New Aeon Labs Multisensor Gen5 not supported in OpenZwave ?
Doume
Domoticz version: 8038
Re: New Aeon Labs Multisensor Gen5 not supported in OpenZwav
Post by Doume »
OK, thanks, I'll try soon
Plaagje
Domoticz version: Latest
Post by Plaagje »
Gettingthere wrote:Just wondering... How did ye include yer sensor? Because I see your hardware is yer Motherboard, and mine is my Z-Stick. Also I don't recognize the 'burglar' switch...
I added the line to the xml file as IDavid stated.
Then i entered inclusion mode:
and pressed the button on the Aeon 3 times.
Now i have the following devices:
TheSpanishInq
Post by TheSpanishInq »
gizmocuz wrote:latest beta is using the security branch now, hope its working ;)
Thanks! 8-)
Seems to work with 2418 as well, with the security branch I pulled from OZW.
Good to see it's in Domoticz native though, so I can skip a few copy/edit statements with future updates. :)
I'm a but confused about the device-list though. Device #31 (in my setup) seems to be the viable motion sensor. I'd already renamed it so I don't know what name it had when it was detected. Device #29 and #30 get updated too and #32 seems to remain ON. Device #21 showed up when I pressed the include button on the multisensor but doesn't seem to get updates thereafter.
Is this by design or do I need to upgrade to latest trunk to get it wright?
Domoticz on Debian AMD64 with Aeon Z-Stick. V2020.2 (build 12900)
ZME_RC2
gizmocuz
Post by gizmocuz »
Nothing changed besides the security branch.... Something not working anymore?
TheSpanishInq
It does seem to work OK, I just found it odd that the device IDs I mentioned show up and don't get any update (not seen in Domoticz thereafter) or remain ON or OFF all the time. Wondered if that is by design with this multisensor.
ZME_RC2
gizmocuz
Post by gizmocuz »
Unfortunately i do not know this sensor, but can you tell if you receive all possible sensors from it, and that they are updating?
(could be some time before some of them update , this so the battery lasts 2 years)
- PIR
- Temp
- Humidity
- Light
Doume
Post by Doume »
Doume wrote:OK, thanks, I'll try soon
Just updated to version 2427 :
Now, the Zwave network seems to be handled in a better way (it doesn't stay anymore in 'red' state )
The Siren Aeon G5 seems to be 'seen' correctly (The 'panic' state has been resetted) , but I can't modify the specific parameters of the siren ( volume, sound type, and so on)
A big step forward, for sure....
TheSpanishInq
gizmocuz wrote: - PIR
- Temp
- Humidity
- Light
I do have those, which get regular updates. The sensor is receiving power from mains via an USB-power-adapter and I've setup the sensor to send updates every 5 minutes. The PIR sends an ON when it is off and montion is detected and sends an OFF when it was on and hasn't seen motion within the timeout that's set for that (240 seconds).
Besides these devices OZW sees several other devices that I don't know off. Two literally are called 'Unknown', another 'Level', with a green arrow behind them indicating I can add them to Domoticz.
They are shown in the screenshot I posted above too (IDs 21, 27 and 35). The ones that get updated regularly have the time stamp highlighted.
The device with ID 31 still is ON (and gets updated), but I've no what it's for either.
ZME_RC2
cpighin
Domoticz version: 3.8153
Post by cpighin »
:) I tried to include my new Aeotec Multisensor6 ZW100-C and the result is showed here
You may see that the sensor seems not to be correctly included since Domoticz (V2.2563) considers it as "Aeotec Unknown: type=0002, id=0064".
What should I do?
Claudio :)
TheSpanishInq
You'll probably have to upgrade Domoticz :| Support for the sensor is in the more recent versions. Dunno if it is in the beta binary for RPi.
ZME_RC2
cpighin
Post by cpighin »
:) I'm running Domoticz (V2.2563) and I cheched file /home/pi/domoticz/Config/manufacturer_specific.xml and I have found following line inside the "<Manufacturer id="0086" name="Aeotec">" part
<Product type="0002" id="004a" name="Multi Sensor Gen5" config="aeotec/multisensor_gen5.xml"/>
and in /home/pi/domoticz/Config/aeotec I see file multisensor_gen5.xml
Claudio :)
cpighin
Post by cpighin »
:) May anyone give any tip to correctly install new New Aeon Labs Multisensor Gen5?
Claudio :)
TheSpanishInq
You mentioned you have a Multisensor 6. In my manufacturer_specific.xml this show up:
<Product type="0002" id="0064" name="MultiSensor 6" config="aeotec/multisensor6.xml" />
<Product type="0102" id="0064" name="MultiSensor 6" config="aeotec/multisensor6.xml" />
<Product type="0202" id="0064" name="MultiSensor 6" config="aeotec/multisensor6.xml" />
First line seems to match... I guess you'll have to upgrade Domoticz.
ZME_RC2
cpighin
Post by cpighin »
:) I'm running Domoticz (V2.2563) which is te last one ;)
Claudio :)
TheSpanishInq
That's probably the latest stable. If you want Domoticz support for your sensor you'll have to compile the latest beta your self/use the latest beta binary. It's described in the wiki.
ZME_RC2
cpighin
Post by cpighin »
Hi :)
I did few trials to overcome the issue but I had no success.
Among the various actions done I mention the repeated exclusions from the system of Aeotec Multisensor6 ZW100-C, that from now on I will call MultisensorGen5, followed by three inclusions.
Domoticz has never recognized properly MultisensorGen5 and has always included as "Unknown Aeotec: type = 0002, id = 0064" even if in file was /home/pi/domoticz/Config/manufacturer_specific.xml I found the following line in the "<Manufacturer id =" 0086 "name =" Aeotec ">"
and in /home/pi/domoticz/Config/aeotec file multisensor_gen5.xml was there.
It may perhaps be useful to inform that as a result of the three inclusions, Domoticz generated
8 devices in the first,
5 devices in the second,
7 devices in the third.
(if useful I can report on the various devices generated)
My understanding is that even if Domoticz has good data to use, it did not do as supposed. Why?
Is there a possibility to force Domoticz to use the right file to configure the MultisensorGen5?
Claudio :)
TheSpanishInq
Are you sure? id=004a != id=0064...
Upgrade? ;)
You could try to pull the specific config files from OZW-git. See if that 'll suffice.
ZME_RC2
cpighin
Post by cpighin »
:) Any help to include correctly a Multisensor Gen5 on Domoticz?
Claudio :)
TheSpanishInq
Nope, not anymore. You don't seem to like my suggestions. Waste of time.
ZME_RC2
pvm
Domoticz version: 4.10538
Post by pvm »
what about making an image of your current install. Switch Domoticz to beta channel,update , exclude, and include again. Latest gen5 can require latest openzwave lib.
When this does not work, restore the original image
