Dashticz - Module - Garbage collector Topic is solved
- HansieNL
Re: Dashticz - Module - Garbage collector
1st try without garbage settings and see if it works. You can later add the mappings and renaming parts.
You can change config['garbage_use_names'] = false to disable mappings
Blah blah blah
ok it works now without the garbage settings.
now put in the right config garbage settings?
can you help me with the right ones?
- HansieNL
- Spoiler: show
config['garbage_mapping'] = {
rest: ['sortibak'],
gft: ['biobak'],
papier: ['papier', 'karton'],
config['garbage'] = {
gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
Blah blah blah
it is working but only now i can not read the text, i need a another color now.
can i change that?
can i change that?
- HansieNL
You have to change the code #x123abc in the config['garbage'] to an other hex color code. For hex color codes there are a lot of websites with examples.martin82 wrote: Sunday 20 September 2020 20:05 it is working but only now i can not read the text, i need a another color now.
can i change that?
Blah blah blah
thnx a lot for the help
- EdwinK
- Domoticz version: BETA
Since today (at least I noticed it today) the garbage info isn't displayed anymore.
This is what the console tells me:
js/garbage.js:139 Uncaught TypeError: Cannot read property 'UniqueId' of undefined
at Object.success (js/garbage.js:139)
at fire (bundle.js?t=5:305)
at Object.fireWith [as resolveWith] (bundle.js?t=5:305)
at done (bundle.js?t=5:305)
at XMLHttpRequest.<anonymous> (bundle.js?t=5:305)
Lokonli
Can you send me your zipcode, housenumber and garbage provider? (You can do it by PM)EdwinK wrote: Thursday 24 September 2020 12:22 Since today (at least I noticed it today) the garbage info isn't displayed anymore.
Then I'll check.
Lokonli
I guess you are using bar-afvalbeheer. Their site (https://www.bar-afvalbeheer.nl/afvalkalender) seems to provide no calendar data at all at the moment. Do you maybe have a working url?
- EdwinK
Your guess was correct
, but no, I don't have a working url. When enter my zipcode and housenumber, I get a calendar. In developertools it shows this:
I hope they will fix it soon.
Refused to load the script 'data:application/javascript;base64,KGZ1bmN0aW9uKCkgewoJLy8gaHR0cHM6Ly9kZXZlbG9wZXJzLmdvb2dsZS5jb20vYW5hbHl0aWNzL2Rldmd1aWRlcy9jb2xsZWN0aW9uL2FuYWx5dGljc2pzLwoJdmFyIG5vb3BmbiA9IGZ1bmN0aW9uKCkgewoJCTsKCX07Cgl2YXIgbm9vcG51bGxmbiA9IGZ1bmN0aW9uKCkgewoJCXJldHVybiBudWxsOwoJfTsKCS8vCgl2YXIgVHJhY2tlciA9IGZ1bmN0aW9uKCkgewoJCTsKCX07Cgl2YXIgcCA9IFRyYWNrZXIucHJvdG90eXBlOwoJcC5nZXQgPSBub29wZm47CglwLnNldCA9IG5vb3BmbjsKCXAuc2VuZCA9IG5vb3BmbjsKCS8vCgl2YXIgdyA9IHdpbmRvdywKCQlnYU5hbWUgPSB3Lkdvb2dsZUFuYWx5dGljc09iamVjdCB8fCAn...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' because it violates the following Content Security Policy directive: "script-src * 'unsafe-inline' 'unsafe-eval'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
herbod
My garbage collector has stopped working. It only mentions loading. I have no idea why.
Someone who has an idea how to get it working again?
See attachments for more info.
- a1.jpg (67.87 KiB) Viewed 1464 times
- a2.jpg (80.59 KiB) Viewed 1464 times
Lokonli
Did you already try Dashticz 3.6?herbod wrote: Saturday 26 September 2020 21:51 My garbage collector has stopped working. It only mentions loading. I have no idea why.
Afvalwijzer changed it's interface a few weeks ago. A fix has been implemented already.
If it's not working, please send me your zipcode and housenumber (you can do that by PM) and I'll test.
herbod
Thanks for the tip. I have updated to 3.6 but the problem remains.
My zip is **** and housenumber *** (unfortunatly I can''t send PM)
- madpatrick
- Domoticz version: 2025.2
What is the option "calendar_parse_locally"
i don't have this in my config.
Maybe this is something to look at
Lokonli
You have to remove the setting config['garbage_use_cors_prefix'] or set it to true.herbod wrote: Sunday 27 September 2020 7:36 Thanks for the tip. I have updated to 3.6 but the problem remains.
My zip is 7004LA and housenumber 133 (unfortunatly I can''t send PM)
You also must have PHP enabled.
Garbage for your address is working on my system.
- HansieNL
This is an old setting and not used anymore.madpatrick wrote: Sunday 27 September 2020 10:16 What is the option "calendar_parse_locally"
Blah blah blah
- EdwinK
bar_afvalbeheer seems to be working again.
herbod
Thank you! it is working again. I have sett ['garbage_use_cors_prefix'] to true but wat does it do? I am trying to understand what i did.
What is the option "calendar_parse_locally" - This is an old setting and not used anymore.
So I can remove it?
The days are mentioned in English, can I get them in Dutch?
I have : var config = {}
config['language'] = 'nl_NL';
So I expected them to be in dutch.
Thanks again!
So I can remove it?
Thanks again!
Lokonli wrote: Sunday 27 September 2020 10:40You have to remove the setting config['garbage_use_cors_prefix'] or set it to true.herbod wrote: Sunday 27 September 2020 7:36 Thanks for the tip. I have updated to 3.6 but the problem remains.
- HansieNL
@herbod
Answer: You can find a description here: https://dashticz.readthedocs.io/en/mast ... cors-proxy
So I can remove it?
Answer: Yes
Answer: try adding to your config.js
So I can remove it?
Answer: Yes
Answer: try adding
config['calendarlanguage'] = 'nl_NL';Blah blah blah
herbod
HansieNL wrote: Sunday 27 September 2020 21:48 @herbod
So I can remove it?
Answer: Yes
Answer: try addingto your config.jsCode: Select all
Thanks!! Sometimes it can be so simple. Was looking for this for a while.
Can I change the date 06-10-2020 in the garbage collector dinsdag (tuesday) 06-10-2020, so adding the day?
