Just recived my HomeEasy HE889, and tried to install it. The most simple part was to connect it in Domoticz, using RFLINK.
But the sunscreen is not closing or opening, so i guess there is somting wrong with the wiring. I hope someone here can help me out.
My old switch is wired like in the attached PDF.
For the HE899 is used http://s.s-bol.com/imgbase0/imagebase3/ ... 241258.pdf
As far is i can see, is the old switch is switching on the brown wire ( fase / phase ). And if i understand the manual from the HE889 well, it is switching with the ' blue' wire ( nul / neutral ).
So, is the combination with my sunscreen an the HE889 possible? And how to get it to work?
I hope someone tried it before, and can help me!
HomeEasy GE889, wirining issue.
axelbaas
- Aansluiting schakelaar.pdf
- Wiring Old switch
- (168.59 KiB) Downloaded 82 times
- Domosapiens
- Domoticz version: V3.5981
Re: HomeEasy GE889, wirining issue.
Axelbaas,
With respect to the motor cable: If you are not sure if black or brown is open or close
Use your old switch to put the sunscreen in a half open/closed position.
1) If you have a meter (or spanningzoeker) measure what direction is what color.
Keep the screen half way.
Connect the new switch:
- blue (from mains) on N
- brown (from mains) on L
- interconnect L and C
Depending on 1) :
- brown (from motor) on B
- black (from motor) on A
or the other way around
- blue (from mains) on blue (from motor)
If the screen is half way there must be an action in one direction or the other
Hope this helps
Domosapiens
[edit, added: - blue (from mains) on blue (from motor); plus typo]
Depending on 1) :
Hope this helps
Domosapiens
Last edited by Domosapiens on Monday 18 January 2016 13:57, edited 1 time in total.
axelbaas
Domosapiens,
Will try it tonight with an multimeter. I will let you know!
Gr. Axel
Gr. Axel
axelbaas
Got it. Had to combine the two blue and brown wires together. Now it is working!
Verstuurd vanaf mijn SM-G920F met Tapatalk
