Trunald
Post by Trunald »
Please excuse me if this information is already somewhere, but I couldn't find via searching; is there any forecast when the Xiaomi integration would be available in the official release of Domoticz? Just did the basic setup of it with the official version, so I wouldn't want to start playing with the beta, but I would really like to use the sensors that I have on the Xiaomi gateway. Even managed to give the gateway a fixed IP via my router's MAC-based DHCP table, so would be all set from that side.
robertje221
Post by robertje221 »
last week i received the xiaomi home hub and a temperature sensor. I added the system to domoticz and it is working fine. Only when i restart the xiaomi home hub, the temperature sensor is displaying 100 ' C . In the xiaomi app the temperature sensor is displaying a correct value of 19 ' C.
is there something i can do about this?
robertje221
already found it.
just push the button on the temp sensor and the values are correct again in domoticz
deennoo
Post by deennoo »
Trunald wrote:Please excuse me if this information is already somewhere, but I couldn't find via searching; is there any forecast when the Xiaomi integration would be available in the official release of Domoticz? Just did the basic setup of it with the official version, so I wouldn't want to start playing with the beta, but I would really like to use the sensors that I have on the Xiaomi gateway. Even managed to give the gateway a fixed IP via my router's MAC-based DHCP table, so would be all set from that side.
Xiaomi Aqara compatibility is still on développement, surely Domoticz won't realase à stable just for xiaomi hardware.
You have to be patient
http://domo-attitude.fr
Trunald
Post by Trunald »
deennoo wrote: Xiaomi Aqara compatibility is still on développement, surely Domoticz won't realase à stable just for xiaomi hardware.
Thank you for your reply. So, do I understand correctly that the Xiaomi support would be included in the next official release?
n1c0l45
Domoticz version: V3.4834
Post by n1c0l45 »
did someone manage to get xiaomi switch (double click, long click, etc...) to work fully with scenes? i just get one action trigger. If i do click, double click, long click its same action? scenes don't see the differents type of trigging, just "click" :s
hekm77
Post by hekm77 »
n1c0l45 wrote:did someone manage to get xiaomi switch (double click, long click, etc...) to work fully with scenes? i just get one action trigger. If i do click, double click, long click its same action? scenes don't see the differents type of trigging, just "click" :s
Names of the switch state that you use in scenes is "Click", "Double Click", "Long Click"?
deennoo
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by deennoo »
Surely Corbin is close to the goal for this FW, we are now waiting for the Aqara Fw update who will provid some new feature (playing present sound on the gateway and your personnal one, gateway will provid room luminosity value and batterie for some sensor)
Stay connected !
deennoo
Post by deennoo »
I got 2 of them and no problème here.
You have to take Time to learn how to "click".
Which domoticz version you have ?
deennoo
Post by deennoo »
Name are :
Click
Double Click
Long Click press
Long Click release
As this is still on beta, because it take Times to be perfect update your domoticz version every day to check what's new.
Or wait for stable
murtadin
Post by murtadin »
I wonder if xiaomi will implement development mode for wi-fi plugs? I have 3 sockets and they will be almost useless if not.
Sent from my MI MAX using Tapatalk
marcotrumpet
Post by marcotrumpet »
Speaking of "click"... I use the switch in mihome app to "rurn on/off" a yeelight bulb. How can I do the same thing in domoticz? I tried with blocky (like "if off click turn on else if off click turn off) and I obtain a funny loop in the log :D
hekm77
Post by hekm77 »
marcotrumpet wrote:Speaking of "click"... I use the switch in mihome app to "rurn on/off" a yeelight bulb. How can I do the same thing in domoticz? I tried with blocky (like "if off click turn on else if off click turn off) and I obtain a funny loop in the log :D
if switch = click and bulb = on then bulb = off
if switch = click and bulb = off then bulb = on
marcotrumpet
I did but I was into loop
deennoo
Post by deennoo »
Which kind of switch ? The wireless wall one or the round one ?
Which gateway fw
We need to know that
marcotrumpet
deennoo wrote:
marcotrumpet wrote:
hekm77 wrote: if switch = click and bulb = on then bulb = off
Which gateway fw
You're right, I'm sorry.
I'm using the round switch on 3.10.0 fw gateway version in domoticz 6863 beta version.
Schermata 2017-03-05 alle 12.28.38.png (121.01 KiB) Viewed 2645 times
rtenklooster
Post by rtenklooster »
After waiting for over a month i finally received my gateway and two human body sensors.
I Love them, and your work on the plugin, integrating this into domoticz.
However, i also like the built in functionality in the mi home IoS app, actions and triggers.
A also have two yeelight bulbs, they work fine together.
Is there also an opportunity to send actions to the gateway, like: play alarm, or sound x?
deennoo
Re: RE: Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by deennoo »
marcotrumpet wrote:
deennoo wrote:
marcotrumpet wrote: I did but I was into loop
Which gateway fw
Hum forget about blocky event "switch" for LUA, more flexible more Powerfull.
marcotrumpet
deennoo wrote:
marcotrumpet wrote:
deennoo wrote: Which kind of switch ? The wireless wall one or the round one ?
Which gateway fw
I know hut I need time to study it.. at thw time it's ok with mihome app.
deennoo
Re: RE: Re: RE: Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by deennoo »
But LUA is your only solution, perfection need some works on DIY
