Currently the Shelly 1, Shelly 2.5 and the Shelly Dimmer are supported.
Check my github repository https://github.com/mario-peters/ShellyCloudPlugin
I'm still in test phase so every feedback is welcome.
tlambin, thanks for using the plugin. Unfortunately I haven't got a Shelly RGBW(2) device for testing purposes. I'm going to investigate the changes I have to make for adding the Shelly RGBW functionality. Perhaps I can send you a test version in the future?tlambin wrote: Sunday 24 May 2020 23:29 Great.
I tested the SHELLY 1PM, SHELLY 2.5 and SHELLY dimmer.
All works fine with the plug-in.
So easy![]()
Are there any plans for adding the SHELLY RGBW(2) to the plug-in soon?![]()
Derik,Derik wrote: Monday 25 May 2020 22:14 i remove the plugin.
every time when the usage change the pugin change the data in domoticz.
And that with 6 shelly's.
Was to much for my odroid N2.
I already started working on this next feature.mariopeters wrote: Monday 25 May 2020 16:50tlambin, thanks for using the plugin. Unfortunately I haven't got a Shelly RGBW(2) device for testing purposes. I'm going to investigate the changes I have to make for adding the Shelly RGBW functionality. Perhaps I can send you a test version in the future?tlambin wrote: Sunday 24 May 2020 23:29 Great.
So easy![]()
Do you receive an error in de log file when you startup Domoticz?HvdW wrote: Monday 20 July 2020 11:59 Hi
What's the status of this plugin?
I cloned it from github, did chmod +x for the plugin, but I doesn't show in the hardware.
What am I doing wrong?
