FlatZ Frontpage
- galadril
- Domoticz version: latest
Re: FlatZ Frontpage
I did found a problem in the lights.html:
<script type="text/javascript" src="http://code.jquery.com/jquery-2.1.4.min.js"></script>
should be:
<script type="text/javascript" src="js/jquery-2.1.4.js"></script>
should be:
- galadril
Re: FlatZ Frontpage
Please check the latest verions:
https://github.com/galadril/FlatZ-Frontpage
- I've added a News page (rss)
- Lot's of fixes bij Patrick (for ipad/device, Rounded css added, fix for Kaku dimmers, etc)
- news.png (61.76 KiB) Viewed 4322 times
SwordFish
- Domoticz version: V4.11375
Re: FlatZ Frontpage
Verry nice.
Are you also working to at scenes to frontpage?
That will be awesome.
- mvveelen
Re: FlatZ Frontpage
Uploaded the last version, and the dim level just doesn't seem to go well.galadril wrote:Krommenie yesmvveelen wrote:I haven't looked at the code yet, because I'm facing some other challenges, but maybe I can try to find out where it goes wrong. What parts do I have to look at exactly?(Assendelft)..
But please check the methods.js, it happens in this function:
function setLightDimmer(idx, bright)
If you compare the json calls with the json calls of Domoticz itself, maybe you can find the problem..
If I take a look at the other frontpage, the code for the dim level is like this (there seems to be a little trick to get the right dim levels):
function ChangeStatus(OpenDicht,level,idx,currentlevel)
//When switched off return to previous level, no matter if plus or min pressed
if (level == txt_off) {
if (currentlevel == 1) {
currentlevel++;
//console.log("In uit",currentlevel);
$.ajax({
url: $.domoticzurl+"/json.htm?type=command¶m=switchlight&idx=" + idx + "&switchcmd=Set Level&level=" + currentlevel,
async: false,
dataType: 'json',
success: function(){
console.log('SUCCES');
error: function(){
console.log('ERROR');
level = level * 1;
//console.log(OpenDicht,level);
if (OpenDicht == "plus")
var d = ((level + 10)/100 * 16) + 0.5;
if(d > 16) {
d = 16;
$.ajax({
url: $.domoticzurl+"/json.htm?type=command¶m=switchlight&idx=" + idx + "&switchcmd=Set Level&level=" + d,
async: false,
dataType: 'json',
error: function(){
var d = ((level-0.1 )/100*16) ;
//console.log("in min",d,level);
if( d < 0 ){
d = 0;
$.ajax({
async: false,
dataType: 'json',
error: function(){
RefreshData();
bickel
Re: FlatZ Frontpage
Great project!
Is it already possible to add setpoint devices? I have several danfoss radiator thermostats i would like to see.
Several people already asked for webcam support...i'd like to support that feature also.
Another small nice to have would be the ability to centralized disable some menu items, like logs and news.
Gr,
ROnald
Gr,
ROnald
Patrick
- Domoticz version: 3.5877
Re: FlatZ Frontpage
What isn't going well?mvveelen wrote:Uploaded the last version, and the dim level just doesn't seem to go well.
So the value is divided by 16 and there is a .5 added for rounding the values to the right values?! So, the level is not in %, but in steps. Is there a way you can add / change this in a next version?Code: Select all
function ChangeStatus(OpenDicht,level,idx,currentlevel) { //When switched off return to previous level, no matter if plus or min pressed if (level == txt_off) { if (currentlevel == 1) { currentlevel++; } //console.log("In uit",currentlevel); $.ajax({ url: $.domoticzurl+"/json.htm?type=command¶m=switchlight&idx=" + idx + "&switchcmd=Set Level&level=" + currentlevel, async: false, dataType: 'json', success: function(){ console.log('SUCCES'); }, error: function(){ console.log('ERROR'); } }); } else { level = level * 1; //console.log(OpenDicht,level); if (OpenDicht == "plus") { var d = ((level + 10)/100 * 16) + 0.5; if(d > 16) { d = 16; } $.ajax({ url: $.domoticzurl+"/json.htm?type=command¶m=switchlight&idx=" + idx + "&switchcmd=Set Level&level=" + d, async: false, dataType: 'json', success: function(){ console.log('SUCCES'); }, error: function(){ console.log('ERROR'); } }); } else { var d = ((level-0.1 )/100*16) ; //console.log("in min",d,level); if( d < 0 ){ d = 0; } $.ajax({ url: $.domoticzurl+"/json.htm?type=command¶m=switchlight&idx=" + idx + "&switchcmd=Set Level&level=" + d, async: false, dataType: 'json', success: function(){ console.log('SUCCES'); }, error: function(){ console.log('ERROR'); } }); } } RefreshData(); }
I'm testing with a KaKu dimmer module and I can't detect any problems.
In settings.js you need to set the maxDimLevel (16 when KaKu), the formula transforms the 0-100 slider value to 0-maxDimLevel value.
- mvveelen
Re: FlatZ Frontpage
So I have to add the , '16' to get it to work? Will do tomorrow and test it. Thanks !
Patrick
Re: FlatZ Frontpage
Yep, in settings.js there's a extra variable added to define the maxDimLevel.mvveelen wrote:So I have to add the , '16' to get it to work? Will do tomorrow and test it. Thanks !
If the code reads no maxDimLevel it will set maxDimLevel to 100.
- galadril
Re: FlatZ Frontpage
In latest version: https://github.com/galadril/FlatZ-FrontpageAnother small nice to have would be the ability to centralized disable some menu items, like logs and news.
In settings.js:
//Menu settings
$.Graph = true;
$.News = true;
$.Log = true;
$.Lights = true;
$.Weather = true;
We're looking into your other requests!
- galadril
Re: FlatZ Frontpage
Working on it, It's now working with camera image url...Several people already asked for webcam support...i'd like to support that feature also.
SwordFish
Re: FlatZ Frontpage
Looks great.
I asked before do you have plans to ad scenes to the frontpage (maybe you over see it)?
- galadril
Re: FlatZ Frontpage
I'll look into itSwordFish wrote:add scenes to the frontpage (maybe you over see it)?
- mvveelen
Re: FlatZ Frontpage
Great, got the dim levels working. My bad....
Question though: is it possible to update the % of the dim level too? When I have it at 53% and I set it to, let's say 100%, it keeps displaying the 53%
Would be nice to see the right % at the same time I change it.
SwordFish
Re: FlatZ Frontpage
That would be great.galadril wrote:I'll look into itSwordFish wrote:add scenes to the frontpage (maybe you over see it)?
- Minglarn
- Domoticz version: v3.8153
Re: FlatZ Frontpage
OMG! =)galadril wrote:Working on it, It's now working with camera image url...Several people already asked for webcam support...i'd like to support that feature also.
Cant wait...
- mvveelen
Re: FlatZ Frontpage
Aside from the % status for the dim level, I have some questions:
- I have Kodi on my RPi and I'm trying to add the Kodi status to the frontpage. All it shows is....nothing. Only an image. Is it possible or am I trying something that hasn't been added (yet)?
- When I look at my power consumption, it shows me:
606 Watt
Today:
6.674 kWh
Total:
890697;793095;0;0;606;0
What about the "Total:" ? A lot of numbers, but it doesn't make sense to me. Am I forgetting something?
- is it possible to make the "switch toggled" pop-up-thingy optional? It's slowing the switching down, so I'd rather have it off or deleted....
606 Watt
Today:
6.674 kWh
Total:
CodeItAway
Re: FlatZ Frontpage
First of all, compliments for your hard work.
I think something went wrong with one of the latest commits. Some files have text like these in them:
<<<<<<< HEAD
- mvveelen
Re: FlatZ Frontpage
Just wanted 1 thing to add to my list of heavy demands
The left column shows the lights. ON or OFF. When it's OFF, everything is fine.
When it's ON, the lights with a dimmer, show the level.....and that is kind of....ugly. The level (text) runs through the text of the light under it, if you know what I mean. Could the level in the left column be set to 'not show' ?
Heisenberg
Re: FlatZ Frontpage
Hi galadril, where do I modify the url streams for the IP cameras?galadril wrote:Working on it, It's now working with camera image url...Several people already asked for webcam support...i'd like to support that feature also.
Also in the camera.html I don't see the navigation on the left (Switches) anymore
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
