Today my 3EM arrived. Can you add this to your plugin?
{"device":{"type":"SHEM-3","mac":"8CAAB561D496","hostname":"shellyem3-8CAAB561D496","num_outputs":1,"num_meters":0,"num_emeters":3,"report_period":1},"wifi_ap":{"enabled":false,"ssid":"shellyem3-8CAAB561D496","key":""},"wifi_sta":{"enabled":true,"ssid":"","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"ap_roaming":{"enabled":false,"threshold":-70},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellyem3-8CAAB561D496","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"OPSoqf","name":"Zuleitung HAK","fw":"20210413-154243/v1.10.2-gb89901a","discoverable":false,"build_info":{"build_id":"20210413-154243/v1.10.2-gb89901a","build_timestamp":"2021-04-13T15:42:43Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":true},"timezone":"Europe/Berlin","lat":50.937931,"lng":6.878530,"tzautodetect":true,"tz_utc_offset":7200,"tz_dst":true,"tz_dst_auto":true,"time":"14:00","unixtime":1618660820,"led_status_disable":false,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["out_on_url","out_off_url","over_power_url","under_power_url","over_power_url","under_power_url","over_power_url","under_power_url","over_power_url","under_power_url"]},"hwinfo":{"hw_revision":"prod-2020-1", "batch_id":1},"relays":[{"name":null,"ison":false,"has_timer":false,"default_state":"off","auto_on":0.00,"auto_off":0.00,"schedule":false,"schedule_rules":[]}],"emeters":[{"name":null,"appliance_type":"General","max_power":0},{"name":null,"appliance_type":"General","max_power":0},{"name":null,"appliance_type":"General","max_power":0}],"wifirecovery_reboot_enabled":true}
{"wifi_sta":{"connected":true,"ssid":"","ip":"192.168.0.60","rssi":-42},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"14:01","unixtime":1618660881,"serial":342,"has_update":false,"mac":"8CAAB561D496","cfg_changed_cnt":5,"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"is_valid":true,"source":"input"}],"emeters":[{"power":134.73,"pf":0.59,"current":0.99,"voltage":231.84,"is_valid":true,"total":68.2,"total_returned":16.2},{"power":131.37,"pf":0.51,"current":1.11,"voltage":231.84,"is_valid":true,"total":89.8,"total_returned":22.5},{"power":22.94,"pf":0.61,"current":0.16,"voltage":231.18,"is_valid":true,"total":6.9,"total_returned":0.3}],"fs_mounted":true,"update":{"status":"idle","has_update":false,"new_version":"20210413-154243/v1.10.2-gb89901a","old_version":"20210413-154243/v1.10.2-gb89901a"},"ram_total":48784,"ram_free":29728,"fs_size":233681,"fs_free":156122,"uptime":1890}
