Temperature logs call JSON
Minglarn
Domoticz version: v3.8153
Post by Minglarn »
Hi, trying to extract the temperature logs from one senor.
Using this:
 http://192.168.1.236:8080/json.htm?type=graph&sensor=temp&idx=9&range=month
And the result is this: (A small cut from the result)
"result" : [
         "d" : "2015-12-17",
         "hu" : "88",
         "ta" : 2.840,
         "te" : 4.60,
         "tm" : 0.0
         "d" : "2015-12-18",
         "hu" : "92",
         "ta" : 8.160,
         "te" : 9.90,
         "tm" : 4.60
         "d" : "2015-12-19",
         "hu" : "88",
         "ta" : 9.10,
         "te" : 10.20,
         "tm" : 6.70
         "d" : "2015-12-20",
         "hu" : "87",
         "ta" : 11.120,
         "te" : 12.30,
         "tm" : 10.10
But having some thoughts about the returned result...
I understand that
"d" = DAY
"hu" = Humidity
But:
"ta" = Highest temp?
"te" = Average temp?
"tm" = Lowest temp?
Is there any wiki or documentation on this?
Please if there is any documentation let me know ...
gizmocuz
Re: Temperature logs call JSON
Post by gizmocuz »
Why not look in the source code ?
temp avarage
max temp
"tm" = Lowest temp?
min temp
Minglarn
Post by Minglarn »
Thanks Gizmo... Will do that next time...
