5-in-1 sketch corrupt after updates?
remb0
Post by remb0 »
I use an mysensor with: motion, ds1820 (temperature), dht22
everything worked fine (the ds1820 was connecter on my hot water pipe. but since a few weeks I do not get new values.
is something changed so my sketch isn't compatible? who can help me with controlling the sketch?
Not knowing if it's a bug or something on the script.
2016-01-21 20_23_07-Domoticz.png (350.02 KiB) Viewed 1625 times
#include <SPI.h>
#include <MySensor.h>
#include <DHT.h>
#include <BH1750.h>
#include <Wire.h>
  #include <DallasTemperature.h>
  #include <OneWire.h>
  #define COMPARE_TEMP 1 // Send temperature only if changed? 1 = Yes 0 = No
  #define ONE_WIRE_BUS 5
  #define MAX_ATTACHED_DS18B20 1
#define CHILD_ID_LIGHT 0
#define CHILD_ID_TEMP2 1
#define CHILD_ID_HUM 2
#define CHILD_ID_TEMP 2
#define CHILD_ID_MOT 3   // Id of the sensor child
#define HUMIDITY_SENSOR_DIGITAL_PIN 4
#define DIGITAL_INPUT_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
#define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
  OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
  DallasTemperature sensors(&oneWire); // Pass the oneWire reference to Dallas Temperature.
MySensor gw;
DHT dht;
BH1750 lightSensor;
 float lastTemperature[MAX_ATTACHED_DS18B20];
int numSensors=1;
boolean receivedConfig = false;
boolean metric = true;
float lastTemp;
float lastHum;
MyMessage msgHum(CHILD_ID_HUM, V_HUM);
MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
MyMessage msgLux(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
MyMessage msgTemperature(CHILD_ID_TEMP2,V_TEMP);
uint16_t lastlux;
void setup()
  // Startup up the OneWire library
  sensors.begin();
  // requestTemperatures() will not block current thread
  sensors.setWaitForConversion(false);
  // Startup and initialize MySensors library. Set callback for incoming messages.
  gw.begin();
  dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
  // Send the Sketch Version Information to the Gateway
  gw.sendSketchInfo("Temp/Temp/Humidity/Motion/Lux", "1.0");
 pinMode(DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
  // Register all sensors to gw (they will be created as child devices)
  gw.present(CHILD_ID_TEMP2, S_TEMP);
  gw.present(CHILD_ID_HUM, S_HUM);
  gw.present(CHILD_ID_TEMP, S_TEMP);
  gw.present(CHILD_ID_MOT, S_MOTION);
  gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
  metric = gw.getConfig().isMetric;
    lightSensor.begin();
void loop()
    // Process incoming messages (like config from server)
    gw.process();
  // Read digital motion value
  boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
      Serial.print("Motion 1/0: ");
  Serial.println(tripped);
  gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
  delay(dht.getMinimumSamplingPeriod());
  float temperature = dht.getTemperature();
  if (isnan(temperature)) {
      Serial.println("Failed reading temperature from DHT");
  } else if (temperature != lastTemp) {
    lastTemp = temperature;
    if (!metric) {
      temperature = dht.toFahrenheit(temperature);
    gw.send(msgTemp.set(temperature, 1));
    Serial.print("Temp: ");
    Serial.println(temperature);
  float humidity = dht.getHumidity();
  if (isnan(humidity)) {
      Serial.println("Failed reading humidity from DHT");
  } else if (humidity != lastHum) {
      lastHum = humidity;
      gw.send(msgHum.set(humidity, 1));
      Serial.print("Hum: ");
      Serial.println(humidity);
    uint16_t lux = lightSensor.readLightLevel();// Get Lux value
    if (lux != lastlux) {
      gw.send(msgLux.set(lux));
      lastlux = lux;
  Serial.print("lux: ");
    Serial.println(lux);
  // Ds1820
  // Fetch temperatures from Dallas sensors
    sensors.requestTemperatures();
    // query conversion time and sleep until conversion completed
    int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution());
    // sleep() call can be replaced by wait() call if node need to process incoming messages (or if node is repeater)
    gw.sleep(conversionTime);
  // Read temperatures and send them to controller
  for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
        // Fetch and round temperature to one decimal
        float temperature1 = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        // Only send data if temperature has changed and no error
        #if COMPARE_TEMP == 1
        if (lastTemperature[i] != temperature1 && temperature1 != -127.00 && temperature1 != 85.00)
            Serial.print("DS1820: ");
            Serial.println(temperature1);
            #else
            if (temperature1 != -127.00 && temperature1 != 85.00) {
            #endif
              // Send in the new temperature
              gw.send(msg.setSensor(i).set(temperature1,1));
              // Save new temperatures for next compare
              lastTemperature[i]=temperature1;
  // Sleep until interrupt comes in on motion sensor. Send update every two minute.
  gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
HarryDutch
Re: 5-in-1 sketch corrupt after updates?
Post by HarryDutch »
The value of CHILD_ID_TEMP and CHILD_ID_HUM is the same (2). Give one of the id's a another value.
remb0
Post by remb0 »
thnanks! I will test it.
remb0
Post by remb0 »
now I got:
C:\arduino-1.6.7\arduino-builder -dump-prefs -logger=machine -hardware "C:\arduino-1.6.7\hardware" -hardware "C:\Users\remco\AppData\Local\Arduino15\packages" -hardware "C:\Users\remco\Documents\Arduino\hardware" -tools "C:\arduino-1.6.7\tools-builder" -tools "C:\arduino-1.6.7\hardware\tools\avr" -tools "C:\Users\remco\AppData\Local\Arduino15\packages" -built-in-libraries "C:\arduino-1.6.7\libraries" -libraries "C:\Users\remco\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10607 -build-path "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\remco\AppData\Local\Temp\arduino_7362141b19766f8a7da9606414bbfc15\_5-in-1.ino"
C:\arduino-1.6.7\arduino-builder -compile -logger=machine -hardware "C:\arduino-1.6.7\hardware" -hardware "C:\Users\remco\AppData\Local\Arduino15\packages" -hardware "C:\Users\remco\Documents\Arduino\hardware" -tools "C:\arduino-1.6.7\tools-builder" -tools "C:\arduino-1.6.7\hardware\tools\avr" -tools "C:\Users\remco\AppData\Local\Arduino15\packages" -built-in-libraries "C:\arduino-1.6.7\libraries" -libraries "C:\Users\remco\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10607 -build-path "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\remco\AppData\Local\Temp\arduino_7362141b19766f8a7da9606414bbfc15\_5-in-1.ino"
WAARSCHUWING: Categorie '' in bibliotheek UIPEthernet is niet geldig. Wordt gewijzigd naar 'Uncategorized'
Build-opties gewijzigd, alles wordt opnieuw gebuild
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "C:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI\SPI.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MyHw.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MyHwATMega328.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MyHwESP8266.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MyMessage.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MyParser.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MyParserSerial.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MySensor.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MySigning.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MySigningAtsha204.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MySigningAtsha204Soft.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MySigningNone.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MyTransport.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MyTransportNRF24.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "C:\Users\remco\Documents\Arduino\libraries\MySensors\MyTransportRFM69.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "C:\Users\remco\Documents\Arduino\libraries\MySensors\utility\ATSHA204.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "C:\Users\remco\Documents\Arduino\libraries\MySensors\utility\RF24.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "C:\Users\remco\Documents\Arduino\libraries\MySensors\utility\RFM69.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "C:\Users\remco\Documents\Arduino\libraries\MySensors\utility\SPIFlash.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "C:\Users\remco\Documents\Arduino\libraries\MySensors\utility\sha256.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "C:\Users\remco\Documents\Arduino\libraries\DHT\DHT.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "C:\Users\remco\Documents\Arduino\libraries\BH1750\BH1750.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "C:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire\Wire.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp" -o "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "C:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire\utility\twi.c" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "C:\Users\remco\Documents\Arduino\libraries\DallasTemperature\DallasTemperature.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "C:\Users\remco\Documents\Arduino\libraries\OneWire\OneWire.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp" -o "nul"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp" -o "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\arduino-1.6.7\tools-builder\ctags\5.8-arduino5/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\arduino-1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\arduino-1.6.7\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\remco\Documents\Arduino\libraries\MySensors" "-IC:\Users\remco\Documents\Arduino\libraries\DHT" "-IC:\Users\remco\Documents\Arduino\libraries\BH1750" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire" "-IC:\Users\remco\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\remco\Documents\Arduino\libraries\OneWire" "-IC:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI" "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp" -o "C:\Users\remco\AppData\Local\Temp\build7362141b19766f8a7da9606414bbfc15.tmp\sketch\_5-in-1.ino.cpp.o"
C:\Users\remco\AppData\Local\Temp\arduino_7362141b19766f8a7da9606414bbfc15\_5-in-1.ino: In function 'void loop()':
_5-in-1:146: error: 'msg' was not declared in this scope
               gw.send(msg.setSensor(i).set(temperature,1));
C:\Users\remco\AppData\Local\Temp\arduino_7362141b19766f8a7da9606414bbfc15\_5-in-1.ino: At global scope:
_5-in-1:153: error: 'gw' does not name a type
_5-in-1:154: error: expected declaration before '}' token
Bibliotheek SPI op versie 1.0 in map: C:\arduino-1.6.7\hardware\arduino\avr\libraries\SPI  wordt gebruikt
Bibliotheek MySensors op versie 2.0.0-beta in map: C:\Users\remco\Documents\Arduino\libraries\MySensors  wordt gebruikt
Bibliotheek DHT in map: C:\Users\remco\Documents\Arduino\libraries\DHT (legacy) wordt gebruikt
Bibliotheek BH1750 in map: C:\Users\remco\Documents\Arduino\libraries\BH1750 (legacy) wordt gebruikt
Bibliotheek Wire op versie 1.0 in map: C:\arduino-1.6.7\hardware\arduino\avr\libraries\Wire  wordt gebruikt
Bibliotheek DallasTemperature op versie 3.7.5 in map: C:\Users\remco\Documents\Arduino\libraries\DallasTemperature  wordt gebruikt
Bibliotheek OneWire op versie 2.3.1 in map: C:\Users\remco\Documents\Arduino\libraries\OneWire  wordt gebruikt
exit status 1
HarryDutch
I see that you are now using the MySensors beta library. Things are handeled different when you are using the beta. For example, every reference to "gw" needs to be removed and so on (for example you now write "sleep" instead of "gw.sleep". You better have a look at one of the example sketches in the new library to get the picture. Could you post the latest sketch you're using?
