deennoo
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by deennoo »
murtadin wrote:
Is there any real chance, that support of wi-fi socket will be added? Developer mode for xiaomi wi-fi socket. For ir remote it would be great too.
Sent from my MI MAX using Tapatalk
Why don't you ask them directly ? Api doesn't talk about wifi socket.
On this topic there is a how to about xiaomi robot cleaner, have you test it for your plug?
http://domo-attitude.fr
corbin
Post by corbin »
hekm77 wrote:I have problems with Xiaomi Smart Socket (ZigBee). Domoticz v3.6908
Can you describe the problem further? Looking at these two logs, the times do not coincide?
Coldman
Post by Coldman »
Hi Corbin, I have same issue, in the log few messages when sockets on / off
2017-03-12 20:25:11.624  User: Admin initiated a switch command (62/xSP03/Off)
2017-03-12 20:25:11.688  (xGW) Light/Switch (xSP03)
2017-03-12 20:25:11.693  {"cmd":"report","model":"plug","sid":"158d00013e26eb","short_id":12198,"data":"{\"status\":\"off\"}"}
2017-03-12 20:25:11.710  (xGW) Light/Switch (xSP03)
2017-03-12 20:25:11.715  {"cmd":"report","model":"plug","sid":"158d00013e26eb","short_id":12198,"data":"{\"status\":\"off\"}"}
2017-03-12 20:25:11.776  (xGW) Light/Switch (xSP03)
2017-03-12 20:25:15.713  RFLink: 20;3F;FineOffset;ID=004d;TEMP=01c8;
2017-03-12 20:25:15.713  (RFLink) Temp (FineOffset)
2017-03-12 20:25:17.242  (Domoticz#01) General/Percentage (RPi#01RAM)
2017-03-12 20:25:17.262  (Domoticz#01) General/Percentage (RPi#01CPU)
2017-03-12 20:25:17.285  (Domoticz#01) Temp (RPi#01Temp)
2017-03-12 20:25:18.618  User: Admin initiated a switch command (62/xSP03/On)
2017-03-12 20:25:18.769  (xGW) Light/Switch (xSP03)
2017-03-12 20:25:19.082  (xGW) Light/Switch (xSP03)
2017-03-12 20:25:19.086  {"cmd":"report","model":"plug","sid":"158d00013e26eb","short_id":12198,"data":"{\"status\":\"on\"}"}
2017-03-12 20:25:19.104  (xGW) Light/Switch (xSP03)
2017-03-12 20:25:19.108  {"cmd":"report","model":"plug","sid":"158d00013e26eb","short_id":12198,"data":"{\"status\":\"on\"}"}
corbin
Post by corbin »
Thanks, think I've found the problem and am compiling on my Raspberry now to test properly.
hekm77
Post by hekm77 »
Thank you, corbin. v3.6912.
Unfortunately, there are no changes with the socket.
Снимок экрана от 2017-03-13 19-59-56.png (26.64 KiB) Viewed 3293 times
2017-03-13 19:55:30.059 (Xiaomi) Light/Switch (Камера)
2017-03-13 19:55:30.141 XiaomiGateway: not updating Domoticz for switch as no change from last state
2017-03-13 19:55:30.141 {"cmd":"report","model":"plug","sid":"158d00011016d0","short_id":41069,"data":"{\"status\":\"on\"}"}
2017-03-13 19:55:31.882 XiaomiGateway: not updating Domoticz for switch as no change from last state
2017-03-13 19:55:31.882 {"cmd":"heartbeat","model":"motion","sid":"158d0001173873","short_id":32522,"data":"{\"status\":\"no_motion\"}"}
2017-03-13 19:55:39.726 Incoming connection from: 5.104.179.16
2017-03-13 19:55:45.862 User: Admin initiated a switch command (9/Камера/Off)
2017-03-13 19:55:46.012 (Xiaomi) Light/Switch (Камера)
2017-03-13 19:55:46.525 XiaomiGateway: not updating Domoticz for switch as no change from last state
2017-03-13 19:55:46.525 {"cmd":"report","model":"plug","sid":"158d00011016d0","short_id":41069,"data":"{\"status\":\"off\"}"}
2017-03-13 19:56:00.082 LUA: TV ping success
2017-03-13 19:56:00.182 LUA: TV says it is active
2017-03-13 19:56:00.182 LUA: TV active, status is ON, so do nothing.
2017-03-13 19:57:00.236 LUA: TV ping success
2017-03-13 19:57:00.338 LUA: TV says it is active
2017-03-13 19:57:00.338 LUA: TV active, status is ON, so do nothing.
2017-03-13 19:57:40.149 User: Admin initiated a switch command (9/Камера/On)
2017-03-13 19:57:40.292 (Xiaomi) Light/Switch (Камера)
2017-03-13 19:57:40.311 {"cmd":"report","model":"plug","sid":"158d00011016d0","short_id":41069,"data":"{\"status\":\"on\"}"}
2017-03-13 19:57:40.311 XiaomiGateway: not updating Domoticz for switch as no change from last state
2017-03-13 19:57:40.311 (Xiaomi) Light/Switch (Камера)
2017-03-13 19:58:00.465 LUA: TV ping success
2017-03-13 19:58:00.626 LUA: TV says it is active
2017-03-13 19:58:00.626 LUA: TV active, status is ON, so do nothing.
2017-03-13 19:58:09.067 XiaomiGateway: not updating Domoticz for switch as no change from last state
2017-03-13 19:58:09.067 {"cmd":"heartbeat","model":"plug","sid":"158d00011016d0","short_id":41069,"data":"{\"status\":\"on\",\"inuse\":\"0\"}"}
2017-03-13 19:58:36.651 User: Admin initiated a switch command (9/Камера/Off)
2017-03-13 19:58:36.817 XiaomiGateway: not updating Domoticz for switch as no change from last state
2017-03-13 19:58:36.817 {"cmd":"report","model":"plug","sid":"158d00011016d0","short_id":41069,"data":"{\"status\":\"off\"}"}
2017-03-13 19:58:36.802 (Xiaomi) Light/Switch (Камера)
2017-03-13 19:59:00.239 LUA: TV ping success
2017-03-13 19:59:20.835 User: Admin initiated a switch command (9/Камера/On)
2017-03-13 19:59:20.951 (Xiaomi) Light/Switch (Камера)
2017-03-13 19:59:20.965 {"cmd":"report","model":"plug","sid":"158d00011016d0","short_id":41069,"data":"{\"status\":\"on\"}"}
2017-03-13 19:59:20.965 XiaomiGateway: not updating Domoticz for switch as no change from last state
2017-03-13 19:59:20.985 (Xiaomi) Light/Switch (Камера)
Kwintessens
Post by Kwintessens »
Hi Corbin,
Running Domoticz beta 3.6944 from Jadahl on synology I am still unable to update devices with error Invalid Key.
On raspberry pi running Domoticz it is working great! So great work :)
Currently I am using it as a slave under my other Domoticz.. but this is (obviously) not ideal.. and want to go back to my synology. Could this be a dependency error? If so.. any idea which dependency I might be missing?
corbin
Post by corbin »
hekm77 wrote:Thank you, corbin. v3.6912.
did you git pull the changes from https://github.com/corbinmunce/domoticz?
corbin
Post by corbin »
Kwintessens wrote: Currently I am using it as a slave under my other Domoticz.. but this is (obviously) not ideal.. and want to go back to my synology. Could this be a dependency error? If so.. any idea which dependency I might be missing?
This is probably related to your network adapter not receiving multicast packets. If that is the case, it could be a configuration setting you can change on the Synology, or an error in my code which I don't know how to fix yet. Also could be the Synology is using an older beta version, as I have fixed network issues recently in the main beta.
hekm77
Post by hekm77 »
corbin wrote:did you git pull the changes from https://github.com/corbinmunce/domoticz?
Yes
Kwintessens
Beta versions on both devices are the same :). I will look into the multicast settings.. thank you in advance.
corbin
Post by corbin »
I'm seeing two 'On' events when I turn the plug on.
2017-03-14 06:58:31.796 User: Admin initiated a switch command (17/Xiaomi Smart Projector/On)
2017-03-14 06:58:31.929 LUA: Xiaomi Smart Projector On
2017-03-14 06:58:31.872 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Projector)
2017-03-14 06:58:31.930 {"cmd":"report","model":"plug","sid":"158d00010ec40b","short_id":6903,"data":"{\"status\":\"on\"}"}
2017-03-14 06:58:31.931 XiaomiGateway: not updating Domoticz for switch as no change from last state
2017-03-14 06:58:31.931 {"cmd":"report","model":"plug","sid":"158d00010ec40b","short_id":6903,"data":"{\"status\":\"on\"}"}
2017-03-14 06:58:32.003 LUA: Xiaomi Smart Projector On
murtadin
Post by murtadin »
i have strange behavior with zigbee plug too. Tried V3.6850 and V3.6911. Every command i see in log 2 times:
2017-03-13 23:07:19.871  User: Admin initiated a switch command (24/console.living/On)
2017-03-13 23:07:19.931  (gw.home) Light/Switch (console.living)
2017-03-13 23:07:19.935  {"cmd":"report","model":"plug","sid":"158d000117a188","short_id":9663,"data":"{\"status\":\"on\"}"}
2017-03-13 23:07:19.953  (gw.home) Light/Switch (console.living)
2017-03-13 23:07:19.957  {"cmd":"report","model":"plug","sid":"158d000117a188","short_id":9663,"data":"{\"status\":\"on\"}"}
2017-03-13 23:07:20.022  (gw.home) Light/Switch (console.living)
2017-03-13 23:07:27.192  User: Admin initiated a switch command (24/console.living/Off)
2017-03-13 23:07:27.256  (gw.home) Light/Switch (console.living)
2017-03-13 23:07:27.260  {"cmd":"report","model":"plug","sid":"158d000117a188","short_id":9663,"data":"{\"status\":\"off\"}"}
2017-03-13 23:07:27.278  XiaomiGateway: not updating Domoticz for switch as no change from last state
2017-03-13 23:07:27.278  {"cmd":"report","model":"plug","sid":"158d000117a188","short_id":9663,"data":"{\"status\":\"off\"}"}
2017-03-13 23:07:27.342  (gw.home) Light/Switch (console.living)
2017-03-13 23:07:31.545  User: Admin initiated a switch command (24/console.living/On)
2017-03-13 23:07:31.609  (gw.home) Light/Switch (console.living)
2017-03-13 23:07:31.614  {"cmd":"report","model":"plug","sid":"158d000117a188","short_id":9663,"data":"{\"status\":\"on\"}"}
2017-03-13 23:07:31.631  (gw.home) Light/Switch (console.living)
2017-03-13 23:07:31.635  {"cmd":"report","model":"plug","sid":"158d000117a188","short_id":9663,"data":"{\"status\":\"on\"}"}
2017-03-13 23:07:31.695  (gw.home) Light/Switch (console.living)
2017-03-13 23:07:32.850  User: Admin initiated a switch command (24/console.living/Off)
2017-03-13 23:07:32.912  (gw.home) Light/Switch (console.living)
2017-03-13 23:07:32.916  {"cmd":"report","model":"plug","sid":"158d000117a188","short_id":9663,"data":"{\"status\":\"off\"}"}
2017-03-13 23:07:32.934  XiaomiGateway: not updating Domoticz for switch as no change from last state
2017-03-13 23:07:32.934  {"cmd":"report","model":"plug","sid":"158d000117a188","short_id":9663,"data":"{\"status\":\"off\"}"}
2017-03-13 23:07:33.000  (gw.home) Light/Switch (console.living)
hekm77
Post by hekm77 »
I see two "on" when on and two "off" when off
2017-03-13 22:05:29.423 User: Admin initiated a switch command (9/Камера/On)
2017-03-13 22:05:29.564 (Xiaomi) Light/Switch (Камера)
2017-03-13 22:05:29.581 {"cmd":"report","model":"plug","sid":"158d00011016d0","short_id":41069,"data":"{\"status\":\"on\"}"}
2017-03-13 22:05:29.581 XiaomiGateway: not updating Domoticz for switch as no change from last state
2017-03-13 22:05:29.582 {"cmd":"report","model":"plug","sid":"158d00011016d0","short_id":41069,"data":"{\"status\":\"on\"}"}
2017-03-13 22:05:29.581 (Xiaomi) Light/Switch (Камера)
2017-03-13 22:05:38.915 User: Admin initiated a switch command (9/Камера/Off)
2017-03-13 22:05:38.985 (Xiaomi) Light/Switch (Камера)
2017-03-13 22:05:39.008 {"cmd":"report","model":"plug","sid":"158d00011016d0","short_id":41069,"data":"{\"status\":\"off\"}"}
2017-03-13 22:05:39.066 (Xiaomi) Light/Switch (Камера)
2017-03-13 22:05:39.087 XiaomiGateway: not updating Domoticz for switch as no change from last state
2017-03-13 22:05:39.087 {"cmd":"report","model":"plug","sid":"158d00011016d0","short_id":41069,"data":"{\"status\":\"off\"}"}
Derik
Post by Derik »
Dear All
Great work this Xiaomi, F^*^cking nice stuff.... [ Love Corbin xxx ]
Some one have a battery live of the motions?
Kwintessens
Wasn't able to find any settings on my synology to make any difference. Did a reinstall of Domoticz without success..
I am wondering if anyone is able to run this on Domoticz running on Synology?
deennoo
Post by deennoo »
Just test today on ds216 play dsm 6.1 last beta aviable for syno and all is ok
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
For the ones who are having trouble getting into developer mode here is a good description with screenshots:
https://github.com/fooxy/homeassistant- ... e-dev-mode
kiquof
Post by kiquof »
Hello my name is Christophe and I come to solicit your help for the installation of the XIAOMI GW. I have difficulties. I followed the tutorial https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara) and then I installed the beta of DZ V3.6953. When I select in hardware "XIAOMI GATEWAY" I do not have the fields that appear to enter the IP settings, port and password. On the other hand, when I go through a DNS redirection via DDNS, the options appear !!!!
Je vous joint les logs
2017-03-15 00:12:46.028 XiaomiGateway: will listen on 9898 for hardware id 10
2017-03-15 00:12:46.028 XiaomiGateway: Worker started...
2017-03-15 00:14:01.902 XiaomiGateway: Worker started...
2017-03-15 00:14:01.903 XiaomiGateway: Using 192.168.0.12 for local IP address.
2017-03-15 00:14:01.903 XiaomiGateway: NOT LISTENING TO UDP FOR HARDWARE ID 11
2017-03-15 00:14:11.037 XiaomiGateway: stopped
2017-03-15 00:14:12.788 Incoming connection from: 192.168.0.10
2017-03-15 00:15:42.914 XiaomiGateway: stopped
2017-03-15 00:15:42.915 XiaomiGateway: will listen on 9898 for hardware id 11
2017-03-15 00:15:42.916 XiaomiGateway: Worker started...
2017-03-15 00:15:42.916 XiaomiGateway: Using 192.168.0.12 for local IP address.
Why two different IDs?
PB UDP?
The IP address of the GW is well informed
[Img] http://www.clicweb.eu/Images/Capture3.PNG [/ img]
Before you ask me the questions:
- Yes, I have cleared the cache of my browser, see my browsers ;-)
- I have checked in the devices part, but it remains empty of any XIAOMI devices :(
- firmware version GW 1.4.1_143.0141
In addition tabs not the same titled.
[Img] http://www.clicweb.eu/Images/Capture2.PNG [/ img]
If you have ideas for my integration problem it would be great. Thank you in advance for all the good ideas.
And thank you all for being so passionate and dedicated to your efforts.
DZ Beta V3.6953 / Aeotec Z-Stick S2 / Aeotec Multi Sensor / Xiaomi Gateway /
corbin
Post by corbin »
Have you tried deleting hardware id 11? If that doesn't work, look in the Hardware table in the Domoticz.db database and try deleting from there.
lamouette
Post by lamouette »
After a hard reboot, it's ok now :)
