The problem is that it is on a Synology. The pip package does install correctly, I also see it. Butthe domoticz installation doesn't find that pip installation folder because it looks at a python folder in it's own installation folder. I don't know why Domoticz is doing that on a Synology.Xavier82 wrote: Wednesday 28 October 2020 19:18 which python version do you have?
Are u using a Raspberry Pi or something else?
For Rpi go to cli (with Putty).
then enter "python -V" (without the ")
this will show which python 2 version you have.
next enter "python3 -V".
this will show which python3 version you have.
then enter "sudo su -" and give password.
You should now be able to enter the next command:
"pip install requests" (this is the command for python version2)
or
"pip3 install requests"
(this is the command for python3)
if everything is ok the requests library should be installed and the script should work.
ShellyCloudPlugin
Re: ShellyCloudPlugin
mariopeters
I think I know the problem.
In the past I also installed Domoticz on a Synology NAS.
Did you also install python3 from Synology.
If so you are using the python version located in (depending on how many volumes you have).
In this directory you will another directory where you need to place the requests lib.
/volume1/@appstore/py3kIn this directory you will another directory
/usr/local/lib/python3.5Re: ShellyCloudPlugin
Unfortunately still the same error. If I look in the folder "/volume1/@appstore/py3k/usr/local/lib/python3.5/site-packages" the requests folder is there. But my domoticz installation is looking in: /usr/local/domoticz/lib/python3.7/site-packages, which is basically a subfolder in the Domoticz folder. Don't know why it is like that..mariopeters wrote: Saturday 31 October 2020 10:42 I think I know the problem.
If so you are using the python version located in(depending on how many volumes you have).Code: Select all
In this directory you will another directorywhere you need to place the requests lib.Code: Select all
DarkG
- Domoticz version: 4.10076
why do you not copy the folder?
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
DarkG
Can someone please edit the script für Shelly 1.
My log is full with this for all my shelly 1 devices. and that are many devices
2020-11-12 00:58:32.265 Error: (badezimmer) 'onHeartbeat' failed 'KeyError'.
2020-11-12 00:58:32.265 Error: (badezimmer) ----> Line 209 in '/home/pi/domoticz/plugins/ShellyCloudPlugin-master/plugin.py', function onHeartbeat
2020-11-12 00:58:32.265 Error: (badezimmer) ----> Line 174 in '/home/pi/domoticz/plugins/ShellyCloudPlugin-master/plugin.py', function onHeartbeat
2020-11-12 00:58:32.265 Error: (badezimmer) ----> Line 388 in '/home/pi/domoticz/plugins/ShellyCloudPlugin-master/plugin.py', function updateSHSW1
2020-11-12 00:58:32.265 Error: (badezimmer) ----> Line 497 in '/home/pi/domoticz/plugins/ShellyCloudPlugin-master/plugin.py', function updateMeter
with the 2.5 modules there is no problem
darrepac
On my side, it is working ok but the log has a lot of error like this:
HTTPConnectionPool(host='192.168.0.54', port=80): Max retries exceeded with url: /status (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x6071b190>, 'Connection to 192.168.0.54 timed out. (connect timeout=10)'))
mariopeters
Domoticz doen't like long http requests.darrepac wrote: Wednesday 18 November 2020 7:50 On my side, it is working ok but the log has a lot of error like this:HTTPConnectionPool(host='192.168.0.54', port=80): Max retries exceeded with url: /status (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x6071b190>, 'Connection to 192.168.0.54 timed out. (connect timeout=10)'))
So for the most of the requests I added a timeout of 10 seconds.
In your example the status update (health check) took longer than 10 seconds.
In my opinion this is very long for a simple request on a local network.
Perhaps you could try to reproduce it from a command line or browser to check whether or not you have latency on your network.
I've installed shellies and this plugin for domoticz. All works fine until one of the shelly (shelly 1) disconnect from the wifi and never reconnect to it.
Consequently, a lot of errors logged by the plugin in domoticz due to the disconnection.
I've tried to disable the device (don't want to delete it) in domoticz but no action in the logs;
Is it possible to change the plugin in order to log only if the device is enable in order to stop the disconnection error logs (every 30s).
EDIT : I've tried do delete the shelly devices (3 per shelly 1) created by the plugin, but the errors logs doesnt stop =》 how can we properly delete a device ? Do i have to restart domoticz ?
EDIT2 : I've tried to restart domoticz => nothing new, i've tried to delete "__pycache__" under plugin directory and restart domoticz but nothing new, onHeartbeat is called every 30s but with the 3 shellies instead of 2 (1 deleted)
i answer myself : the only way i've found is to delete the line of the hardware directly in the hardware table of the domoticz DB
Works fine
I think it should be possible to delete the hardware added directly in the hardware GUI page
Works fine
zuputrus
- Domoticz version: 2022.1
Since it's possible to have 2 router at home, one master and other repeating signal, but instead of 192.168.1.xxx it could be 192.168.31.xxx.
How could be possible to detect one shelly device connected to second wifi? It doesn't work for me, at least.
I have some shellys devices in first wifi 192.168.1.xx and plugin works perfectly, but when i try to add other shelly in second wifi domoticz says that has created devices but really it doesn't.
samourai47
Hello
I installed my first shelly device with cloud. I found this plugin and i want to try
I installed and i have some errors
With a dummy capteur i wroks with this instruction
Have an idea aund can you give me some help
Thank's
2021-01-28 07:51:35.291 Error: (Shelly) 'onHeartbeat' failed 'ConnectionError'.
2021-01-28 07:51:35.291 Error: (Shelly) ----> Line 230 in '/home/pi/domoticz/plugins/Shelly/plugin.py', function onHeartbeat
2021-01-28 07:51:35.291 Error: (Shelly) ----> Line 195 in '/home/pi/domoticz/plugins/Shelly/plugin.py', function onHeartbeat
2021-01-28 07:51:35.291 Error: (Shelly) ----> Line 75 in '/usr/lib/python3/dist-packages/requests/api.py', function get
2021-01-28 07:51:35.291 Error: (Shelly) ----> Line 60 in '/usr/lib/python3/dist-packages/requests/api.py', function request
2021-01-28 07:51:35.291 Error: (Shelly) ----> Line 533 in '/usr/lib/python3/dist-packages/requests/sessions.py', function request
2021-01-28 07:51:35.291 Error: (Shelly) ----> Line 646 in '/usr/lib/python3/dist-packages/requests/sessions.py', function send
2021-01-28 07:51:35.291 Error: (Shelly) ----> Line 498 in '/usr/lib/python3/dist-packages/requests/adapters.py', function send
2021-01-28 08:36:20.467 Error: Error parsing http request.
2021-01-28 08:36:21.022 Error: Error parsing http request.
2021-01-28 08:36:21.565 Error: Error parsing http request.
2021-01-28 08:36:22.109 Error: Error parsing http request.
2021-01-28 08:38:18.680 Error: (Shelly) HTTPConnectionPool(host='192.168.0.91', port=80): Max retries exceeded with url: /status (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x623eef70>, 'Connection to 192.168.0.91 timed out. (connect timeout=10)'))
2021-01-28 08:54:00.182 Error: (Shelly) HTTPConnectionPool(host='192.168.0.91', port=80): Max retries exceeded with url: /status (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x623ef190>, 'Connection to 192.168.0.91 timed out. (connect timeout=10)'))
2021-01-28 08:54:39.727 Error: (Shelly) HTTPConnectionPool(host='192.168.0.91', port=80): Max retries exceeded with url: /status (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x623ef590>, 'Connection to 192.168.0.91 timed out. (connect timeout=10)'))
2021-01-28 08:55:12.405 Error: (Shelly) 'onHeartbeat' failed 'ConnectionError'.
2021-01-28 08:55:12.406 Error: (Shelly) ----> Line 230 in '/home/pi/domoticz/plugins/Shelly/plugin.py', function onHeartbeat
2021-01-28 08:55:12.406 Error: (Shelly) ----> Line 195 in '/home/pi/domoticz/plugins/Shelly/plugin.py', function onHeartbeat
2021-01-28 08:55:12.406 Error: (Shelly) ----> Line 75 in '/usr/lib/python3/dist-packages/requests/api.py', function get
2021-01-28 08:55:12.406 Error: (Shelly) ----> Line 60 in '/usr/lib/python3/dist-packages/requests/api.py', function request
2021-01-28 08:55:12.406 Error: (Shelly) ----> Line 533 in '/usr/lib/python3/dist-packages/requests/sessions.py', function request
2021-01-28 08:55:12.406 Error: (Shelly) ----> Line 646 in '/usr/lib/python3/dist-packages/requests/sessions.py', function send
2021-01-28 08:55:12.406 Error: (Shelly) ----> Line 516 in '/usr/lib/python3/dist-packages/requests/adapters.py', function send
2021-01-28 08:55:51.980 Error: (Shelly) HTTPConnectionPool(host='192.168.0.91', port=80): Max retries exceeded with url: /status (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x623efd90>, 'Connection to 192.168.0.91 timed out. (connect timeout=10)'))
2021-01-28 08:56:31.558 Error: (Shelly) HTTPConnectionPool(host='192.168.0.91', port=80): Max retries exceeded with url: /status (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x6238c1b0>, 'Connection to 192.168.0.91 timed out. (connect timeout=10)'))
2021-01-28 08:57:04.246 Error: (Shelly) 'onHeartbeat' failed 'ConnectionError'.
2021-01-28 08:57:04.246 Error: (Shelly) ----> Line 230 in '/home/pi/domoticz/plugins/Shelly/plugin.py', function onHeartbeat Code: Select all
http://192.168.0.91/relay/0?turn=onThank's
extremeaudio
Hi, I installed the plugin but cannot see it in the hardware list.
Log gives error .
What could be the issue?
Log gives error .
Error: PluginList: Parsing '/home/pi/domoticz/plugins/ShellyCloudPlugin/', 'Error document empty.' at line 0 column 0 in XML ''.-
DarkG
empty xml in folder
extremeaudio
Empty XML in which folder? The Shelly plugin folder only has a plugin.py file and a readme file. There is no XML.
Here is how I installed ..
From WinSCP
Created a folder called ShellyCloud under Domoticz-Plug-ins
Copied the plugin.py and readme.md files into the folder
Changed permissions to 0777 or whatever has the max rights by right clicking on the files and from properties
Restart Domoticz
Ignore everything. Got it working. Was not following the correct procedure for installing the plugin. Sorry.
From WinSCP
Restart Domoticz
extremeaudio
All my other shelly devices are working, but my RGBW (which I am using in 4 white LED strips mode) is not working
These are the errors in the logs.
2021-04-08 16:57:55.304 Error: (Cove) 'onHeartbeat' failed 'KeyError'.
2021-04-08 16:57:55.304 Error: (Cove) ----> Line 230 in '/home/pi/domoticz/plugins/ShellyCloudPlugin/plugin.py', function onHeartbeat
2021-04-08 16:57:55.304 Error: (Cove) ----> Line 195 in '/home/pi/domoticz/plugins/ShellyCloudPlugin/plugin.py', function onHeartbeat
2021-04-08 16:57:55.304 Error: (Cove) ----> Line 466 in '/home/pi/domoticz/plugins/ShellyCloudPlugin/plugin.py', function updateSHRGBW2
2021-04-08 16:57:55.304 Error: (Cove) ----> Line 513 in '/home/pi/domoticz/plugins/ShellyCloudPlugin/plugin.py', function updateLight-
extremeaudio
Any help with the previous post please ?
I have set my RGBW2 to 4 white channels
But when I make changes in the switch in domoticz I can see commands in the log..
instead of 'color' int he above url it needs to be white. Will the plugin automatically detect that the shelly is set to 4 white channels? Because I dont see any setting in the add hardware section of domoticz.
Please help with this.
2021-04-15 21:58:19.008 (Cove) url: http://192.168.1.65/color/0Please help with this.
DarkG
Today my 3EM arrived. Can you add this to your plugin?
{"device":{"type":"SHEM-3","mac":"8CAAB561D496","hostname":"shellyem3-8CAAB561D496","num_outputs":1,"num_meters":0,"num_emeters":3,"report_period":1},"wifi_ap":{"enabled":false,"ssid":"shellyem3-8CAAB561D496","key":""},"wifi_sta":{"enabled":true,"ssid":"","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"ap_roaming":{"enabled":false,"threshold":-70},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellyem3-8CAAB561D496","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"OPSoqf","name":"Zuleitung HAK","fw":"20210413-154243/v1.10.2-gb89901a","discoverable":false,"build_info":{"build_id":"20210413-154243/v1.10.2-gb89901a","build_timestamp":"2021-04-13T15:42:43Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":true},"timezone":"Europe/Berlin","lat":50.937931,"lng":6.878530,"tzautodetect":true,"tz_utc_offset":7200,"tz_dst":true,"tz_dst_auto":true,"time":"14:00","unixtime":1618660820,"led_status_disable":false,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["out_on_url","out_off_url","over_power_url","under_power_url","over_power_url","under_power_url","over_power_url","under_power_url","over_power_url","under_power_url"]},"hwinfo":{"hw_revision":"prod-2020-1", "batch_id":1},"relays":[{"name":null,"ison":false,"has_timer":false,"default_state":"off","auto_on":0.00,"auto_off":0.00,"schedule":false,"schedule_rules":[]}],"emeters":[{"name":null,"appliance_type":"General","max_power":0},{"name":null,"appliance_type":"General","max_power":0},{"name":null,"appliance_type":"General","max_power":0}],"wifirecovery_reboot_enabled":true}Code: Select all
{"wifi_sta":{"connected":true,"ssid":"","ip":"192.168.0.60","rssi":-42},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"14:01","unixtime":1618660881,"serial":342,"has_update":false,"mac":"8CAAB561D496","cfg_changed_cnt":5,"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"is_valid":true,"source":"input"}],"emeters":[{"power":134.73,"pf":0.59,"current":0.99,"voltage":231.84,"is_valid":true,"total":68.2,"total_returned":16.2},{"power":131.37,"pf":0.51,"current":1.11,"voltage":231.84,"is_valid":true,"total":89.8,"total_returned":22.5},{"power":22.94,"pf":0.61,"current":0.16,"voltage":231.18,"is_valid":true,"total":6.9,"total_returned":0.3}],"fs_mounted":true,"update":{"status":"idle","has_update":false,"new_version":"20210413-154243/v1.10.2-gb89901a","old_version":"20210413-154243/v1.10.2-gb89901a"},"ram_total":48784,"ram_free":29728,"fs_size":233681,"fs_free":156122,"uptime":1890}RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
- EdwinK
- Domoticz version: BETA
Have this error's:
2021-08-12 17:24:24.121 Error: Shelly: (Shelly) 'onHeartbeat' failed 'JSONDecodeError':'Expecting value: line 1 column 1 (char 0)'.
2021-08-12 17:24:24.121 Error: Shelly: (Shelly) ----> Line 230 in '/home/pi/domoticz/plugins/shelly_Cloud/plugin.py', function onHeartbeat
2021-08-12 17:24:24.121 Error: Shelly: (Shelly) ----> Line 195 in '/home/pi/domoticz/plugins/shelly_Cloud/plugin.py', function onHeartbeat
2021-08-12 17:24:24.121 Error: Shelly: (Shelly) ----> Line 348 in '/usr/lib/python3.7/json/__init__.py', function loads
2021-08-12 17:24:24.121 Error: Shelly: (Shelly) ----> Line 337 in '/usr/lib/python3.7/json/decoder.py', function decode
2021-08-12 17:24:24.121 Error: Shelly: (Shelly) ----> Line 355 in '/usr/lib/python3.7/json/decoder.py', function raw_decode
extremeaudio
Is it possible to include support for Shelly RGBW in 4 white mode. Right now only working as RGBW mode
tjabas
hi!
i have installed this plugin but i get these errors:
2021-12-14 20:54:06.112 Error: Zappi: (Zappi) 'onHeartbeat' failed 'JSONDecodeError'.
2021-12-14 20:54:06.112 Error: Zappi: (Zappi) ----> Line 230 in '/home/pi/domoticz/plugins/ShellyCloudPlugin-master/plugin.py', function onHeartbeat
2021-12-14 20:54:06.112 Error: Zappi: (Zappi) ----> Line 195 in '/home/pi/domoticz/plugins/ShellyCloudPlugin-master/plugin.py', function onHeartbeat
2021-12-14 20:54:06.112 Error: Zappi: (Zappi) ----> Line 348 in '/usr/lib/python3.7/json/__init__.py', function loads
2021-12-14 20:54:06.112 Error: Zappi: (Zappi) ----> Line 337 in '/usr/lib/python3.7/json/decoder.py', function decode
2021-12-14 20:54:06.112 Error: Zappi: (Zappi) ----> Line 355 in '/usr/lib/python3.7/json/decoder.py', function raw_decode
i have searched this thread but i cant figure it out what to do to fix this.
Users browsing this forum: fdemees and 1 guest
