Dashticz - Module - Garbage collector Topic is solved
HansieNL
Re: Dashticz - Module - Garbage collector
Post by HansieNL »
1st try without garbage settings and see if it works. You can later add the mappings and renaming parts.
You can change config['garbage_use_names'] = false to disable mappings
Blah blah blah
martin82
Post by martin82 »
ok it works now without the garbage settings.
now put in the right config garbage settings?
can you help me with the right ones?
HansieNL
Post by HansieNL »
martin82 wrote: Sunday 20 September 2020 17:57 ok it works now without the garbage settings.
Can you try with the following config settings (and enable garbage_use_names):
config['garbage_mapping'] = {
    	rest: ['sortibak'],
    	gft: ['biobak'],
    	papier: ['papier', 'karton'],
config['garbage'] = {
    gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
    rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
    papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
Blah blah blah
martin82
Post by martin82 »
it is working but only now i can not read the text, i need a another color now.
can i change that?
HansieNL
Post by HansieNL »
martin82 wrote: Sunday 20 September 2020 20:05 it is working but only now i can not read the text, i need a another color now.
can i change that?
You have to change the code #x123abc in the config['garbage'] to an other hex color code. For hex color codes there are a lot of websites with examples.
Blah blah blah
martin82
Post by martin82 »
thnx a lot for the help :)
EdwinK
Post by EdwinK »
Since today (at least I noticed it today) the garbage info isn't displayed anymore.
This is what the console tells me:
js/garbage.js:139 Uncaught TypeError: Cannot read property 'UniqueId' of undefined
at Object.success (js/garbage.js:139)
at fire (bundle.js?t=5:305)
at Object.fireWith [as resolveWith] (bundle.js?t=5:305)
at done (bundle.js?t=5:305)
at XMLHttpRequest.<anonymous> (bundle.js?t=5:305)
Lokonli
Post by Lokonli »
EdwinK wrote: Thursday 24 September 2020 12:22 Since today (at least I noticed it today) the garbage info isn't displayed anymore.
Can you send me your zipcode, housenumber and garbage provider? (You can do it by PM)
Then I'll check.
Lokonli
Post by Lokonli »
I guess you are using bar-afvalbeheer. Their site (https://www.bar-afvalbeheer.nl/afvalkalender) seems to provide no calendar data at all at the moment. Do you maybe have a working url?
EdwinK
Post by EdwinK »
Your guess was correct :), but no, I don't have a working url. When enter my zipcode and housenumber, I get a calendar. In developertools it shows this:
Refused to load the script 'data:application/javascript;base64,KGZ1bmN0aW9uKCkgewoJLy8gaHR0cHM6Ly9kZXZlbG9wZXJzLmdvb2dsZS5jb20vYW5hbHl0aWNzL2Rldmd1aWRlcy9jb2xsZWN0aW9uL2FuYWx5dGljc2pzLwoJdmFyIG5vb3BmbiA9IGZ1bmN0aW9uKCkgewoJCTsKCX07Cgl2YXIgbm9vcG51bGxmbiA9IGZ1bmN0aW9uKCkgewoJCXJldHVybiBudWxsOwoJfTsKCS8vCgl2YXIgVHJhY2tlciA9IGZ1bmN0aW9uKCkgewoJCTsKCX07Cgl2YXIgcCA9IFRyYWNrZXIucHJvdG90eXBlOwoJcC5nZXQgPSBub29wZm47CglwLnNldCA9IG5vb3BmbjsKCXAuc2VuZCA9IG5vb3BmbjsKCS8vCgl2YXIgdyA9IHdpbmRvdywKCQlnYU5hbWUgPSB3Lkdvb2dsZUFuYWx5dGljc09iamVjdCB8fCAn...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' because it violates the following Content Security Policy directive: "script-src * 'unsafe-inline' 'unsafe-eval'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
I hope they will fix it soon.
herbod
Post by herbod »
My garbage collector has stopped working. It only mentions loading. I have no idea why.
Someone who has an idea how to get it working again?
See attachments for more info.
Lokonli
Post by Lokonli »
herbod wrote: Saturday 26 September 2020 21:51 My garbage collector has stopped working. It only mentions loading. I have no idea why.
Did you already try Dashticz 3.6?
Afvalwijzer changed it's interface a few weeks ago. A fix has been implemented already.
If it's not working, please send me your zipcode and housenumber (you can do that by PM) and I'll test.
herbod
Post by herbod »
Thanks for the tip. I have updated to 3.6 but the problem remains.
My zip is **** and housenumber *** (unfortunatly I can''t send PM)
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
What is the option "calendar_parse_locally"
i don't have this in my config.
Maybe this is something to look at
Lokonli
Post by Lokonli »
herbod wrote: Sunday 27 September 2020 7:36 Thanks for the tip. I have updated to 3.6 but the problem remains.
My zip is 7004LA and housenumber 133 (unfortunatly I can''t send PM)
You have to remove the setting config['garbage_use_cors_prefix'] or set it to true.
You also must have PHP enabled.
Garbage for your address is working on my system.
HansieNL
Post by HansieNL »
madpatrick wrote: Sunday 27 September 2020 10:16 What is the option "calendar_parse_locally"
This is an old setting and not used anymore.
Blah blah blah
EdwinK
Post by EdwinK »
bar_afvalbeheer seems to be working again.
herbod
Post by herbod »
Thank you! it is working again. I have sett ['garbage_use_cors_prefix'] to true but wat does it do? I am trying to understand what i did.
What is the option "calendar_parse_locally" - This is an old setting and not used anymore.
So I can remove it?
The days are mentioned in English, can I get them in Dutch?
I have : var config = {}
config['language'] = 'nl_NL';
So I expected them to be in dutch.
Thanks again!
Lokonli wrote: Sunday 27 September 2020 10:40
HansieNL
Post by HansieNL »
@herbod
Answer: You can find a description here: https://dashticz.readthedocs.io/en/mast ... cors-proxy
So I can remove it?
Answer: Yes
Answer: try adding
config['calendarlanguage'] = 'nl_NL';
to your config.js
Blah blah blah
herbod
Post by herbod »
HansieNL wrote: Sunday 27 September 2020 21:48 @herbod
So I can remove it?
Answer: Yes
Answer: try adding
to your config.js
Thanks!! Sometimes it can be so simple. Was looking for this for a while.
Can I change the date 06-10-2020 in the garbage collector dinsdag (tuesday) 06-10-2020, so adding the day?
