Hi everyone,
Yesterday i moved from Windows version to RPI version of Domoticz.
I setup my netatmo account in the windows instance and everything was fine : i had my thermostat and the weather
But since i moved to RPI, i can only see the weather station.
Under hardware, it's written 'netatmo weather'.
My thermostat sensor / switch are no longer seen.
I want to add it them again, but don't know how to ?
I tryed to disable and re enable the netatmo configuration, but nothing.
I tryed to remove the thermostat set point, but i can't add it again, there is no new device under the device tab
does someone has an idea ?
Configure Netatmo Thermostat under Domoticz RPI
Re: Configure Netatmo Thermostat under Domoticz RPI
i've just verified my Windows version , this is written NETATMO as hardware and not NETATMO WEATHER STATION like in the RPI distribution.
I have the latest version of domoticz for both plateform
Did someone configure domoticz with the netatmo thermostat on the RPI version?
No one has setup thermostat with the rpi build v2.3540?
Jango
Why do not you use the latest beta software of domoticz?
I use domoticz 2.4547 now and the netatmo is working fine under domoticz
