I have a z-wave network with a static update controller (SUC) (Z-wave-me USB stick or UZB). I am using a Raspberry Pi with a razberry z-wave interface.
The SUC appears not detected in Domoticz, SUC node = 0 in the Openzwave control panel, however the z-way server software (when I use this in the Raspberry Pi instead of Domotics with ozw) does detect the SUC. What could be the issue here?
No detection of static update controller (suc)
WillemK
Re: No detection of static update controller (suc)
No response/solutions?
willie-p
I've the same issue as in the openzwave software and razberry.
See also my post on adding the second controller: viewtopic.php?f=24&t=10240
Kind regards,
Will
Kind regards,
Will
WillemK
Hello Willie-p,
What I encounter is I think not the same issue as you describe. Adding Domoticz as a secondary controller was not problem, but I want to keep it as a slave without associating capabilities but only updating from the primary controller. The primary controller should be see as a SUC (Static Update Controller) by the secondary controller in openzwave but it is not. In the Openzwave control panel a "0" is shown at SUC node.
When I switch to the z-way control panel (from z-wave.me) the secondary controller sees the primary as SUC. So for the moment I can only update the secondary controller by switching from Domoticz to z-way.
I wonder whether there is a way in openzwave to change the SUC Node ID. If someone knows it, please share. Thanks in advance!
Regards,
Willem
Regards,
Willem
WillemK
I still did not found a solution, still can't get a secondary domoticz controller update from the SUC.
jin
+1 for me...
I really need this feature since 2014... This seems a limitation of Domoticz
with kind regards
with kind regards
WillemK
It does still not work. It is probably openzwave limitation.
jin
That missing features make OpenZWave stack really less portable... primarily with large zwave network.
WillemK
I still hope that this function will be added some day...
