Configure Netatmo Thermostat under Domoticz RPI
fabd
Post by fabd »
Hi everyone,
Yesterday i moved from Windows version to RPI version of Domoticz.
I setup my netatmo account in the windows instance and everything was fine : i had my thermostat and the weather
But since i moved to RPI, i can only see the weather station.
Under hardware, it's written 'netatmo weather'.
My thermostat sensor / switch are no longer seen.
I want to add it them again, but don't know how to ?
I tryed to disable and re enable the netatmo configuration, but nothing.
I tryed to remove the thermostat set point, but i can't add it again, there is no new device under the device tab
does someone has an idea ?
fabd
Re: Configure Netatmo Thermostat under Domoticz RPI
Post by fabd »
i've just verified my Windows version , this is written NETATMO as hardware and not NETATMO WEATHER STATION like in the RPI distribution.
I have the latest version of domoticz for both plateform
Did someone configure domoticz with the netatmo thermostat on the RPI version?
fabd
Post by fabd »
No one has setup thermostat with the rpi build v2.3540?
Jango
Post by Jango »
Why do not you use the latest beta software of domoticz?
I use domoticz 2.4547 now and the netatmo is working fine under domoticz
