Dashticz - Show your dashboard and how-to's!
HansieNL
Post by HansieNL »
Have you tried to set the following config parameter:
config['last_update'] = 0;
For full manual: https://dashticz.readthedocs.io/en/master/
Blah blah blah
BlizzWave
Post by BlizzWave »
Or you could use CSS.
You would have to inspect the webpage to figure out the correct block name.
But I would assume this would work
.block_2_1 .lastupdate {
	display: none;
JeroenL
Domoticz version: 2023.2
Post by JeroenL »
Having Sonos largely integrated into Dashtiz (see below), the last fun part is still missing: AlbumArt
I have the (dynamic) URL to the current AlbumArt in a Domoticz variable (As I have for album, artist and title). Does anyone have an ideas how I can get this variable from Domoticz into my frames block, something like:
url : sonos_albumart
Also I noticed the images vary in size, do they need to get scaled somehow to be placed properly into a frame?
Thanks - Jeroen
Verzonden vanaf mijn iPad met Tapatalk
Lokonli
Post by Lokonli »
JeroenL wrote: Friday 31 January 2020 16:23 Having Sonos largely integrated into Dashtiz (see below), the last fun part is still missing: AlbumArt
Thanks - Jeroen
Can you create a new topic for this in the subforum 'Feature requests'? Then we will continue the discussion there.
garethiowc
Post by garethiowc »
HansieNL wrote: Thursday 30 January 2020 17:44 Have you tried to set the following config parameter:
DOH! Sorry, I didn't see that. makes life a lot easier
Derik
Post by Derik »
EdwinK wrote: Friday 03 January 2020 9:48
clinkadink wrote: Thursday 02 January 2020 22:11 Image
Looks nice and clean.
Nice!!!
Please share your code's..
Like to have some camera's working
Robert
Post by Robert »
To make your camera work i can show you my configuration.
Note. in Dashticz v3 "image:"is changed inyto "btnimage:"
buttons.webcam = { width: 4, isimage: true, refreshimage: 5000, refreshurl: 5000, btnimage: 'http://Domoticz ip:port/camsnapshot.jpg?idx=2?'}
IDX is depending of your domoticz configuration
lotte3500
Domoticz version: 4.9700
Post by lotte3500 »
My dashboard:
Also installed a tablet:
CONFIG.js:
var config = {}
config['language'] = 'nl_NL';
config['domoticz_ip'] = 'http://172.57.56.105';
config['user_name'] = 'XXX';
config['pass_word'] = 'XXX';
config['dashticz_refresh'] = '3600';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen'
config['news_scroll_after'] = '15';
config['auto_positioning'] = 0;
//config['standard_graph'] = 'DAY';
config['no_rgb'] = 0;
config['hide_topbar'] = 1;
config['calendarlanguage'] = 'nl_NL';
//OpenWeather
config['owm_api'] ='XXX';
config['owm_city'] = 'Roermond';
config['owm_name'] = '';
config['owm_country'] = 'nl';
config['static_weathericons'] = 1;
config['owm_days'] = 1;
config['owm_lang'] = 'nl';
config['owm_min'] = 1;
//Garbage collector
config['dashticz_php_path'] = './vendor/dashticz/';
config['calendar_parse_localy']= 1;
config['garbage_company'] = 'mijnafvalwijzer';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = 'XXX';
config['garbage_street'] = 'XXX';
config['garbage_housenumber'] = '20';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = '5';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = false;
config['garbage_icon_use_colors'] = true;
config['garbage_use_cors_prefix'] = false;
config['garbage'] = {
gft: {kliko: 'grey', code: '#375b23', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
pmd: {kliko: 'orange', code: '#db5518', name: 'Plastic', icon: 'img/garbage/kliko_orange.png'},
rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
kerstboom: {kliko: 'green', code: '#5e5d5c', name: 'Kerstboom', icon: 'img/garbage/tree.png'}
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, btnimage: 'http://api.buienradar.nl/image/1.0/RadarMapNL$
buttons.log = {key:'log', width:12, icon:'fas fa-file-alt', title: 'Domoticz Log', log:true, level: 2}
buttons.domoticz1 = { width:3, isimage:true, refresh:5000, btnimage: 'http://172.57.56.51/dashticz/img/favicon/favicon-96x$
var blocks = {}
blocks[994] = {}
blocks[994]['title'] = 'TV';
blocks[994]['hide_data'] = true;
blocks[1060] = {}
blocks[1060]['title'] = 'Keuken';
blocks[1060]['hide_data'] = true;
blocks[995] = {}
blocks[995]['title'] = 'Eettafel';
blocks[995]['hide_data'] = true;
blocks[1072] = {}
blocks[1072]['title'] = 'Buiten';
blocks[1072]['hide_data'] = true;
blocks[70] = {}
blocks[70]['title'] = 'Aqua dag';
blocks[70]['hide_data'] = true;
blocks[71] = {}
blocks[71]['title'] = 'Aqua nacht';
blocks[71]['hide_data'] = true;
blocks[51] = {}
blocks[51]['title'] = 'Hal';
blocks[51]['hide_data'] = true;
blocks[1419] = {}
blocks[1419]['title'] = 'Stofzuiger';
blocks[1419]['image'] = '../img/mi_robot.svg';
blocks[1419]['hide_data'] = true;
blocks[1419]['width'] = 12;
blocks['s2']['hide_data'] = true;
blocks['s2']['image'] = '../img/tv.png';
blocks[986] = {}
blocks[986]['title'] = 'Computer';
blocks[986]['last_update'] = false;
blocks[1008] = {}
blocks[1008]['title'] = 'Manual';
blocks[1008]['last_update'] = false;
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
//temperaturen
blocks[435] = {}
blocks[435]['title'] = 'Woonkamer';
blocks[435]['width'] = 3;
blocks[429] = {}
blocks[429]['title'] = 'Buiten';
blocks[429]['width'] = 3;
blocks[722] = {}
blocks[722]['title'] = 'Slaapkamer';
blocks[722]['width'] = 3;
blocks[885] = {}
blocks[885]['title'] = 'Garage';
blocks[885]['width'] = 3;
blocks[1400] = {}
blocks[1400]['title'] = 'Babykamer';
blocks[1400]['width'] = 3;
blocks[746] = {}
blocks[746]['title'] = 'Gastenkamer';
blocks[746]['width'] = 3;
blocks[842] = {}
blocks[842]['title'] = 'WC';
blocks[842]['width'] = 3;
//slimme meter
//P1 energie
blocks[1238] = {}
blocks[1238]['width'] = 6;
//P1 gas
blocks[1248] = {}
blocks[1248]['width'] = 6;
blocks['graph_1238'] = {
title: 'Stroom',
graph: ['bar'],
custom : {
"Week": {
range: 'month',
filter: '7 days',
data: {
usage: 'd.v+d.v2'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
usage: 'd.v+d.v2'
graph: 'line',
"Maand": {
range: 'year',
filter: '1 months',
data: {
usage: 'd.v+d.v2'
"Jaar": {
range: 'year',
filter: '12 months',
data: {
usage: 'd.v+d.v2'
datasetColors:['lightblue'],
width: 6,
height: '300px'
blocks['graph_1248'] = {
graph: 'bar',
title: 'Gas',
custom : {
"Week": {
range: 'month',
filter: '7 days',
data: {
usage: 'd.v'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
usage: 'd.v'
graph: 'line'
"Maand": {
range: 'year',
filter: '1 months',
data: {
usage: 'd.v'
"Jaar": {
range: 'year',
data: {
usage: 'd.v'
width: 6,
height: '300px'
blocks[357] = {}
blocks[357]['title'] = 'Zonnewering';
blocks[357]['hide_stop'] = true;
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',994,1060,995,1072,51,'s2',1419,986,357,70,71,buttons.domoticz1,1008]
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = ['weather_owm',435,429,722,885,1400,746,'842_1','graph_1238', 'graph_1248']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise',buttons.buienradar,'garbage',buttons.log,'1238_1', '1248_1']
columns[3]['width'] = 3;
var screens = {}
screens[1] = {}
There is only one thing I am not happy about at the moment. With the graphs, when I select 'Year' I want to have the values summed by month, now it shows per day (see the right graph 'Gas' above). Does anyone have an idea on how to accomplish that?
Last edited by lotte3500 on Monday 03 February 2020 15:40, edited 1 time in total.
HansieNL
Post by HansieNL »
@lotte3500 Your OWM API key is visible in your CONFIG.js !!!
Blah blah blah
lotte3500
Post by lotte3500 »
HansieNL wrote: Monday 03 February 2020 14:14 @lotte3500 Your OWM API key is visible in your CONFIG.js !!!
Thanks! just removed it
edwin1234
Domoticz version: 2021.1
Post by edwin1234 »
does someone know why i only see the graphs in my first screen and in the other screens only the device value?
here is the config:
//Definition of blocks
blocks = {}
blocks['myblocktitle'] = {
type: 'blocktitle',
title: 'verlichting'
//====titel boven bloks=====
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Sensoren';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Verbruik';
//====this shows only hours,day,month in graph=========
config['standard_graph'] = 'day';
var columns = {}
columns[2] = {
blocks : ['myblocktitle' , 12, 11, 15, 14, 18, 9,], //zet de titel boven schakelaars
width: 4
//--- Screen 1 ---
columns[1] = {
blocks : ['blocktitle_2','graph_9','graph_18',],
width: 4
var screens = {}
screens[1] = {}
columns[3] = {
blocks : ['blocktitle_3' , 78, 79, 80, 82, 62,16,],
width: 4
//==== soort grafiek bars of points =====
blocks['graph_9'] = {
graph: 'bar',
datasetColors: ['yellow'],
legend:true
blocks[120] = {
width: 12
var screens = {}
screens['default'] = {}
screens['default']['maxwidth'] = 1920;
screens['default']['maxheight'] = 1080;
screens['default'][1] = {}
screens['default'][1]['background'] = 'bg0.jpg';
screens['default'][1]['columns'] = [1,2,3]
screens['default'][2] = {}
screens['default'][2]['background'] = 'bg9.jpg';
screens['default'][2]['columns'] = [1,]
screens['default'][3] = {}
screens['default'][3]['background'] = 'bg9.jpg';
screens['default'][3]['columns'] = [1,2,]
screens['default'][4] = {}
screens['default'][4]['background'] = 'bg9.jpg';
screens['default'][4]['columns'] = [2,]
screens['tablet'] = {}
screens['tablet']['maxwidth'] = 1024;
screens['tablet']['maxheight'] = 768;
screens['tablet'][1] = {}
screens['tablet'][1]['background'] = 'bg9.jpg';
screens['tablet'][1]['columns'] = [1]
screens['tablet'][2] = {}
screens['tablet'][2]['background'] = 'bg9.jpg';
screens['tablet'][2]['columns'] = [2]
screens['phone'] = {}
screens['phone']['maxwidth'] = 750;
screens['phone']['maxheight'] = 1334;
screens['phone'][1] = {}
screens['phone'][1]['background'] = 'bg0.jpg';
screens['phone'][1]['columns'] = [1]
screens['phone'][2] = {}
screens['phone'][2]['background'] = 'bg0.jpg';
screens['phone'][2]['columns'] = [3]
screens['phone'][3] = {}
screens['phone'][3]['background'] = 'bg0.jpg';
screens['phone'][3]['columns'] = [2]
Lokonli
Post by Lokonli »
edwin1234 wrote: Saturday 08 February 2020 10:43 does someone know why i only see the graphs in my first screen and in the other screens only the device value?
here is the config:
blocks = {}
type: 'blocktitle',
var columns = {}
columns[2] = {
width: 4
//--- Screen 1 ---
columns[1] = {
width: 4
var screens = {}
screens[1] = {}
columns[3] = {
width: 4
graph: 'bar',
legend:true
blocks[120] = {
width: 12
var screens = {}
Until recently it was only possible to show a graph only once. We are finalizing a big update of the graph module, in which this will be solved as well.
edwin1234
Post by edwin1234 »
Ok ,
Thanks for your answer
Vomera
Post by Vomera »
Does someone use the Meteo Alarm plugin on the dashticz ? Can you make a screenshot how it looks like.
I try to implement it, but just need some inspiration :)
EdwinK
Post by EdwinK »
Nothing special, just like this:
Screen Shot 2020-02-11 at 12.27.12.png (46.46 KiB) Viewed 2895 times
The exlmation mark is done with 'fas fa-exclamtion'
The colours change with each warning level.
// Meteo Alarm
blocks[407] = {
icon: 	'fas fa-exclamation',
//title:	'Alarm Vandaag',
width: 6
blocks[408] = {
//title:	'Alarm Morgen',
width: 6
Vomera
Post by Vomera »
I got some inspiration
In config.js
blocks[10922] = {} //Meteo Alarm Morgen
blocks[10922]['width'] = 6;
// blocks[10922]['switch'] = true;
blocks[10922]['hide_data'] = true;
in custom.js
//  meteo alarm
function getStatus_10921(idx,value,device){
   if(device['Data']=="No Data"){
	$('div.block_10921').removeClass('warningyellow').removeClass('warningorange').removeClass('warningred');
    blocks['10921']['icon'] = 'far fa-thumbs-up';
	// geen actie
	else if (device['Data']=="Rain-Flood(2)"){
    $('div.block_10921').addClass('warningyellow');
	blocks['10921']['icon'] = 'fas fa-water';
	blocks['10921']['title'] = 'Hoogwater waarschuwing';
	else if (device['Data']=="Rain-Flood(3)"){
    $('div.block_10921').addClass('warningorange');
	else if (device['Data']=="Rain-Flood(4)"){
    $('div.block_10921').addClass('warningred');
In domoticz
The only thing i want to get is to hide the rain-flood(2) message. Normal you can do it with the hide_data function, but it doesnt work. Maybe because its a "text" subtype in domoticz?
edit:
I got it to manage it in custom.css
.block_10921 .value {
color: transparent !important;
EdwinK
Post by EdwinK »
Looks nice. :)
Vomera
Post by Vomera »
This is version 3.2.0, working on the 3.4.0, but there are some issue's that i'm working on :)
Vomera
Post by Vomera »
EdwinK wrote: Tuesday 11 February 2020 16:03 Looks nice. :)
Tnx :) the color changes also. When its wind(2) its yellow, wind(3) its orange and wind(4) is red.
edwin1234
Post by edwin1234 »
I have set my bar graph color to yellow in the config file
blocks['graph_6'] = {
graph: 'bar',
but the bar graph stays white.
Do i have to change something else?
