 22406 0
ehci_hcd 38572 0
ppc85xx_synobios 31446 0
skge 41500 0
synoacl_ext4 16683 0
synoacl_vfs 8648 0
hfsplus 75000 0
fuse 58743 0
vfat 12814 0
fat 50456 1 vfat
i2c_mpc 10320 0
of_i2c 4658 1 i2c_mpc
i2c_core 19323 3 ppc85xx_synobios,i2c_mpc,of_i2c
cryptosoft 15693 0
ecryptfs 90327 0
sha512_generic 12013 0
sha256_generic 12560 0
sha1_generic 5095 0
ecb 5269 0
talitos 26523 0
authenc 9366 0
rng_core 6346 1 talitos
cryptodev 15358 1
ocf 21290 2 cryptosoft,cryptodev
crc32c 5774 0
ansi_cprng 6937 0
aes_generic 30578 0
cpufreq_stats 5933 0
freq_table 5346 1 cpufreq_stats
dm_snapshot 25975 0
crc_itu_t 4411 1 udf
crc_ccitt 4403 0
quota_v2 7169 2
quota_tree 10166 1 quota_v2
usbcore 123446 11 ch341,pl2303,cp210x,ftdi_sio,usbserial,usbhid,usblp,usb_storage,ohci_hcd,ehci_hcd
sg 26254 0
psnap 5089 0
llc 6464 1 psnap
raid456 58235 0
raid10 26936 0
raid0 12020 0
linear 9202 0
async_raid6_recov 8066 1 raid456
async_pq 6885 2 raid456,async_raid6_recov
raid6_pq 78043 2 async_raid6_recov,async_pq
async_xor 6029 3 raid456,async_raid6_recov,async_pq
xor 10517 1 async_xor
async_memcpy 4486 2 raid456,async_raid6_recov
async_tx 5410 5 raid456,async_raid6_recov,async_pq,async_xor,async_memcpy
dm_mod 61733 1 dm_snapshot
ipv6 238191 38 Code: Select all
[ 17.270650] usbcore: registered new interface driver usbfs
[ 17.294731] usbcore: registered new interface driver hub
[ 17.305965] usbcore: registered new device driver usb
[ 27.543971] usb usb1: configuration #1 chosen from 1 choice
[ 27.760982] usb usb2: configuration #1 chosen from 1 choice
[ 28.082240] usbcore: registered new interface driver usb-storage
[ 28.232998] usbcore: registered new interface driver usblp
[ 28.522189] usbcore: registered new interface driver hiddev
[ 28.541073] usbcore: registered new interface driver usbhid
[ 28.546670] usbhid: v2.6:USB HID core driver
[ 30.923079] usb 2-1: new full speed USB device using ohci_hcd and address 2
[ 31.086703] usb 2-1: configuration #1 chosen from 1 choice
[ 52.051872] usbcore: registered new interface driver usbserial
[ 52.057750] usbserial: USB Serial Driver core
[ 52.122666] usbcore: registered new interface driver ftdi_sio
[ 52.208197] usb 2-1: lock for hub EH
[ 52.354067] usb 2-1: reset full speed USB device using ohci_hcd and address 2
[ 52.493458] usb 2-1: device firmware changed
[ 52.497756] usb 2-1: unlock for hub EH
[ 52.504367] usb 2-1: cp210x converter now attached to ttyUSB0
[ 52.531532] usb 2-1: cp210x converter now attached to ttyUSB1
[ 52.540401] usbcore: registered new interface driver cp210x
[ 52.559088] usb 2-1: USB disconnect, address 2
[ 52.777089] usb 2-1: new full speed USB device using ohci_hcd and address 3
[ 52.976597] usb 2-1: configuration #1 chosen from 1 choice
[ 53.131334] usb 2-1: pl2303 converter now attached to ttyUSB0
[ 53.308192] usb 2-1: pl2303 converter now attached to ttyUSB1
[ 53.391220] usbcore: registered new interface driver pl2303
[ 53.540833] usbcore: registered new interface driver ch341
[ 57.277543] Modules linked in: ch341 pl2303 cp210x ftdi_sio usbserial cifs udf isofs loop usbhid hid input_core usblp usb_storage ohci_hcd ehci_hcd ppc85xx_synobios(P) skge synoacl_ext4(P) synoacl_vfs(P) hfsplus fuse vfat fat i2c_mpc of_i2c i2c_core cryptosoft ecryptfs sha512_generic sha256_generic sha1_generic ecb talitos authenc rng_core cryptodev(P) ocf(P) crc32c ansi_cprng aes_generic cpufreq_stats freq_table dm_snapshot crc_itu_t crc_ccitt quota_v2 quota_tree usbcore sg psnap llc raid456 raid10 raid0 linear async_raid6_recov async_pq raid6_pq async_xor xor async_memcpy async_tx dm_mod ipv6 [last unloaded: i2c_core]
[ 57.412628] [be789d40] [c30b8538] serial_open+0xe4/0x140 [usbserial]
Stevanovich
Re: SYNOLOGY Ds209+
Some news here, i still try to plug my AEON Stick gen5 , with UsbSerialDriver V3.0.9
and Fail to open usb port
I think there is a problem with detect AEON Stick ?
Thanks for help
Thanks for help
- Domoticz002.JPG (108.44 KiB) Viewed 5312 times
Stevanovich
Re: SYNOLOGY Ds209+
I followed this post from :
http://www.openremote.org/display/docs/ ... ents=false
Now, work prefectly, my device is /dev/ttyACM0 , so apply this to previous post
I shut down domoticz, uninstall domoticz, reboot my synology, réinstall domoticz4) Permission OpenRemote service account to allow the creation of OS locks. This will be needed to ensure a resource lock is created when communicating the serial port of the USB device.
For this:
Add a new group using the standard add group admin screen in synology. Review section 3 of How to create user accounts and groups on Synology NAS. Add a group called: uucp
Add the openremote user to the newly created uucp group
Verify that the group is setup correctly in a shell session:
> more /etc/group
You should see something like:
uucp65548:openremote
Ensure new group can access write to /var/lock folder:
> chown -R root.uucp /var/lock
5) Permission openremote to the USB port device.
Add a new group using the standard add group admin screen in Synology. Review section 3 of How to create user accounts and groups on Synology NAS. Add a group called: dialout
Add the openremote user to the newly created dialout group
> more /etc/group
dialout65549:openremote
Ensure new group can access write to /dev/ttyUSB0 device:
> chown -R root.dialout /dev/ttyUSB0
The example here uses ttyUSB0, but the device assigned is what you'll observe in step (6) in the Installation of Linux Serial Drivers.
