Locked
EdwinK
Re: Dashticz v2.0, custom positioning and multiple screens
Post by EdwinK »
Hi @Robgeerts
Any change the font-size of these can be increased a bit. Maybe with a custom css?
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Blueone wrote:
robgeerts wrote:If you want the text to be white, add to custom.css:
.standby .row {
	opacity:1 !important;
I cannot use cgi in my scripts.
I could make a setting that the dashboard has to call an url when going to standby.
Isn't it possible to call this url http://127.0.0.1/cgi-bin/screen_brightn ... ghtness=11 when this script is added by the user? If not, I can also create a simple HTML which can be put in the webserver which run's the cgi.
In the latest version, just released, you can use this in your config.js:
var _STANDBY_CALL_URL		= 'http://127.0.0.1/cgi-bin/screen_brightness.cgi?brightness=11';
robgeerts
Post by robgeerts »
EdKo66 wrote:Hi @Robgeerts
Try adding this to custom.css:
.col-data .title {
	font-size:14px;
.col-data span {
	font-size:16px;
Dingetje2004
Post by Dingetje2004 »
Maybe the updated wiki can help you out? Check the last part with a couple of variables for custom icon en text settings ;) This helped me out this morning.
.fa.fa-lightbulb-o.on {
    color: rgba(0,255,0,1)
.fa.fa-lightbulb-o.off {
   color: rgb(255, 28, 133)
.fa-thermometer-half:before{
    font-size: 24px;
    font-weight: 1200;
    color: rgb(255, 245, 0)
Last edited by Dingetje2004 on Saturday 15 April 2017 12:13, edited 2 times in total.
EdwinK
Post by EdwinK »
Thanks both. :)
Blueone
Post by Blueone »
Thanks! I will also make some text for the wiki so other people can use it easyly. Next job: putting the touchscreen to the wall, this dashboard really gives extra value to domoticz!
On minor the thing, the brightness has to be set back to a new brightness when it comes out of stand-by, so two values are needed.
pvdhelm
Post by pvdhelm »
tnx EdKo66 now it works
Dropshot
Post by Dropshot »
Could it be possible to see the graps, of for instance the temperature, when I press on the block?
freakshock
Post by freakshock »
robgeerts wrote:
freakshock wrote:Hi Rob,
Amazing dashboard! I like how most of it works straight out of the box. One question, is it normal behavior that the buienradar image does not refresh on its own? Does it only refresh with a full page refresh? Tested this with chrome on android and Windows. Thanks
I just tested this in latest version and its working for me...
Could you test this??
The image refreshes correctly now,thanks Rob!
wizjos
Post by wizjos »
Thanks @westd001!
I've got it up and running on my PI!
Regards,
Wizjos
b00n
Post by b00n »
Hellow,
is anyone having the same issue i'm only getting emty boxes for my switches ?
robgeerts
Post by robgeerts »
What is the content of your config.js?
And do you get any error in console? (f12)
EdwinK
Post by EdwinK »
b00n wrote:Hellow,
Looks like there is an error in your CONFIG.js. Check your IDX's
freakshock
b00n wrote:Hellow,
If you share your config.js we van help you better :)
I encountered a new error with the latest commit, where my dimmer switches are not working in the on/off function. If the light is on I can however change the brightness.
This is the console code:
VM2218:27 Uncaught TypeError: idx.substr is not a function
    at switchDevice (eval at <anonymous> (jquery.min.js:2), <anonymous>:27:9)
    at HTMLDivElement.onclick (index.html:1)
robgeerts
Post by robgeerts »
Excuse me!
Should be fixed in latest version!
freakshock
robgeerts wrote:Excuse me!
Two minutes, now that's what I call a quick fix :lol: Thanks!
freakshock
Dropshot wrote:Could it be possible to see the graps, of for instance the temperature, when I press on the block?
That would be an amazing feature!
maluko
Post by maluko »
HansieNL wrote:
maluko wrote:i am trying to add a virtual swicth that control my irrigation zone system, but i am facing with this problem:
virtual swich is placed on "rega" plan and hiden on main plan, so can´t see on dashboard, if i bring back to main next came back to dash.
can i contorn this?
thanks.
You have to use var _USE_FAVORITES = false
allways use this but seem to not show when switch are hiden.
var _USE_AUTO_POSITIONING 	= false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES			= false; //only used when using auto positioning
b00n
Post by b00n »
Do i miss something?
CONFIG.js
(3.6 KiB) Downloaded 66 times
Dropshot
Post by Dropshot »
robgeerts wrote:
Dropshot wrote:
robgeerts wrote:
Could you send me the output of that device?
Here is the output:
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CustomImage: 0,
Data: "67 mirek",
Description: "",
Favorite: 1,
HardwareID: 4,
HardwareName: "Dummy",
HardwareType: "Dummy (Does nothing, use for virtual switches only)",
HardwareTypeVal: 15,
HaveTimeout: false,
Image: "Custom",
LastUpdate: "2017-04-14 09:24:00",
Notifications: "false",
PlanID: "0",
PlanIDs: [
0
Protected: false,
SensorType: 1,
SensorUnit: "mirek",
ShowNotifications: true,
SignalLevel: "-",
SubType: "Custom Sensor",
Timers: "false",
Type: "General",
TypeImg: "Custom",
Unit: 1,
Used: 1,
XOffset: "0",
YOffset: "0",
idx: "157"
In latest version the icon is a question mark, now you can override this icon too..
Thank you, I've the icon working now! Is it also possible to switch the title and value for the custom sensors? As I've showed earlier, it's different compared to temperature and lux for instance:
Locked
