High temperature sensor
oliviers
Domoticz version: Stable
Post by oliviers »
Can anyone recommend a temperature sensor for high temperatures (40-120°C), supported by RFXCOMM/Domoticz ?
Goal is to start an heat recovery fan in the fireplace hood as soon as the temperature reaches 40-50 degrees therein.
Of course I could do it with a simple thermostat, but I would rather do it via my home automation system...
Thanks for any hint,
Oliviers
Paris area
Raspberry Pi 4 - RFXComm 433 - IrTrans - Zwave
b_weijenberg
Re: High temperature sensor
Post by b_weijenberg »
The Maverick ET-722 BBQ/smoke sensor can be used for example.
RFX-433, RFX-433EMC, RFX-868
oliviers
Post by oliviers »
That sounds like an interesting suggestion... I looked to all kind of devices, but I didn't think to a BBQ probe, I must admit ....
Paris area
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
I have that sensor for my bbq's, indeed it works with Domoticz. (I use it to keep an eye on the smoker during long sessions).
I am not sure how long the battery will last if you keep it turned on.
You would only need the transmitter part, not the receiver. Maybe you can get it as a spare part.
But you can also use a (waterproof) DS18B20 sensor, they also go up to 125 degrees C.
It would need some additional components though.
oliviers
Post by oliviers »
Well, if I go for that solution, I will replace the battery by a wall adapter.
Paris area
oliviers
Post by oliviers »
Just to let you know....
I'm running that sensor on its batteries for three months now.... Not showing any wekaness so far...
Paris area
jenssen
Domoticz version: stable
Post by jenssen »
bbqkees wrote:I have that sensor for my bbq's, indeed it works with Domoticz. (I use it to keep an eye on the smoker during long sessions).
what receiver do I need to connect this transmitter to Domoticz? Do you recommended the Maverick ET732 or the Maverick ET733? Is it seen as a temperature device within Domoticz? How fast is the temperature updated?
Thanks.
bbqkees
Post by bbqkees »
I use the RFXCOM.
I have the ET732 but the ET733 seems like the follow up model.
Roland1971
Post by Roland1971 »
I did find the ET733 under the christmas tree today :-) looks and feels good !
When searching for new devices, Domoticz finds 3 new, 2 temperature sensors and 1 BBQ meter. The temperature sensors are added and displayed in the dashboard but I am not able to find the BBQ meter. Is this correct or ?
Does anyone have a solution to add the BBQ meter
Happy holidays
Axeteg
Post by Axeteg »
I have a problem with the Maverick termometer.
I can see it under the "Device" tab,with correct values and everything, but when i add it, it dont show in the "Temperature" tab.
Someone else that has this problem?
