Temperature logs call JSON
Minglarn
Domoticz version: v3.8153
Post by Minglarn »
Hi, trying to extract the temperature logs from one senor.
Using this:
 http://192.168.1.236:8080/json.htm?type=graph&sensor=temp&idx=9&range=month
And the result is this: (A small cut from the result)
"result" : [
         "d" : "2015-12-17",
         "hu" : "88",
         "ta" : 2.840,
         "te" : 4.60,
         "tm" : 0.0
         "d" : "2015-12-18",
         "hu" : "92",
         "ta" : 8.160,
         "te" : 9.90,
         "tm" : 4.60
         "d" : "2015-12-19",
         "hu" : "88",
         "ta" : 9.10,
         "te" : 10.20,
         "tm" : 6.70
         "d" : "2015-12-20",
         "hu" : "87",
         "ta" : 11.120,
         "te" : 12.30,
         "tm" : 10.10
But having some thoughts about the returned result...
I understand that
"d" = DAY
"hu" = Humidity
But:
"ta" = Highest temp?
"te" = Average temp?
"tm" = Lowest temp?
Is there any wiki or documentation on this?
Please if there is any documentation let me know ...
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
gizmocuz
Re: Temperature logs call JSON
Post by gizmocuz »
Why not look in the source code ?
temp avarage
max temp
"tm" = Lowest temp?
min temp
Minglarn
Post by Minglarn »
Thanks Gizmo... Will do that next time...
